Buying a 65816 system
For someone who wants to program, and not to solder, as far as I can tell, there's only one way to buy a new 65816-based system - the educational kits from apatco:
There is a $200 kit available:
http://www.apatco.com/shop/index.php?productID=674
Also available assembled, but even more pricey at $300:
http://www.apatco.com/shop/index.php?productID=685
It is also possible to buy 65816 chips, and several people have done their own systems designs, and done small upgrade boards for 6502-based systems. But I don't believe any of those are for sale.
John Kortink sells a BBC second processor board with a 65816 option, but only as an upgrade (it needs the Tube chip from an original "cheese wedge")
The only other approaches I can think of to get a physical 65816 system to program on, without soldering, are to buy a secondhand apple ii gs or a SNES. The SNES is probably fairly easy to get hold of, but would need further equipment to develop for.
Have I missed any small-scale sellers of built systems?
For EUR80 or $120 you can buy a development system for the SNES cartridge port:
https://www.assembla.com/wiki/show/quickdev16#order
- BigDumbDinosaur
I have much less invested in POC V1 if you don't count the dumb serial terminal I use for I/O (could easily be a PC). Not sure, though, how useful POC V1 would be to someone getting their feet wet with the '816.
Re: Buying a 65816 system
I see there's an LCD, which is nice... [128x64 pixel]
On the other hand, if you allow for inflation then their assembled unit is about half what I paid for my KIM-1. And a 65c816 is "slightly" preferable to a 1 MHz NMOS 6502!
Re: specifications, I emailed Apatco and got a prompt reply.
Hi Jeff,
Thanks for the interest! Yes, there is a link off of our main website for the datasheet.
http://www.apatco.com/downloads/eb50_datasheet_v1.4.pdf
The kit comes with both a 2Mhz and a 6Mhz crystal.
Let me know if you have any other questions.....
Gord Clink
APATCO Technologies
http://www.apatco.com <http://www.apatco.com/>
Gord Clink
APATCO Technologies
- BigDumbDinosaur
- BigDumbDinosaur
8BIT wrote:
I will be offering a bulk buy for my SBC-4 later this year.
At least we know Daryl's stuff will perform.
By email they informed me, "FYI, the 20Mhz operation can be done by disabling the glue logic and creating your own." Sounds kind of extreme, to me. Would anyone actually do that? Even if you did, you'd probably also need faster memory & IO chips (or else Wait-State circuitry).
Personally I think a better plan would be to simply upgrade the existing glue logic with 74AC series or something similar. Limit the mods to adding a few series termination resistors on the strobe lines maybe. And settle for whatever speedup you can get, without expending a lot of effort.
The kit ships with both a 2Mhz and a 6Mhz crystal. I bet the boards perform just fine at such speeds -- and can probably be made to go even faster. But the 20 MHz figure seem awfully optimistic. I wonder if they have a demo system to back up the claim.
The NCS 2056T, because of the 74LS logic gates used in the clock circuit is limited to about 8Mhz.... The series gate oscillator was chosen for learning purposes
Just to clarify. The NCS EB50 was designed to be as flexable as possible as a base system to develop in an educational environment. It was also designed as an upgrade path to the NCS 2056T breadboard computer system. Because the 2056T uses the 74 series logic, the EB50 by default uses this logic as well. The current configuration limit, which is actaully the EEPROM which is 150ns, limits it's operation to 6.66Mhz hence the 6Mhz cyrstal that it comes with.
As some users may want to experiment with a faster system, the board has jumpers (JP1, JP2) which will reroute the CE signals for RAM, ROM chips to the J1 50 pin memory bus connector. As well, the JP3, JP4, & JP5 will reroute the U2, U3, and U7 to the J1 50 pin connector as well. This allows you to develop your own logic, maybe with CPLD or what ever.
The board runs extremely well, and was designed with simplicity in mind. The skies the limit for experimenting with the EB50.
It also will use the ViaUSB adapter from WDC and allows programming with the TIDE programming environment.
http://www.apatco.com/shop/index.php?productID=699
If you have any other questions or concerns, don't hesitate to contact us.
APATCO Technologies
APATCO Technologies
- GARTHWILSON
- Forum Moderator
- GARTHWILSON
- Forum Moderator
1/(6MHz) is 167ns per cycle. With setup times, that's still not enough time for a 150ns EEPROM unless the parts are significantly faster than they are specified to be. If you want reliability, 150ns is definitely not fast enough for a 6MHz system. It may work now, just by luck, and then a customer who operates it in a hotter environment and has a slightly lower power supply voltage (but still within spec) will have it not work and may not know why.
You're counting on the processor putting the next address out on the address bus the instant the phase 2 clock falls, and that is simply not the case. There is some processing that has to take place before it can get the address out there. You're also counting on the processor being able to wait for the next fall of the phase-2 clock to read the data; but it cannot wait that long. It needs it before that. That's what the setup times are about. Then if you have address-decoding logic that adds further delays that cut down the amount of time that the EEPROM can be allowed to have. That's why the timing diagrams are in the data sheet.
