It is currently Mon May 20, 2013 10:32 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Mon Apr 23, 2012 9:15 pm
The 6502 was a nice processor to program but looking around the alternatives of the time (Z80, 6809 etc) there were a few things I missed. Interestingly the clever double width accumulator of the 6809 or the similar 16 bit registers of Z80 were not one of them. Rather the DJNZ was something I would have liked. Inner loops could never get tight enough so something that decremented X or Y and branched, preferably with a backward bias, in a single instruction was something I wanted. If anyone is about to improve the 6502 instruction set I'd like to hear your view on such end-of-loop instructions.
Steve Wozniak created SWEET16 that I had thought would provide the necessary 16 bit functionality and also a transition to a 16 bit processor. So why was SWEET16 never implemented in hardware? Like the 6502 it was elegant, orthogonal and required no prefix codes. It seems to me like a lost opportunity.
PostPosted: Mon Apr 23, 2012 10:25 pm
You could just use the 65816. Although the high address byte (A16-A23) may look scary, you don't have to latch, decode, or use that high address byte to still get a ton of benefits. The code length is dramatically shortened anytime you need to deal with 16-bit values. See an example here. Keep in mind however that the 6502 out-benchmarked the Z80 even though the Z80 had more and wider registers, and ran at higher clock rates.
PostPosted: Mon Apr 23, 2012 11:37 pm
something that decremented X or Y and branched [...] in a single instruction was something I wanted
Hello, Alienthe! It is an interesting idea. Loops account for a high proportion of the execution time for most programs, so speeding up the critical loops is usually worth the effort -- an optimization almost as reliable as boosting clock speed. Loops can be unrolled, of course, but that's a bit OT. I can certainly see the appeal of a DJNZ equivalent for 6500 family.
One caveat is that it has to be more than just a convenience for producing pretty code. IOW I'd want to be certain there's a bottom line saving in clock cycles. (Did the Z80's DJNZ live up to this?) At 5 cycles, the DEY BNE sequence is already pretty fast, even though not as sexy as a single instruction equivalent. In the spirit of discussion, what would be the costs and benefits of separately optimizing the DEY instruction and the BNE instruction? The overall payoff would be broader...
cheers
http://LaughtonElectronics.com
PostPosted: Tue Apr 24, 2012 6:34 am
I could've done with a 2 cycle instruction to swap the top and bottom 4 bits of the accumulator (SWap Nybble?). Would've saved on sequences like
ASL A
ASL A
ASL A
ASL A
which could just have become
SWN A
AND #$F0
I guess it would've been a whole new special path in the random control logic, as it's not remotely like any other kind of operation, so I can see why it wasn't there.
PostPosted: Tue Apr 24, 2012 7:12 pm
SWEET16 was launched as part of Apple II back in 1977, the 65816 was launched late in 1984. These 7 years represent, in my view, a lost opportunity. SWEET16, while not as capable as 65816, would have been simple to implement due to orthogonality and a well structured ISA and instruction code design, as one would indeed expect from the Woz. Moreover the SWEET16 is more "spacious" having more registers, while the 65816 adds no new general purpose registers.
I remember many benchmark discussions back in the day but I never was really sure how the speed really differed.
PostPosted: Tue Apr 24, 2012 7:34 pm
Collapsing multiple instructions into one, esp. with something like incrementing or decrementing has its caveats. For example Motorola got it wrong in the 68000 where the postincrement/predecrement of index registers was broken when for example a bus error ABORTed the opcode. Collapsing dec/inc and branch should be fine in this respect though.
However, if you start combining INX with BNE, you could also combine INX with BEQ, and INY instead of INX and maybe even a memory location, and other branches.... You quickly clutter your opcode space.
Here is a set of opcodes I defined for my 65002: http://www.6502.org/users/andre/65k/specsprog.html
BLT - Branch Less Than (C=0 or Z=1)
BGT - Branch Greater Than (C=1 and Z=0)
RDL - Rotate Direct Left (rotate without carry, i.e. bit 7 is directly moved to bit 0)
RDR - Rotate Direct Right (rotate without carry)
ASR - arithmetic shift right (shift in the sign from the left)
SWP - swap upper and lower nibble
INV - two's complement
BCN - bit count, compute number of 1-bits
SXY - swap X and Y
PSH - push all registers (in a 6502 that would be AC, XR, YR, more in a 65002)
PLL - pull all registers (in a 6502 that would be AC, XR, YR, more in a 65002)
FIL - fill a memory area with a byte value
ADS - add value to stack pointer
SBS - substract value from stack pointer
MVN/MVP - move a memory area (see 65816)
HBS - determine bit number of highest bit that is set (like log2)
HBC - determine bit number of highest bit that is clear
BSW - bit swap - exchange bit 7 with bit 0, bit 6 with bit 1, etc
(Not all of them are already on the web page though).
INX/INY can be done in a single cycle in the 65002, so there is not much penalty of not combining them.
