g540 programmer programming ATF22V10C
Dajgoro
Post by Dajgoro »
I didn't express myself well when i said memory test, i meant ram test.
I use Windows XP(32 bit) SP3, on a desktop pc(AMD Phenom, AM2+ socket).
takioh
Post by takioh »
Dajgoro,
Yesterday I've tried once more again, carefully ZIF socket down, and all process have done as the manual described.
The result is......Wow! it works! I managed to write program into UV-EPROM.
I dont't know how could I acheive the process, but I think Dajgoro is right.
ZIF socket would be cheep, sometimes it can't grab enough dip pin.
So it causes program error, I guess.
G540 is not garbage, but some operational skill would be required.
Thank you, Dajgoro.
P.S. I've already ordered another universal programmer ;)
I had trouble sometimes with the green 3M ZIF sockets, but I've never had trouble with the black Aries ZIF sockets. Does this unit have the former?
takioh
Post by takioh »
Mr.Wilson,
My G540 has Black ZIF sockets.
It seems that quality check is not good.
I'm now building UV-EPROM eraser....
Dajgoro
Post by Dajgoro »
I am glad you managed to get it working!
As for erasing eproms, i tried uv-led(1 day), no success, so i moved to try with the sun(1 week), but Zagreb is not a very sunny city, so i ended up ordering the eraser from ebay...
I built an EPROM eraser from a cheap kitchen cabinet light fixture, using a antiseptic UV fluorescent lamp and a mechanical timer. Erase time is typically 12 minutes and I can get 15 EPROMS into the rig at a time.
Programming GALs
I've since "improved" my low-tech EPROM erase by attaching the timer directly to the light fixture.
EPROM Eraser w/Integral Timer
Also, if anyone has the TOPS853 USB programmer and wants version 10 of their software please contact me via PM. Despite the usual Chinese-English gaffes and a somewhat strange user interface, it appears to work much better than the older versions.
