65Org16 Assembler (16-bit bytes, 32-bit address space)
ElEctric_EyE
Post by ElEctric_EyE »
Thanks again Bitwise!
What is actually involved in making these 'minor' adjustments to your JAVA creation? Could a layman like myself do them?
BitWise
In Memoriam
Post by BitWise »
If you can program in Java then the code is quite easy to fix. For example here a link to the patch for the last bug fix
http://dev65.svn.sourceforge.net/viewvc ... pathrev=16
You'd need a Subversion client, a copy of the Eclipse IDE with the 'Subclipse' plug in installed, a sourceforge account and access permission to commit changes back to repository -- All these are free downloads and registrations + me granting you repository access.
Andrew Jacobs
ElEctric_EyE
Not so easy, heh...
Are you sure that's the update? I'm getting all zero page opcodes again, even LDA$xxxxxxxx which was fixed before... I'll try the ! expression.
BitWise
In Memoriam
Post by BitWise »
ElEctric_EyE wrote:
Not so easy, heh...
Curious. I get
FFFFF000  00BD8000FFFF      :                 LDA $FFFF8000,X
FFFFF003  00BD8000FFFF      :                 LDA !$FFFF8000,X
FFFFF006  00BD8000FFFF      :                 LDA |$FFFF8000,X
FFFFF009  00B58000          :                 LDA $00008000,X
FFFFF00B  00BD80000000      :                 LDA !$00008000,X
FFFFF00E  00BD80000000      :                 LDA |$00008000,X
FFFFF011  00EE8000FFFF      :                 INC $FFFF8000
FFFFF014  00EE8000FFFF      :                 INC !$FFFF8000
FFFFF017  00EE8000FFFF      :                 INC |$FFFF8000
FFFFF01A  00E68000          :                 INC $00008000
FFFFF01C  00EE80000000      :                 INC !$00008000
FFFFF01F  00EE80000000      :                 INC |$00008000
Andrew Jacobs
ElEctric_EyE
It works. I forgot it optimizes $00000001 to $0001...
Some more observations as I am testing more opcodes on my .b core:
1) STA $xxxx,Y ($0091) is observed as STA $xxxxxxxx,Y ($0099). In fact, all odd opcodes in column 1 have this problem, i.e. ($0011,$0031,$0051,$0071... observed as $0019,$0039,$0059,$0079, etc.)
Thanks for your continued support!
BitWise
In Memoriam
Post by BitWise »
In the WDC datasheet $91 is STA (zp),Y. Only LDX and STX have a zp,Y addressing mode so the assembler uses the abs,Y instruction where zp,Y isn't available.
FFFFF02B  009980000000      :                 STA $00008000,Y
FFFFF02E  009980000000      :                 STA !$00008000,Y
FFFFF031  009980000000      :                 STA |$00008000,Y
FFFFF034  00910001          :                 STA ($0001),Y
FFFFF036  00110001          :                 ORA ($0001),Y
FFFFF038  00B61234          :                 LDX $1234,Y
FFFFF03A  00961234          :                 STX $1234,Y
Andrew Jacobs
ElEctric_EyE
DOH, I knew that. Indirect Indexed. :oops:
Still it is an interesting feature of your assembler. Thanks, I think As65 is bug free now!
ElEctric_EyE
Re: 65Org16 Assembler (16-bit bytes, 32-bit address space)
In As65, I am using simple macro's like for instance:
LDBi              .MACRO          ;LDB #$xxxx
                  .BYTE $01A9
                  .ENDM
And so when I write the assembly I have to do this:
LDBi
.BYTE $00FF
What is the syntax of the macro have to look like to have the assembly abit more agreeable to the eyes?
LDBi, $00FF
or
LDBi $00FF
or something along these lines.
Ideally, it would look like
LDBi #$00FF
Is this possible?
