Calc65: a BCD floating point package
Re: Calc65: a BCD floating point package
I've even changed an ISR between interrupts that were coming at over 40,000 per second on my 6502 workbench computer, not pausing the interrupts. (To do that you get the new ISR ready and then change the vector to point to the new one.) Even a fast PC can't do that.
I guess you can do that safely, if only one half of the vector needs to be changed...
- BigDumbDinosaur
whartung wrote:
ElEctric_EyE wrote:
Yes, thanks BigEd and Charles R. Bond..
Excellent write-up by Charles on his CBA65. Hashing mnemonics is the most interesting chapter in the .pdf. I'll read this .pdf many times as I would like to eventually tackle an assembler/disassembler for the 65Org16.b. There are many clues here.
When all is said and done, all that has been accomplished is determining whether a mnemonic in the source code is a valid one. His technique doesn't address (!) the requirement of associating that mnemonic with a valid addressing mode and the number of bytes that must be present in the operand, if an operand is required. As many mnemonics can be used with multiple addressing modes, further resolution is required at assembly time to determine if the entered instruction can, in fact, be assembled as written.
Furthermore, while his "perfect" hashing does work for the NMOS 6502 it doesn't directly apply to the CMOS derivatives, which map some previously invalid opcodes onto new instructions or onto existing instructions with new addressing modes. The result is that there isn't a consistent pattern to the relationships between mnemonics and the corresponding opcodes like there was in the NMOS 6502 parts. This is especially the case with the 65C816, which unlike its 8 bit cousins, has no invalid opcodes, has instructions stashed in "odd places," and therefore requires a different method of resolving mnemonics and corresponding addressing modes and operands.
As I earlier said, I used tables (totaling 850 bytes) in my POC's M/L monitor to assemble and disassemble machine instructions, as I was not able to develop any hashing method for the '816 that would work with consistency. Three of the tables are 256 bytes each, corresponding to the 256 possible opcodes of the '816 (i.e., the first entry in each table corresponds to the BRK instruction and the last entry corresponds to an SBC $BBHHLL instruction, where BBHHLL is a 24 bit address), two containing the actual mnemonics in a binary format that produces a unique 16 bit encoding for each mnemonic. I separated the LSBs (least significant byte) and MSBs (most significant byte) into two tables so a simple technique can be used to search for a mnemonic. A short excerpt of the two mnemonic tables follows (taken directly from the POC's BIOS ROM assembly listing):
10222 ; encoded W65C816S instruction mnemonics MSB...
10223 ;
10224 mnetabhb .byte >mne_brk ; $00 BRK
10225 .byte >mne_ora ; $01 ORA (dp,X)
10226 .byte >mne_cop ; $02 COP
10227 .byte >mne_ora ; $03 ORA dp,S
10228 .byte >mne_tsb ; $04 TSB dp
10229 .byte >mne_ora ; $05 ORA dp
10230 .byte >mne_asl ; $06 ASL dp
10231 .byte >mne_ora ; $07 ORA [dp]
10497 ; encoded W65C816S instruction mnemonics LSB...
10498 ;
10499 mnetablb .byte <mne_brk ; $00 BRK
10500 .byte <mne_ora ; $01 ORA (dp,X)
10501 .byte <mne_cop ; $02 COP
10502 .byte <mne_ora ; $03 ORA dp,S
10503 .byte <mne_tsb ; $04 TSB dp
10504 .byte <mne_ora ; $05 ORA dp
10505 .byte <mne_asl ; $06 ASL dp
10506 .byte <mne_ora ; $07 ORA [dp]
...Code: Select all
1040 6D04 mne_asl =$6d04 ;ASL
1049 64C6 mne_brk =$64c6 ;BRK
1058 8C08 mne_cop =$8c08 ;COP
1079 14E0 mne_ora =$14e0 ;ORA
1118 1D2A mne_tsb =$1d2a ;TSB
5929 EA2F 64 53 stz mnepck ;clear encoded...
5930 EA31 64 54 stz mnepck+s_byte ;mnemonic workspace (s_byte = 1)
5931 ;
5932 ;
5933 ; encode mnemonic...
