Women never were very good at interior decorating. I can just hear my wife again: "What is that thing in the living room? Can we get rid of it?"
How to Start hardware of 2864 EEPROM Self made circuit...??
- GARTHWILSON
- Forum Moderator
The most tedious part was hand-converting the program to the bit patterns that had to be set via the switches. Talk about a mistake-prone task...
When I got married, my wife didn't like my dining room furniture and insisted we replace it.
Hello,
After spending so much time I came to know there is some contacting problem arsing between these push buttons.....
when i pull them up the counters move in up ward address, while pushing down they don't count.
i have checked my circuit there is no problem in it, but there is some problem in this white and blue switches, please fig. this out what's that problem....!!
- GARTHWILSON
- Forum Moderator
Ritesh, the forum these pictures are on does not allow access to non-members, so we can't see them.
Edit: You had three empty posts after this, so I deleted them. They had no text or images—totally empty.
- GARTHWILSON
- Forum Moderator
- GARTHWILSON
- Forum Moderator
- BigDumbDinosaur
Not an 8085 Forum!
RITESH wrote:
and you have any idea of 8085 SBC hardware??
- GARTHWILSON
- Forum Moderator
Without my seeing your whole diagram, one possible cause of trouble that comes to mind is that you're using double-pole switches. These definitely will not make contact on the two poles at the same time, and even if they did, there will be bounce (I think you only took care of the bounce problem on one side) and the setup-time requirements on the counters' up/down inputs may not be satisfied. I'm not sure we can spot the problem and give you relevant help without seeing the whole diagram.
I never got into the 8085. The 6502 attracts me for its simple bus structure and the fact that its interrupt performance is much, much better.
Nightmaretony
- In Memoriam
