TMorita wrote:
Jameco stocks the entire WDC product line now, apparently:
http://www.jameco.com/webapp/wcs/stores ... =jamecoall
Or:
http://www.jameco.com and search for "western design center".
Toshi
Or:
Toshi
BTW, to anyone contemplating a new PCB design around the WDC parts, I highly recommend using the PLCC44 packages instead of DIP. It doesn't seem like it at first, but the PLCC44 layout uses only about 60 percent of the board real estate used with the DIP packages. Also, trace lengths can be substantially shorter with the PLCC44 parts, which helps to keep a lid on stray capacitance and other ill effects. When I started laying out the PCB for my POC unit I tried both DIP40 and PLCC44 for the MPU. There was no contest.
Now, if you are planning to do a wire-wrap layout, PLCC will be more challenging, but not as bad as you might think. The socket's pin grid is still on 0.100 centers, even though the contact spacing on the chip package is 50 mil. The only thing that might give you pause is keeping the pin numbers straight.