5934 ;
5935 EA33 A0 03 ldy #s_mnemon ;chars needed for mnemonic
5936 ;
5937 EA35 20 ED F2 .0000040 jsr getcharw ;get a char from buffer, strip whitespace
5938 EA38 D0 0A bne .0000060 ;gotten
5939 ;
5940 EA3A C0 03 cpy #s_mnemon ;any input at all? (s_mnemon = mnemonic size)
5941 EA3C 90 03 bcc .0000050 ;yes
5942 ;
5943 EA3E 4C 55 E9 jmp monce ;no, abort assembly
5944 ;
5945 EA41 4C C1 EB .0000050 jmp monasc10 ;incomplete mnemonic — error
5946 ;
5947 EA44 38 .0000060 sec
5948 EA45 E9 3F sbc #a_mnecvt ;ASCII to binary factor (a question mark)
5949 EA47 A2 05 ldx #n_shfenc ;shifts required to encode (5 bits to a char)
5950 ;
5951 EA49 4A .0000070 lsr a ;shift out a bit...
5952 EA4A 66 54 ror mnepck+s_byte ;into...
5953 EA4C 66 53 ror mnepck ;encoded mnemonic
5954 EA4E CA dex
5955 EA4F D0 F8 bne .0000070 ;next bit
5956 ;
5957 EA51 88 dey
5958 EA52 D0 E1 bne .0000040 ;get next char
It is possible, using the same tables, to diassemble an instruction into the corresponding ASCII mnemonic. The first code fragment uses the opcode to get the encoded form of the mnemonic:
8722 F3EC A6 55 ldx opcode ;instruction opcode is mnemonic table index
8723 ;
8724 ;
8725 ; decode mnemonic & addressing info...
8726 ;
8727 F3EE BD E1 F9 lda mnetablb,x ;packed mnemonic LSB
8728 F3F1 85 53 sta mnepck ;working storage LSB
8729 F3F3 BD E1 F8 lda mnetabhb,x ;packed mnemonic MSB
8730 F3F6 85 54 sta mnepck+s_byte ;working storage MSB
...Code: Select all
8803 ; display mnemonic...
8804 ;
8805 F457 A0 03 ldy #s_mnemon ;size of ASCII mnemonic
8806 ;
8807 F459 A9 00 .0000040 lda #0 ;initialize char
8808 F45B A2 05 ldx #n_shfenc ;shifts to execute
8809 ;
8810 F45D 06 53 .0000050 asl mnepck ;shift encoded mnemonic
8811 F45F 26 54 rol mnepck+s_byte
8812 F461 2A rol a
8813 F462 CA dex
8814 F463 D0 F8 bne .0000050
8815 ;
8816 F465 69 3F adc #a_mnecvt ;convert to ASCII &...
8817 F467 48 pha ;stash
8818 F468 88 dey
8819 F469 D0 EE bne .0000040 ;continue with mnemonic
8820 ;
8821 F46B A0 03 ldy #s_mnemon
8822 ;
8823 F46D 68 .0000060 pla ;get mnenmonic byte
8824 F46E 20 9A E3 jsr bsouta ;print it (BIOS console display sub)
8825 F471 88 dey
8826 F472 D0 F9 bne .0000060Code: Select all
10772 ; instruction addressing modes & sizes...
10773 ;
10774 ; xxxxxxxx
10775 ; ||||||||
10776 ; ||||++++———> addressing mode index...