André
Edit: added ASR which I had forgot
PostPosted: Tue Apr 24, 2012 7:36 pm
I've got some notes on Z80 vs 6502 which I wanted to put into some order for a coherent post about what happened with chess machines... But here are some raw clippings:
The fridge (Judd) reckons a roughly 3:1 clock speed comparability
http://www.ffd2.com/fridge/speccy/score
and has good architectural comparison
(The implication is that 4MHz z80 wins versus 1MHz 6502, but not against 2MHz 6502.)
The hpmuseum queens benchmark comes out at 2.8:1
http://www.hpmuseum.org/cgi-sys/cgiwrap ... ead=120687
       -  Z80      283 msec
       -  6502     100 msec
       -  68000    220 msec
There are some cycle count comparisons in the slightly excited
http://www.alfonsomartone.itb.it/aunlzr.html
In this thread
https://groups.google.com/forum/#!msg/a ... I1im1b2DsJ
william H ivey says he found a 1MHz 6502 to be more performant than a 4MHz z80
That thread and another page both say that z80 is good for floating point. The other page says it's because of the large register set - so less memory bandwidth needed.
http://www.andreadrian.de/oldcpu/Z80_nu ... ncher.html
PostPosted: Tue Apr 24, 2012 7:45 pm
cheers
Well, syntactic sugar always has an appeal. My value proposition here is actually more real than that:
1: Loops never get tight enough.
2: The BNE is (nearly) symmetric as to the maximum distance of branching forward or backward and it gets inelegant if you have to branch more than 128 away from present address. An instruction as proposed here would lend itself to a backward bias, with branches -192 to +64, perhaps even -224 to +32, saving ugly branches plus JMP.
3: BNE is 2 cycles if branch not taken, 3 if taken. The proposal here is to assume branch is taken and optimise for that, shaving off another cycle.
4: DEX + BNE is in sum 3 bytes and 5 cycles, while a LPX (just to give it a name) would be 2 bytes and 3 cycles, perhaps 2 cycles (see point 3).
5: It overcomes the lack of post/pre decrementing index registers during load/store, as found in many other processors, and does so without adding more combinatorials to the existing already substantial number of addressing modes.
LPX (=DEX; BNE) might even be combined as LPX ++Y (=INY; DEX; BNE) allowing fast reversal. Simultaneous decrementing both X and Y seems less useful.
All in all I believe the benefits are substantial. As for the cost it requires 2 (perhaps 4) new opcodes: LPX, LPY, LPX ++Y, LPY ++X with corresponding logic. Considering decrementing and branching logic already are in place I guess the added logic would not be that great.
To speed things up you might prepare branch if register is not 1 and then run the decrement in parallel, retiring the updated value while the branch is taking place.
I was never comfortable about comparing with Z80 so I cannot comment much on the timing issues for Z80. Still, I believe these looping instructions are sexy, draped in leather and crack the whip over Z80, as it should...
PostPosted: Tue Apr 24, 2012 7:54 pm
I quite agree. A clean structure is to me one of the attractions of the 6502 (and also the SWEET16). For looping purposes I was only thinking of decrementing and a BNE with backward bias. There are some obvious variations outlined in my earlier reply.
Incidentally the DSP65300 has a zero overhead loop function. It is fast, elegant and clever but regrettable requires a fair bit of logic and a flag in the processor status.
PostPosted: Tue Apr 24, 2012 8:53 pm
I never noticed any injustice in the backward-versus-forward branch distance myself. Although I've done the branches around JMPs, I don't remember it ever being to get back to the top of a long loop. However there have been many times when longish forward branches were needed to bypass a portion of code that should be skipped under the current conditions.
The benchmarks truly are favorable to the 6502; but the one that really counts of course is your own application. I have a short list of new instructions I would like added, but I can imagine a list of reasons why they have not been added, ranging from instruction-decoding complexity versus speed, to silicon real-estate costs which apparently are one of the major motivators for WDC's licensees to choose the 65c02 over the competition for many jobs.
PostPosted: Tue Apr 24, 2012 9:28 pm
I have a short list of new instructions I would like added, ...
I'm eager to hear of them!
André
PostPosted: Wed Apr 25, 2012 1:24 am
My first reaction is: what sets the status register flags? The change in Y or the change in X?
Presumably the answer is the change in X. Okay, but what am I going to know about the state of Y (ie., the value it holds) after the loop terminates? In the general case, presumably nothing.
My second reaction is: oh, this adds to the complexity of trying to visualize just what the instruction really does. Every other instruction changes just one register at a time; this would be un-orthogonal to them. Oh, my poor head!
I do pity myself quite easily.
PostPosted: Wed Apr 25, 2012 2:16 am
Signed or unsigned comparison? As things stand now signed comparisons are always a tricky thing on the 6502. You have to use that mysterious V-flag if you want to do signed. It's difficult enough to grasp what's going on that a lot of people stay away from it. Perhaps explicitly signed comparison, subtraction and addition instruction branch instrctions would be helpful as well.
I like these. They can be synthesized already by interspersing CMP immediates among ROL/ROR sequences, but they're occasionally nice to have.