In that case, with the three commercial assemblers I've worked with, you would put the name of a macro variable in the macro definition line:
LDBi:  .MACRO  param
       .BYTE   $1A9, param
       .ENDM
Something I liked about the 2500AD assembler is that you could have any number of parameters, and have, in essence, "If there is a fourth parameter, do this; if there is a fifth one, do that," etc..
For different address modes, you would probably have to use another parameter to tell it which addressing mode you want, or put it in the mnemonic, which is what I did in my super-simple Forth assembler, so it takes for example, LDA# or LDA_ZP or LDA_ZP,X etc.. Not being familiar with As65 though, I suspect the range of characters it lets you put in a label (as for macro names) is more limited.
BitWise
In Memoriam
Post by BitWise »
As65 accepts named or numbered arguments. So you can write either
LDBi    .MACRO  param
        .BYTE   $1A9,param
        .ENDM
or
LDBi    .MACRO
        .BYTE   $1A9,\0
        .ENDM
In both cases you invoke it with
        LDBi    $1234
If you wanted to extend the assembler to understand a new opcode the you would add a block like the following but change the constants in the switch to the correct values of the LDB opcodes
	 * An <CODE>Opcode</CODE> that handles the LDA instruction.
	protected final Opcode 	LDA		= new Opcode (KEYWORD, "LDA")
		 * {@inheritDoc}
		public boolean compile ()
			switch (parseMode ()) {
			case IMMD:	genImmd (0x00A9, arg);	break;
			case DPAG:	genDpag (0x00A5, arg);	break;
			case ABSL:	genAbsl (0x00AD, arg);	break;
			case DPGX:	genDpag (0x00B5, arg);	break;
			case ABSX:	genAbsl (0x00BD, arg);	break;
			case DPGY:
			case ABSY:	genAbsl (0x00B9, arg);	break;
			case INDX:	genDpag (0x00A1, arg);	break;
			case INDY:	genDpag (0x00B1, arg); 	break;
			case INDI:	genDpag (0x00B2, arg);	break;
			default:
				error (ERR_ILLEGAL_ADDR);
			return (true);
You have to make a couple of other small tweaks but that's the most of it.
Andrew Jacobs
ElEctric_EyE
LDBi              .MACRO  param        ;LDB #$xxxx
                  .BYTE $01A9, param
                  .ENDM
This is giving me 'invalid expression' error. Your second example yields same result. What could I be doing wrong?
BitWise
In Memoriam
Post by BitWise »
                  .BYTE $01A9, param
                  .ENDM
Curious, I get:
FFFFF03C                      LDBi            .MACRO  param
                                              .BYTE   $01A9,param
                                              .ENDM
                                              .EXTERN fred
                                              LDBi    $00ff
FFFFF03C  01A900FF          +                 .BYTE   $01A9,$00ff
                                              LDBi    fred
FFFFF03E  01A90000          +                 .BYTE   $01A9,fred
                                              LDBi    1+2*3
FFFFF040  01A90007          +                 .BYTE   $01A9,1+2*3
Andrew Jacobs
ElEctric_EyE
Ok. Thanks for checking...
Is this sufficient for the beginning of a 65016 boot.asm file, or am I missing something?
     .CODE
  	.ORG	$FFFFC000
I'm running NMAKE from a DOS command window under Windows XP SP3.
NMAKE is giving me 13 of these identical errors if this is any clue.
BitWise
In Memoriam
Post by BitWise »
Send me a copy of your boot.asm file
Andrew Jacobs
ElEctric_EyE
Ah, I am dense. It works. I didn't realize when I change the macro parameters, I need to change the way the macro's are invoked. The errors were all the times the macro was improperly invoked, using the old syntax. Sorry about that.
Now, extending your assembler seems interesting, where would I add that block? You made provisions for $B2, the indirect indexed W addressing mode? Although it seems like more work, it may be worth it in order to get the assembly looking exactly as it should. I'd like to experiment with this.
