Getting started in Forth
8BIT wrote:
I was trying to enter a double number by just typing it in. I found that it only loaded the upper 16 bits onto the data stack, not the entire 32 bits.
8BIT wrote:
it worked
DPL (a User Variable) will retain the position of the decimal (radix?) point in case you actually need to interpret it somehow -- for fixed-point arithmetic, perhaps. But Forth makes no assumption -- you're on your own! (As usual
Re: tracing down the '816 wrinkle, I recall Fig has a JSR Trace that can optionally be included with NEXT. Using that, maybe you could determine approximately where things went off the rails, thus narrowing your search for the bug.
I found the page wrapping problem in two places. On a 65c02, an LDA $FE,X will wrap around back into page 0. The 65816 in emulation mode will too. However, in native mode, it will advance into page 1.
Example: X=$10, LDA $FE,X The address pointed to:
65C02 = $0E
65816 = $0E (emulation mode)
65816 = $10E (native mode)
Here's the offending code:
and here
Corrected code adds just one instruction:
The other fix I mentioned, a TXS replacement, is here:
This get fixed to:
FigForth now runs on a 65816 in native mode. I can now work on the disk interface.
65C02 = $0E
ZBRAN .WORD *+2
INX
INX
LDA $FE,X
ORA $FF,X
BEQ BRAN+2
PPLOO .WORD *+2
INX
INX
STX XSAVE
LDA $FF,X
PHA
PHA
LDA $FE,X
ZBRAN .WORD *+2
LDA $00,X
ORA $01,X
INX
INX
CMP #$00 ; <--- added
BEQ BRAN+2
PPLOO .WORD *+2
LDA $01,X
PHA
PHA
LDA $00,X
INX
INX
STX XSAVE
RPSTO .WORD *+2
STX XSAVE ; load return stack pointer (machine
LDY #8 ; stack pointer) from silent user
LDA (UP),Y ; VARIABLE R0
TAX
TXS
RPSTO .WORD *+2
TAX
; TXS
lda #$01 ; 65816 native mode fix
.byte $eb ; XBA
txa ;
.byte $1b ; TCS (16 bit equiv to TXS)
BTW, re Fig FORTH, you should (if you haven't already) get your hands on the fig-FORTH INSTALLATION MANUAL by William F. Ragsdale. The Glossary he includes is invaluable. Amazon lists this document; mebbe it's downloadable somewhere as well; dunno. (Copyright permitting, it'd be a worthwhile addition to the 6502.org library!)
- GARTHWILSON
- Forum Moderator
Daryl, I should have thought of that for you so you could save some time, but it has been years since I worked on my '816 Forth. What I did on that for 0branch (which won't work on the '02 though) is:
where HEADER is a macro that makes the header (which you omitted for brevity), PRIMITIVE is a macro which does the same thing as your ".WORD *+2", and INX2 is a macro that just puts a pair of INX's in since that's done in so many places in the kernel.
HEADER "0branch", NOT_IMMEDIATE
0branch: PRIMITIVE
INX2
LDA FFFE,X
BEQ branch+2
.That code works too.
I compared bytes used and cycles used and both your way and mine are the same - 10 cycles and 6 bytes (just affected opcodes, not entire subroutine).
Thanks Garth. Down the road, I may try to optimize this Forth for the 816, unless you find time to publish your's first. In the mean time, I still have a lot to learn.
- GARTHWILSON
- Forum Moderator
Down the road, I may try to optimize this Forth for the 816, unless you find time to publish yours first.
And again--for those who are afraid of the 816's mode bits-- You almost never take it out of 16-bit accumulator and 8-bit index registers. You leave it in those modes almost all the time. When you do change it, you use a macro so it's clear what you're doing, like "INDEX_16" instead of whatever the cryptic REP or SEP instruction is.
I'll send you mine whenever you're ready. It's just that the explanations are not not all cleaned up as tidy as I would like it to be, especially for those who have no significant prior Forth experience.
- GARTHWILSON
- Forum Moderator
I should add:
If I were a millionaire in terms of time, I would like to do another Forth, this time STC (subroutine-threaded code) which would run faster. Bruce gave a discussion here and here (two posts in the same topic) on how it is considerably more memory-efficient than initially meets the eye.
And one more thing: My fix for the UM* bug that's common in public-domain 6502 Forth is at viewtopic.php?t=689 . The bug rarely shows up, which is why I used it for 15 years without realizing it was there; but an FFT has a ton of multiplies, and it was getting messed up by the bug. I think I mentioned it recently but did not find it in the source-code repository to quickly direct you to the fix.
- It is heavily commented, including plenty of use of the DOS/ANSI [Edit: that should say IBM437] characters that were so good for drawing smooth charts and diagrams. (I know I might have to replace those characters now since few people use DOS anymore.) A documentation file gives a lot of general info about the Forth, reasons for doing various things certain ways, some philosophy, etc..
- has the more-readable Forth equivalent code corresponding to the assembler source for each word. This Forth equivalent code is in kind of like shaddow-screen files (although they're text files, not screen files) with .FTH extensions instead of .ASM
- has graphic explanations of parts that tend to be more confusing; for example, what the program-structure words compile, and how DOES works
- various parts are in INCLude files, so for example you may want to omit math extensions or mostly replace the 816HDWR.ASM file with your own since your hardware may be quite different from mine, for example, an entirely different keypad/keyboard or display
The FIG site:
http://www.forth.org
links to the Taygeta archive:
ftp://ftp.taygeta.com/pub/Forth
which has a ton of interesting stuff, but it can be hard to find things. IMO, it's worth spending some time looking through it, though.
The FIG-Forth Installation Manual is here:
ftp://ftp.taygeta.com/pub/Forth/Archive ... IGINST.ZIP
The FIG-Forth 6502 assembler is here:
ftp://ftp.taygeta.com/pub/Forth/Archive ... sm6502.txt
which can be used to write CODE words (i.e. primitives). It appears to be OCR'd since the letter O appears in several places where the number zero should be, and a lowercase L appears where the number one should be. I made some fixes to a copy of this file, but have not tested those fixes.
Also of interest is this FIG-Forth implementation for the 8086, not so much the 8086 assembly source code, but specifically the block file FORTH.SCR (.lzh is an old compression/archive format, like .zip):
ftp://ftp.taygeta.com/pub/Forth/Archive/ibm/fig86.lzh
Although it looks almost like a text file, it actually consists of 64 character * 16 line blocks (and hence its length is a multiple of 1024); there are no CRLF line terminators, so your favorite text editor may barf on it. In DOS/Windows EDIT /64 FORTH.SCR does the trick. I found it helpful to turn it into a real text file containing CRLFs (I probably used awk or perl or somesuch for this, I don't really remember).
To be clear, I should point out that any old STC implementation is not necessarily more space efficient than you'd think, but it's possible to create an implementation that is, without sacrificing too much of the speed advantages of STC.
0branch: PRIMITIVE
INX2
LDA FFFE,X
BEQ branch+2
