I've hit a wall on my "Veronica" 6502 project ( http://quinndunki.com/blondihacks/?p=780 ) , and no amount of googling or researching or experimenting is helping anymore.
I have an Atmel AT28C256 32k x 8 parallel EEPROM (data sheet: http://www.jameco.com/Jameco/Products/P ... 4843AT.pdf ). I am trying to write to it, but nothing I do seems to work. The datasheet says it works just like an SRAM, but my circuit ( http://quinndunki.com/blondihacks/wp-co ... vB_Sch.jpg ) which writes correctly to SRAMs has no effect on the EEPROM.
Let's reduce it to the simplest possible case. For example:
1) Hook up Vcc and ground on the EEPROM
2) Tie all address and data lines to ground
3) Tie /CE low, /OE high, and /WE high
4) Briefly touch /WE to low, then back to high.
I expect this to write 0x00 to address 0x0000. On an SRAM, that is what happens with this exact test. On the EEPROM, I get 0xFF (the factory default value) back. I've tried everything I can think of, but I cannot get any byte to write anywhere into this thing. I've tried four different chips, thinking one might be bad. I also tried disabling the Software Write Lock, per the datasheet, even though it is supposed to be disabled from the factory. All four chips were purchased new from Jameco.
The above breadboard test works on an SRAM just fine, as does my dedicated writing circuit (linked to above). So I'm skeptical of the datasheet's claim that the EEPROM is written to the same way. I'm intentionally avoiding the page-write mode by only writing a single byte, to eliminate variables. I've scoured the data sheet, trying to find some trick that I've missed, but I can't see anything wrong. I've gone through the timing diagrams with a fine toothed comb, and spent hours on the logic analyzer, but can't find anything I'm doing differently from what the datasheet specifies.
Any and all suggestions would be much appreciated. I'm completely out of ideas on what might be wrong. It must be something silly, because the datasheet makes it sound very simple to use this thing. I have a couple of new chips en route from another source, but that's a long shot. I can't believe all four of the ones I got are bad?
- Quinn
