I saw that as well Garth. With a dual-core Intel cpu. The all in one package is sorta cool, where you just need to plug into a video device, but so many details left out. Is it a Nehalem Intel cpu where they don't need the north bridge? Where are the spec's?
They could use it as a tool to teach the fundamentals of dual/quad core Intel CPU's. Including assemblers, and such.
Maybe they are? Not enough info... But this is why the C-64 was a favorite. It was open to the public, including schematics and all.
But $600 is too much for me.
Commodore returns...
ElEctric_EyE
BTW: They didn't even bother to add connectors for the old 9-pin standard joysticks (at least I couldn't find any info on this), so this really is just a low-end PC in a fancy case...
IMHO this thing is way overpriced. If you look at http://www.commodoreusa.net/CUSA_C64Select.aspx, the $600 version neither has WIFI nor a DVD drive. You can buy a netbook (or nettop) with similar specs for far less money...
so long,
Hias
ElEctric_EyE
ElEctric_EyE wrote:
Their custom OS sounds interesting...
From their current FAQ http://www.commodoreusa.net/CUSA_FAQ.aspx:
10. What is Commodore OS?
Our new Commodore operating system, will be a unique Commodore and AMIGA centric Linux distribution, that will grow over time into something far greater.
Problem with all these derivatives is that most of them didn't catch up with the changes of their base. If Debian or Ubuntu releases a new version, the derviative also have to do this - and as history has shown us a lot of them failed and then vanished over time.
Creating your own Debian/Ubuntu/... based distribution is quite easy, but maintaining it over time means a lot of work.
So, at the end you might be better off installing the original (i.e.: the base distribution) and just add the additional software. In Debian/Ubuntu this is just an "apt-get install vice uae" at the command line. While you're at it you can also "apt-get install atari800 xmame-sdl xmess-sdl spectemu-x11" and get even more emulated systems on your Linux box :-)
so long,
Hias
