65c816 cross compiler suggestions?
Tancor
Post by Tancor »
Hi all,
I know that many / most are using 6502 processors, but I've noticed a bit of a surging of using the 65816 processor, and I was hoping to find out what others are using for assemblers/compilers for their designs?
-T
-Tony
KG4WFX
For assembly, I use Cross-32 (C32 for short) macro assembler from Universal Cross-Assemblers. When you get the assembler for around $200, you get all the files to assemble for about 50 processors, plus the info to make your own tables for any other processor not yet invented (or even your own). IOW, you may never need to buy another assembler.
For Forth, I use my own home-written Forth.
jdeboy
Post by jdeboy »
I'm using the AS-Assembler by Alfred Arnold. It supports many processors (including the 65816) and is freeware. You can find links at:
http://john.ccac.rwth-aachen.de:8000/alf/
TMorita
Re: 65c816 cross compiler suggestions?
Post by TMorita »
Tancor wrote:
Hi all,
-T
My 65816 port of LCC is now in the downloads section.
Toshi