10777 ; ||||
10778 ; |||| Index Mode
10779 ; |||| ———————————————————————————————————
10780 ; |||| 0000 dp, abs, absl, implied or A
10781 ; |||| 0001 #
10782 ; |||| 0010 dp,X, abs,X or absl,X
10783 ; |||| 0011 dp,Y or abs,Y
10784 ; |||| 0100 (dp) or (abs)
10785 ; |||| 0101 [dp] or [abs]
10786 ; |||| 0110 [dp],Y
10787 ; |||| 0111 (dp,X) or (abs,X)
10788 ; |||| 1000 (dp),Y
10789 ; |||| 1001 dp,S
10790 ; |||| 1010 (dp,S),Y
10791 ; |||| 1111 sbnk,dbnk (block move)
10792 ; |||| —-—-—-—-—-—-—-—-—-—-—-—-—-—-—-—-—-
10793 ; |||| A = accumulator
10794 ; |||| abs = absolute
10795 ; |||| absl = absolute long
10796 ; |||| dbnk = destination bank
10797 ; |||| dp = direct (zero) page
10798 ; |||| S = stack relative
10799 ; |||| sbnk = source bank
10800 ; |||| ———————————————————————————————————
10801 ; ||||
10802 ; ||++———————> binary-encoded operand size
10803 ; |+—————————> 1: relative branch instruction
10804 ; +——————————> 1: variable operand size...
10805 ;
10806 ; —————————————————————————————————————————————————————————————
10807 ; Variable operand size refers to an immediate mode instruction
10808 ; that can accept either an 8 or 16 bit operand. During instr-
10809 ; uction assembly, an 8 bit operand can be forced to 16 bits by
10810 ; preceding the operand field with a pipe (|), e.g., LDA |#$01,
10811 ; which will assemble as $A9 $01 $00. LDA #$0001 will assemble
10812 ; as $A9 $01, whereas LDA |#$0001 will assemble as $A9 $01 $00.
10813 ; —————————————————————————————————————————————————————————————
10814 ;
10815 mnetabam .byte ops0 | am_nam ; $00 BRK
10816 .byte ops1 | am_indx ; $01 ORA (dp,X)
10817 .byte ops1 | am_nam ; $02 COP
10818 .byte ops1 | am_stk ; $03 ORA dp,S
10819 .byte ops1 | am_nam ; $04 TSB dp
10820 .byte ops1 | am_nam ; $05 ORA dp
10821 .byte ops1 | am_nam ; $06 ASL dp
10822 .byte ops1 | am_indl ; $07 ORA [dp]Code: Select all
0992 ; addressing mode translation...
0993 ;
0994 0000 am_nam =%0000 ;(0) no symbol
0995 0001 am_imm =%0001 ;(1) #
0996 0002 am_adrx =%0010 ;(2) dp,X or addr,X
0997 0003 am_adry =%0011 ;(3) dp,Y or addr,Y
0998 0004 am_ind =%0100 ;(4) (dp) or (addr)
0999 0005 am_indl =%0101 ;(5) [dp] or [addr]
1000 0006 am_indly =%0110 ;(6) [dp],Y
1001 0007 am_indx =%0111 ;(7) (dp,X) or (addr,X)
1002 0008 am_indy =%1000 ;(8) (dp),Y
1003 0009 am_stk =%1001 ;(9) dp,S
1004 000A am_stky =%1010 ;(10) (dp,S),Y
1005 000B am_rsrva =%1011 ;(11) reserved
1006 000C am_rsrvb =%1100 ;(12) reserved
1007 000D am_rsrvc =%1101 ;(13) reserved
1008 000E am_rsrvd =%1110 ;(14) reserved
1009 000F am_move =%1111 ;(15) MVN/MVP sbnk,dbnkAs the '816 can use 24 bit operands with many instructions (e.g., LDA $123456), some code shenanigans were required to deal such situations. In general, the rule is "least fit," meaning use the machine opcode to which the smallest form of the operand will fit. For example, if I code JMP $000012, the assembler will assemble the instruction as $4C $12 $00 (JMP $0012), since JMP can accept either a two or three byte address and the entered address, $12, can be minimally resolved to two bytes. Coding JMP $012345 will result in $5c $54 $32 $01 (JMP $012345)—note the $5C opcode, which is a jump to another bank instruction.
Immediate mode instructions that can accept either 8 or 16 bit operands are also subjected to the "least fit" rule, so coding LDA #$0012 assembles to $A9 $12, even though the apparent intention is to assemble the instruction with a 16 bit operand. As "least fit" in this case can alter the program in an undesirable way, I devised a syntactical method to force the assembler to assemble a 16 bit operand, even though the MSB is zero. If the programmer precedes the operand with a | (UNIX pipe) the operand will be assembled as 16 bits. Hence LDA |#$12 will result in $A9 $12 $00 (LDA #$0012). This sort of chicanery is necessary because, unlike the above JMP examples, as well as other instructions that can use 24 bit addresses as operands, there is no opcode difference when assembling 8 bit immediate operands vs. 16 bits—the resolution comes from how the M and X bits in the status register are conditioned at run time.