This would be extremely handy. This might be the best addition of them all.
I dunno. It's easy enough already to do "EOR #$FF". I don't know that I want to do this often enough to make it worthwhile as a separate instruction. Is there some address mode other than accumulator where this is useful?
This would take a (very) short routine to duplicate, and the answer would come in log(N) time. Or a big lookup table and constant time. Is there enough need to make it a separate instruction? I can see that it would be handy if you wanted to do parity checks, but beyond that I'm stumped. If parity is all it's good for, why not just a parity status flag?
SXY - swap X and Y
Mmm. Maybe. All I can think of is setting up registers prior to subroutine (or OS) calls, but it might be handy at that.
So the other day I was thinking "What if each register had its own dedicated on-chip stack space?" Ie, N registers, N stacks And then I thought "What would that possibly be good for?" And then I thought "Interrupts!". I was thinking the processor would do it automatically upon recognizing an interrupt, so an ISR could start out trashing any register it wanted. RTI would restore them all. If each stack was 8- or 16-deep, you could even deal with re-entrant interrupts. The stacks would not be user-accessible, just places to stash register values during interrupts.
But an instruction to do it would be just as useful. The idea of multiple dedicated stacks would of course be to minimize response time to an interrupt. I don't think these would be as useful for calling subroutines, mainly because of the difficulty of returning results in registers (if the callee did PSH at the start then PLL at the end would trash anything you put in them...unless maybe the caller did PSH? Then after the callee returns, save any results passed in registers before the caller does PLL...might work. Okay, I like it)
Again a short subroutine. Is the speed advantage (one or two cycles per byte?) worth it?
Fun. I like these, although playing with stack pointer is not for novices.
I never liked this instruction much. Kind of ugly. The coolest answer to this in the 6502 world I ever saw were the Commodore RAM expanders. That REC chip could do transfers and fills at a byte per clock cycle, and swap two bytes in two clock cycles.
How is the result returned, BTW? What if no bit is set? If bits are numbered 7..0 then zero is not an answer to that. I guess I'm having trouble seeing how useful they'd be, ie., what problem do they solve?
PostPosted: Wed Apr 25, 2012 5:03 am
This is mostly from a list that's at least 10 years old when I probably wasn't thinking as much about relocatable code where relative addresses for data access would be a plus. The '816 can do that though, maybe not as nimbly as nimbly as I could wish, but a hundred times as well as the 6502 can.
STF STore FF to a memory location without affecting processor registers. Many times a byte is used as a flag variable, and STZ clears it, so STF would set it much more efficiently than STZ, DEC. LDA #$FF (or $FFFF) followed by STA ___ affects a processor register.
DIN and DDE Double INcrement and Double DEcrement. Same as INC INC or DEC DEC but faster, and the C flag would tell if you went from FF to 01 or vice-versa without having to test in between the two INC or DEC instructions. This is particularly useful in higher-level languages that are always incrementing pointers to the next two-byte address.
BEV & BOD ("Branch if EVen" and "Branch if ODd"), using another flag in the status register. I can't remember anymore why I wanted these. The need might go away with the DIN and DDE above. Since the NMOS 6502 had the JMP(xxFF) bug, Forth on that one required keeping 16-bit values aligned on even addresses. It's not a problem on the CMOS one, so potentially thousands of bytes can be saved by not having to align.
SWN SWap Nybbles $12 becomes $21. Useful in cobbling together fast math routines? 65816 has an XBA instruction to swap bytes in the 16-bit accumulator.
JSR relative long, to anywhere in the 64K memory space. (This and long relative branching are possible on the 6502 by doing JSR to a routine that calculates the target address, but it's very inefficient. The JSR puts the calling address on the stack so the routine can add the offset to it.) The '816 has BRL, and you can synthesize a BSR with it by preceeding it with PER.
Several other desirables are already implemented in the 65816, like a branch relative long (BRL), stack-relative addressing, block move, push an indirect address or a relative address or a literal on the stack, movable base page that doesn't have to be ZP, 16-bit stack pointer, etc..
Putting just a few of IDC (indirect-threaded code) Forth's internals like NEXT , nest , and unnest in the machine-language instruction set would make a big difference in execution speed and I believe could be used for other higher-level languages as well, although the extra stack pointer mentioned recently to use an RTS-like instruction for DTC (direct-threaded code) Forth's NEXT would probably be more efficient. STC (subroutine-threaded code) Forth doesn't need any of them.
Eliminate most dead bus cycles. I don't know if it gets easier if the input clock were faster than the bus, like 20 or 40MHz input for a 10MHz bus.
Looking over my own lists and others', I'd have to say that most of the dreamed-of extra instructions would not be used enough to justify them, or there's already a provision in the '816, like the block-fill one which can be done with MVN or MVP, starting from the oposite end from how you would do a move. Ones like MULtiply take a lot of silicon real estate.
PostPosted: Wed Apr 25, 2012 2:53 pm
The 65C816's XBA instruction does that on the accumulator.
x86? We ain't got no x86. We don't need no stinking x86!
