It is currently Sat Nov 23, 2024 4:40 am
PostPosted: Wed Feb 01, 2012 12:06 am
VGA Primer for generating video signals
Video Graphics Array "VGA" is a standard for computer display.
http://www.nathandumont.com/node/241
PostPosted: Wed Feb 01, 2012 12:32 am
Wow, we probably should set up a section of the website for things like this, which although are not absolutely 65-family related, are definitely related to the projects we take on with the 65 family! I added it to my own bookmarks. Thanks.
PostPosted: Wed Feb 01, 2012 1:11 am
http://elm-chan.org/works/crtc/report.html
the Elm Chan CPLD VGA controller. Should be easily interfaceable to the C02 bus...
PostPosted: Wed Feb 01, 2012 2:23 am
Nathan applied his VGA primer to hardware which includes the ChipKit Uno32. It isn't FPGA but some of the hardware to his pong demo could be applied to FPGA:
http://www.nathandumont.com/node/242
He has other VGA projects.
ChipKIT: Conway's Game of Life on VGA
http://www.nathandumont.com/node/244
I don't know a whole lot about electronics even though I've been reading about different hardware for three years. I seek having different solutions which includes video for microcontrollers, the 6502 and its compatibles.
PostPosted: Mon Oct 22, 2018 8:07 pm
Some projects using only TTL logic chips to produce VGA video signals:
https://hackaday.com/2015/10/15/spit-ou ... gic-chips/
https://hackaday.io/project/20334-bread ... l-and-sram
https://hackaday.io/project/20161-bread ... and-eeprom
http://www.pyroelectro.com/projects/mas ... ideo_card/
PostPosted: Thu Nov 08, 2018 9:45 pm
Here is a VGA timing calculator I wrote when I made Vulcan-74...
[url]lucidscience.com/temp/VGA.exe[/url]
Just set the clock to what you are using, and it does the rest.
I also made an NTSC calculator for my current JetPack project...
[url]lucidscience.com/temp/NTSC.exe[/url]
Brad
PostPosted: Thu Nov 08, 2018 10:20 pm
The Rockwell 6545AP can be made to do VGA timing. A normal 6545 or a 6845 is a little too slow, but the AP version of the Rockwell 6545 is fast enough. It's mainly designed for text displays but can be made to do graphics as well. As it's only really a timing generator chip you can widen the bus width of the video ram to more than 8-bits and add more colours or text attributes.
PostPosted: Wed Dec 19, 2018 3:04 pm
Here are some nice tutorials I found for generating VGA with Verilog.
https://timetoexplore.net/blog/arty-fpga-vga-verilog-01