Anyhow, this ran on a bit longer than originally intended and wasn't meant to be a diatribe on assembler algorithms. My point was that C.R. Bond's assembler is simplistic in the sense that going outside of the realm of the NMOS 6502 will produces complications that his code would not readily handle. This statement, however, is not meant to denigrate his work in any way.
- BigDumbDinosaur
C R Bond's calc65 floating point arithmetic and transcendental function package:
http://www.crbond.com/calc65.htm
Uses 8 bytes and BCD to give 12 decimal digits and 3 exponent digits.
Have you tried that link? All I get is a screen full of gibberish when I attempt to access the source code.
.print stats,xref,clip=76,csort=c,cycles
.files h6x
; fltpt7.cba -- floating point routines for 650X
; (C) 1999 - 2008, C. Bond. All rights reserved.
; v.1
; This version includes add, subtract, multiply, divide, square
; root, tangent and arctangent. The tangent and arctangent are
; implemented as efficient BCD CORDIC algorithms. Sine, cosine
; arcsine and arccosine are also provided.
- BigDumbDinosaur
- GARTHWILSON
- Forum Moderator
I did and it didn't—it's still run-on lines.
$ file fltpt65.cba
fltpt65.cba: ISO-8859 English text, with CRLF line terminators
Here's an example of a perfect hash I tried with the GNU 'gperf' program, and the NMOS 6502 mnemonics. First, it defines a table of letter values:
Now, if you have a 3 letter mnemonic, you can turn that into a number. The first step is to change the middle letter, so it's one more. For example, "SBC" becomes "SCC", and "TXA" becomes "TYA". The next step is to look up the resulting letters in the table, and add up the 3 numbers. So for instance, "SBC" becomes "SCC", and S=0, and C=1, S+C+C = 0+1+1 = 2.
Here are the results:
All codes from 2 to 53 are used exactly once. Between the last couple of codes, there are some holes. These could be patched by a few lines of code that map 62->54, 66->56, and 78->57. Or, if you have enough memory, you can fill the holes with some value that indicates the mnemonic isn't valid.
A 2
B 4
C 1
D 2
E 11
F 2
G 82
H 82
I 19
J 32
K 46
L 5
M 31
N 43
O 15
P 3
Q 39
R 18
S 0
T 5
U 25
V 10
W 48
X 6
Y 4
Z 16
SBC -> SCC -> 0 + 1 + 1 = 2
SEC -> SFC -> 0 + 2 + 1 = 3
SED -> SFD -> 0 + 2 + 2 = 4
DEC -> DFC -> 2 + 2 + 1 = 5
BCS -> BDS -> 4 + 2 + 0 = 6
BCC -> BDC -> 4 + 2 + 1 = 7
DEY -> DFY -> 2 + 2 + 4 = 8
TXS -> TYS -> 5 + 4 + 0 = 9
DEX -> DFX -> 2 + 2 + 6 = 10
TXA -> TYA -> 5 + 4 + 2 = 11
...all codes between 11 and 53 ...
BVC -> BWC -> 4 + 48 + 1 = 53
JSR -> JTR -> 32 + 5 + 18 = 55
RTI -> RUI -> 18 + 25 + 19 = 62
BMI -> BNI -> 4 + 43 + 19 = 66
JMP -> JNP -> 32 + 43 + 3 = 78
I converted the fltpt65.cba file with dos2unix, then assembled it with C R Bond's cba65 assembler (using WINE on linux) and have bundled the results up in a zip file attached to the head post. One would either study this package or port it to another assembler syntax, I suspect. I may remove the archive as technically it's a copyright problem - so if you want it, grab it while you can.
The log file from the assembler is quite interesting: it includes a count of the opcodes used, sorted in order:
Also, the assembly listing includes cycle count information.
