The interest lies in the shape:
- 16 bit registers (8 of them, plus SP and O, a fullsize overflow register)
16 bit 'bytes'
16 bit 'address bus'
opcode is 1 'byte' plus 0, 1 or 2 operand 'bytes'
The spec of the DCPU-16 is simple, and is very clearly laid out here. It's more regular than our machines: all registers except SP can perform all roles. It lacks a status word, instead having a set of skip on compare instructions. All instructions take two operands, where the operands can be registers, literals, memory or indirect accesses, or special. (These are quite powerful addressing modes)
It seems likely that someone will come up with a C compiler before too long. I'm not sure how applicable that will be as a starting point for targetting the 65Org16.b, given the differences in the machine. At the very least, the backend would be issuing macros or sequences of 65Org16 instructions, which would cost time and space. A peephole optimiser might make up a little of the slack. (But a C compiler which produces less them optimal code on a CPU running at 100MHz might be better than none at all)
There's a subreddit which is presently too new to have much in it. There's a tag on stackoverflow which is again too fresh to have any meat.
Edit: and there's a forum here
(*)The c is a superscript but it seems that we don't write it out as 0x10^c
