Raspberry Pi and the MagPi
The Raspberry Pi is gaining popularity fast, and there is also the MagPi magazine, and the first issue has been released. The MagPi kinda reminds me of the old 80' computer magazines(i never read them, but i plan to follow this) and i guess that it is going to be very interesting and educative.
It seems that the 80' computer programming era just got a reboot with a bit of the 80' nostalgia.
I think this is worth following and commenting, so i started this topic...
Re: Raspberry Pi and the MagPi
link for the magazine: http://themagpi.wordpress.com/
I think one of the nice things about the Pi is that it boots from SD card, which is of course swappable. So you can have a number of experimental environments which don't need to co-exist. And although you (probably) have to boot a linux kernel, you don't necessarily have to boot all the way into a full linux distribution with a windowing environment: you could boot straight into some program of your choice, whether a python or native ARM program.
Adafruit Prototyping Pi Plate Kit for Raspberry Pi -
http://www.adafruit.com/products/801
An alternative to the Raspberry Pi is:
Olinuxino 1.2 GHz single board computer
http://dangerousprototypes.com/2012/04/ ... -computer/
Take note - that's a future plan board! Even the 545MHz boards are 'due in May' - see links from pricelist
http://www.olimex.com/dev/pricelist.html
The R-Pi is still cheaper, i just got a email from my local farnell distributer, they will be able to get them August, instead of June... So i guess i wont be seeing any pies soon...
I would also like to try making some arm based projects myself, but i have no idea how to build them...
There's a datasheet here
http://www.element14.com/community/docs ... spberry-pi
with plenty of detail about lots of the on-chip peripherals. What has people upset is that there isn't detail about how to drive the video capabilities, beyond what the closed-source linux video driver allows for. (But that's plenty for most purposes.)
ElEctric_EyE
ChuckT wrote:
...The Raspberry PI has a chip in it and the major supplier won't issue a very detailed datasheet.
It seems to be worse than that - there's no detailed datasheet, so even less access to peripherals than found on the Pi. But this is all very off-topic - let's stick to products which are at least in production even if supplies are very limited.
To answer Dajgoro's earlier point: have a look at cjb's posting elsewhere (the STM32F4DISCOVERY is a cheap ARM-based dev board with lots of 5V-tolerant I/O - the chip is surface mount but not BGA)
(*)but see cjb's comment below.
i remember seeing some arm mcu that had an external bus interface, where you could add external ram(or maybe hardware?).
Friends of mine are pushing for a 65816 simulator next
NOTE: DON'T BUG ME ABOUT A 65816 SIMULATOR >:E
With this kind of mcu, you only have a more powerful hardware, and (almost?) no more functionality that my sbc has now. The real deal is hiding in soc solutions, and i tried investigating them, but they are all kinda obscure, and until somebody points you the right direction, you don't have a point where to start.
The thing that makes me crazy is that i am right now in the 4. semester, and still i haven't seen any modern hardware(actually i did have some arm assembly once, but only basics in an emulator), right now i have labs with the 8051...
Is there some sort of IDE software, or something similar for this sort of arm mcu/cpu?
