But my problem is the weird daughter board sat in UE7; it contains 4 roms, marked 901465, from 20 to 23.
I can only find a single .bin file containing all 4 roms together on zimmers.net, but I can't find anywhere an explanation on how to change this daughter board with a single EPROM; what kind of eprom can be fitted into UE7? And how to connect this EPROM? Is the same schematics as UA5 and UA6?
Thank you for any help,
73 de IW9HGS - Gabriele "asbesto" Zaverio
"Museo dell'Informatica Funzionante" Computer Museum http://museum.freaknet.org
This is the first time I hear of such a daughter-board but I can understand its purpose. With the 8296 Commodore combined the previously used 4k ROMs into a single 16k ROM. The original 8296 comes with such a single chip in UE7. In your case some seems to have replaced the single chip with an adapter to use the original 4k ROMs.
So do you suspect these ROMs or the adapter to be defect? Then you have two options - use a single 16k ROM (assumingly with an appropriate pinout adapter if necessary, not sure about that), or replace/use the adapter with single 4k ROM chips.
Well, I fixed my 8296 just replacing UE5 with an EPROM using an handwired adaptor, but i'm just collecting information in case of a new failure This daughter board was very weird to me.
BTW, there is a little mistake on the description of the 8296 on your web site.
The 8296 is compatible with the 8096, which is just a 8032 with a 64k RAM board, so 32K+64K would be correct for a 8096.
The 8296, however, has 128k RAM. On the other hand, only slightly more than the 32K+64K of the 8096 can be used: The system ROM can be replaced with some of the extra 32k RAM using some board (jumper) configuration.
Thank you for this, we fixed that page with the new informations!
Please excuse us for errors in pages, we're starting our serious work; we had very hard years in which we only stored our pieces in some deposits, and we decided to rent a space for our Museum only some months ago; so we really have a lot of voluntary work to fix everything: the space, computers, the internet sites and so on...
Gee...and to think that I can recall when one could see these machines being used in businesses before IBM PCs ruined everything. Great that you were able to get it going again.
