I'm seeking advice on bench top power supplies
Help me choose a bench top power supply. I might want something for 6502 work but I'm also mindful of other more modern microprocessors or microcontrollers. I don't want to spend a bundle but I think they are safer than building my own power supply and some microcontrollers are going down to 1.8 volts.
http://www.mpja.com/Bench-Supplies/products/2/
Re: I'm seeking advice on bench top power supplies
I bought myself some cheap supply, it broke twice already, and it does not have a 5V output mode. As for the laboratory supplies, every singe one that i encountered in school or in the university's lab was broken. I've seen many people building their own supplies with lm385, and it works, and it is much cheaper also. But if you need precise voltages, i suppose you should buy one of toes...
- GARTHWILSON
- Forum Moderator
A page in the 6502 primer:
http://wilsonminesco.com/6502primer/BasicWkbench.html
"Stopped reading there..."
I'll suggest getting the power-points-with-USB-recharger-sockets, a suitably chopped-up USB cable, and you'll have a regulated 5VDC supply that's good for up to typically 500mA to 1A. See http://i.imgur.com/nRafp.jpg
For the other voltages, I'm using a recent' car-lighter-socket to USB adaptor that uses a high-efficiency DC-to-DC converter IC inside (I bought another this morning for $5..) and replacing the "R1" resistor that controls the Vout on the DC-DC conversion IC inside with a suitable potentiometer. The STM MC30463 IC I've got here has datasheets available for knowing what value is needed.
- GARTHWILSON
- Forum Moderator
> The LM7805 [..]
> Um, is that to say you have something against it?
In designed products, they're maybe acceptable, but the suggestion of using a LM7805 for ad-hoc power provision usually brings out their worst-- not being adequately heatsinked (the proverbial prototype supply that then gets used 24/7.. and then there's all that heat next to an electrolytic cap..) It's also the 21st Century, you don't need to waste watts of electricity for a milliwatt mcu..
Linear semis also have a significant piracy problem, in that it's good practice now to just test any of their devices you have for being on-spec.
- GARTHWILSON
- Forum Moderator
Getting 5v power from USB is so convenient (for hobby purposes) that I'd like to know if there are any downsides to it.
Dajgoro wrote:
The 5V output of an usb charger/adapter is good, but when used from a pc usb port it is not 5V at all, if i am lucky i get 4.7V, with lots of interference.
Thanks - worth knowing. Things which run at 3V3 or less can evidently get away with deriving their power from a PC USB, but I suppose that means they still need a regulator. Also, you only get 100mA from a host port until you request more - not so for chargers.
http://www.maxim-ic.com/app-notes/index.mvp/id/3241
(actually, you might get more, but that's all you're supposed to take.)
> The LM7805 [..]
I think if I spend the money on one, that will be my final purchase for the year. I don't mind throwing away a chip or two that gets damaged because it is cheaper than buying a top of the line benchtop supply. I just wanted the next best one from my list and hopefully under $100. For aircraft safety, the best is critical. For me, expense is the difference between being able to afford a project and failure.
- BigDumbDinosaur
I use old PC power supplies for situations that can get by on fixed voltages. The three most widely used voltages with computer hardware are available in copious amounts, and with minimal noise. In fact, I have an old ATX power supply running my POC unit, which is powered from one of the 5¼ inch floppy drive connectors. The current (!) output voltages (I just checked) are 5.04 volts and 12.03 volts, according to my Fluke DVM. That's less than a one percent error on both outputs. Close enough for me!
1) Setting up production of such items is not cheap. Payback at a few cents per item would be measured in terms of years.
2) The design and production of linear regulators are well understood. It is difficult to imagine a company that did go to the trouble of getting into production of these, intentionally screwing it up to save a few milli-cents.
3) I've not heard of this before now. Have I had my head in the sand?
Besides, the regulation tolerance of LM78XX regulators is about +/- 5%. If you want really close tolerances you'll need to be selective even from first line suppliers
As for a great bench supply, I have a Systron-Donner / Trygon TL8V-3-0V. It's huge and old, but the performance is beyond reproach. I got mine on eBay for about $90 four years ago, including shipping. It seems they are still in circulation: http://www.ebay.com/itm/SYSTRON-DONNER- ... 0340602873
This is but one of several currently for sale on eBay.
They are truly awesome. I doubt you could get a modern, made in china alternative that would perform as well for so little. or weigh as much.
If anyone does ever get one, I have the service manual and would be willing to scan it for you.
Mine has a General Dynamics asset tag on it. I wonder what it was used to help design?
