Firing up a FIG-Forth
As I mentioned in my introduction post, I'm toying with a home built simulator and assembler and trying to get the FIG 6502 assembly listing going.
From the anecdotes I've seen here, it seems that the list is solid and that I shouldn't be second guessing it or looking for bugs in it per se.
I've already found several bugs in my simulator. My two recent ones were my INC instruction was actually DECrementing (bad), and my LDA (X, 1) instructions weren't as indirect as they should have been.
Throughout the debug process, I've been adding simple features to the simulator to aid me getting this up to speed.
Now, though, while the inevitable problem may well be with a bad instruction implementation, I'm running in a lot of high level Forth words.
I'm using the JSR TRACE feature and I've added to that the capability of dumping the parameter stack in my tracings. This looks really helpful.
My current problem is basically it's printing "? Msg #0" for pretty much anything I type after I hit enter. Whether its a blank line, a number or a forth word -- always that same thing.
I think the problem is within the NUMBER routine. But still not sure. The Forth is harder to debug at this level than the assembly is.
I guess Msg #0 is the "don't know what this is" error. Not sure on that either.
Anyway, figured I'd just chime in and let others know what my progress is.
Comments always welcome.
- BigDumbDinosaur
Re: Firing up a FIG-Forth
whartung wrote:
...and my LDA (X, 1) instructions weren't as indirect as they should have been.
Let us know how far you get. Do you have adequate Fig FORTH doc, BTW?
cheers,
On the plus side, we know most of your simulator is working properly, simply based on the fact you're able (I assume) to get the greeting upon program start, and that you have a command prompt and can type in a string and see your keystrokes echoed. That's saying a lot!
I maybe should've explained that INTERPRET first checks whether the input string is a Forth word -- that's what -FIND is for. Only if that fails does it attempt to treat the string as a number. Conclusion: NUMBER may or may not be broken, but if the machine can't find a known word like DUP or SWAP then something else has already gone wrong. My suggestion is to look for the first problem first.
the number '1' is a Forth word, so -FIND and (FIND) should find it. But that's clearly failing because as I understand it, FIND is tried first and if it fails, then NUMBER is tried.
I have some archive of a Fig doc, that seems to be missing Chapter 7. It's in some mostly plain text format, but there's obvious garbage at the start and end. But it's legible.
In Chap. 8, it describes the NUMBER code, and I can see exactly what code is failing.
From that document there's this excerpt;
BEGIN Start the conversion process
DPL ! Store the decimal point counter
(NUMBER) Convert one digit after another until an invalid char occurs.
Result is accumulated into d .
DUP C@ Fetch the invalid digit
BL - Is it a blank?
WHILE Not a blank, see if it is a decimal point
DUP C@ Get the digit again
2EH - Is it a decimal point?
0 ?ERROR Not a decimal point. It is an illegal character for a number.
Issue an error message and quit.
0 A decimal point was found. Set DPL to 0 the next time.
REPEAT Exit here if a blank was detected. Otherwise repeat the
conversion process.
It could be as simple as Forth seeing my LF (line feed, ascii 10) while it's looking for a CR. I found the one reference in EXPECT, perhaps there are others. It's not "configurable" like DEL/RUBOUT/BS is in a user variable(?, I think). No, nothing glaringly obvious at least.
Since (FIND) is machine code, that could easily be a bug in the simulator. It's clear that NEXT and friends is all working, or we wouldn't be this far. They work much better now that INC does the right thing lol.
But if it's in (FIND) I should have a decent chance of hunting it down, as I said, it's easier to debug machine code that Forth at this point.
Well, it's not the memory being too big, not yet at least, though I didn't know it had that limitation.
I'm in the process of trying to figure out (FIND). It runs for a bit before it exits, it's definitely looping through something. It's getting the CONTEXT value and the text that it's looking for looks good. I don't quite know the structure of the back end of the dictionary, so I'll have to decipher that so I can watch it click along to see what part of the scanning is failing, and why.
Figured the hot tip was just to try MON since it should succeed immediately.
It took me a little while to grok what was going on with the EORs to facilitate comparison, an idiom I was not accustom to.
In the end, though, it worked well since I just had a few instructions to work through. As it turned out my AND instruction was setting flags based on the operand, but not the result -- oops. Amazing it got as far as it did.
So, it's finding words now. My new issue is: "1 1 + ." prints zero. Stack looks good, so it's probably in the number formatting routines somewhere.
But progress is progress.
But perhaps you prefer to fix the emulator piecemeal, and learn about Forth at the same time. Here's a bit of code that may prove helpful:
: COMPTEST ( --- ) KEY EMIT ;Code: Select all
HEX
: HEXDIGIT. ( n --- ) F AND 30 +
DUP 39 > IF 7 + THEN EMIT ; ( isolates the ls nibble of n and outputs the ascii equivalent)
: 10h* ( n --- n*10h) DUP + DUP + DUP + DUP + ; ( shifts n 4 places to the left)
: HEX. ( n --- ) DUP 10h* DUP 10h* DUP 10h*
HEXDIGIT. HEXDIGIT. HEXDIGIT. HEXDIGIT. ; ( outputs the ascii equivalent of n)Quote:
cjb wrote:
MEM can't be greater than $7F00. The words that scan and add to the dictionary do signed comparisons with pointers.
16-bit addresses, standard in Fig-FORTH, are sign-extended automatically by the 68000 CPU so that 16-bit addresses in the range 8000-FFFF point the CPU to FFFF8000 - FFFFFFFF (i.e. highest 32K). Unfortunately, most systems do not have RAM available, decoded for this upper 32K. Unless your system does, this 68000 implementation will work only in the lowest 32K.
If the compiler seems OK...
I modified the JSR TRACE routine to show word nesting, as well as to dump the current parameter stack - that makes it MUCH easier to follow along to see what's going on. It appears I have some problem in U*, but I'm still working on that one. I was suspecting ROL for a bit but that seems ok so far.
MEM = $6E00 ;top of assigned memory+1 byte.
UAREA = MEM-128 ;128 bytes of user area
DAREA = UAREA-BMAG ;disk buffer space.Re: Firing up a FIG-Forth
whartung wrote:
Struggling this way via getting Forth running is more interesting
Detail is that I seem to be mostly in high level Forth right now, which seems to pretty much work, rather than low level assembly (which is obviously questionable).
For example, just entering a number (say 123) is causing issues. So I'm going to dig in to NUMBER, and see what's what.
Speaking of numbers, you'll eventually want to take action regarding Garth's warning about the U* aka UM* multiplication bug if you haven't already. But no rush -- this bug is rarely the source of any trouble, and likely isn't to blame for any obvious problems presently on your plate.
PS- I notice 6502.org has a copy of the Fig Forth 6502 assembly source under Monitors, Assemblers, and Interpreters, here. This version does include the U* bug.
cjb wrote:
I was referring to the parameter set in the fig-forth assembler source