NUMBER OF SOURCE LINES: 4135
NUMBER OF LISTING LINES: 4413
NUMBER OF SYMBOLS: 345
NUMBER OF UNREFERENCED LABELS: 35
NUMBER OF REFERENCES: 1975
NUMBER OF ANONYMOUS LABELS: 153
NUMBER OF ASSEMBLER WARNINGS: 0
MAX. INCLUDE FILE NESTING LEVEL: 0
NUMBER OF CPU INSTRUCTIONS: 2965
OPCODE USAGE SUMMARY (SORTED BY OPCODE COUNT):
MNEMONIC OPCODE COUNT MNEMONIC OPCODE COUNT MNEMONIC OPCODE COUNT
JSR nn 20 0332 LDA #n A9 0306 LDX #n A2 0247
LDY #n A0 0175 BPL n 10 0153 STA n 85 0119
STA nn,X 9D 0114 DEX CA 0110 LDA nn AD 0106
RTS 60 0092 STA nn 8D 0084 LDA nn,X BD 0071
BNE n D0 0067 JMP nn 4C 0061 AND #n 29 0055
LDA n A5 0051 LDA nn,Y B9 0046 CLC 18 0042
DEY 88 0040 BRK 00 0040 BEQ n F0 0039
BCC n 90 0037 STA nn,Y 99 0033 BCS n B0 0032
DEC n C6 0029 LDA (n),Y B1 0028 ASL 0A 0026
SED F8 0025 ADC #n 69 0024 ORA nn,Y 19 0022
LDY nn,X BC 0022 CMP #n C9 0020 INC n E6 0019
SEC 38 0018 CLD D8 0017 BIT nn 2C 0015
ORA nn 0D 0014 TAX AA 0014 LSR 4A 0014
LDX n A6 0014 ADC nn,X 7D 0011 BMI n 30 0010
CPX nn EC 0009 CMP nn CD 0009 BVS n 70 0009
- BigDumbDinosaur
Arlet wrote:
The perfect hashing method works fine with other 6502 derivatives, as long as the list of mnemonics is fixed. The idea is that you take a random 3 character string, and turn it into a 8 bit number with a small amount of arithmetic operations. With a perfect hash, each of the valid mnemonics would generate a distinct number. After verifying the 3 character string, the next step is to look up the 8 bit number in a table, and produce the mnemonic index in the range 0..N-1, where N is the number of mnemonics. The rest of the processing is the same as if you'd looked up the mnemonic in a table of strings to produce this index.
The hashing process, in my not-uneducated opinion, is a colossal waste of time for this application. Hashing would make sense when the array is large, elements in the list are of varying sizes, and/or not in ascending or descending lexical order. In such cases, the overhead of hashing the search key and checking for collisions would pay off. However, the NMOS 6502 only has 56 unique mnemonics and the worst case, the 65C816, has only 92. There's just not all that much data to search. Hence the hashing search algorithm itself would contribute to much of the wall clock time required to look up a mnemonic. In all likelihood, a binary search on a sorted array of mnemonics (or a 16 bit representation of them) would be on average just as fast and would not require hash collision checks. In an assembler, far more time will be consumed in evaluating and error checking of each line of code than in looking up a mnemonic in a sorted array. In fact, I daresay I/O performance will be the true bottleneck, not compute-bound operations.
- BigDumbDinosaur
A 2
B 4
C 1
D 2
E 11
F 2
G 82
H 82
I 19
J 32
K 46
L 5
M 31
N 43
O 15
P 3
Q 39
R 18
S 0
T 5
U 25
V 10
W 48
X 6
Y 4
Z 16
- GARTHWILSON
- Forum Moderator
I know how hashes work.
- BigDumbDinosaur
You can go into a loop that watches for evidence of the interrupt just having been serviced, and when you see that one has been, immediately jump in and change both bytes of the vector, while you know you have enough time before the next interrupt. The interrupts were on evenly spaced intervals from a timer.
- BigDumbDinosaur
My own understanding of hashes, splay trees, AVL trees, etc. is awfully foggy.
