After a bit of thinking, I came up with this preliminary design for a video output system, useful for implementing games. I wanted something that would be efficient, flexible, and not too hard to write in Verilog. I also wanted to be able to display bitmaps, transparency, overlapping windows, tiles and sprites, but I didn't want a whole bunch of separate modes and systems that would make it very complex.
So, I came up with the following:
1. One block RAM will be used to hold as a big list of items that are shown on the screen. Each item is a rectangular bitmap or arbitrary size. For each item, it will store X/Y coordinates, and the item number. I was planning to use 8 bits for X, 8 bits for Y, and 8 bits for the item #. The remaining 8 bits are reserved for later.
So, for instance, if item #0 represents a 64x80 pixel tree, you could make a table that says:
(200,100,#0)
(300,200,#0)The objects support transparency (later maybe also other effects such as shadow/fog/and similar color manipulations), so they can be overlapped to create extra effects. By overlapping the trees, you could make a nice looking forest, for instance. Or you could make a foreground layer and a background layer, and scroll them at different speeds to create a 3D parallax effect. Of course, the rendering time and bandwidth usage will go up depending on the overlap. Animation, such as a running hero could be accomplished simply by changing the item # in the table. For each different number, a different image would be displayed in the same position, and it would only require 1 byte to be written.
2. The description of each possible object is stored in a second table, indexed by item number. So, for our tree item #0, this table will hold:
0: width=64, stride=64,height=80, base=$1239A
I'm trying to avoid artificial limitations, so there's no 8 sprite/scanline limit, for instance. Bandwidth and rendering time vary with total number of objects, objects per scanline, object size, and amount of overlap. If you try to do too much, the engine will just run out of time, and start dropping objects. It's up to the programmer to keep an eye on that.
