It is currently Sun Nov 24, 2024 10:49 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jan 26, 2011 6:36 pm
Glad you fixed it - I was wondering if I'd try to run two simulators and compare traces. Bruce has written a good tutorial about the V flag.
PostPosted: Sat Jan 29, 2011 11:55 am
Sorry for the bad news, but the emulator is still buggy.
This time I tried the Apple 1 assembler from http://www.sbprojects.com/projects/apple1/a1asm.htm and it hangs after the "AUTO" command.
Because I wasn't sure if the assembler was OK I wrote another A1 emulator using the 6502 core of Marat Fayzullin (from "mame" code) and tested the assembler. It ran without problems. So, I guess there are still some bugs around in your emulator.
My emulator can be downloaded from here: http://www.ele.uva.es/~jesus/6502/a1.tgz
It is not very accurate regarding the Apple I, but the 6502 emulation code is well tested. You can merge this code with your CPU emulator and compare results in order to hunt for bugs...
PostPosted: Sun Jan 30, 2011 11:02 pm
I got the time to do the emulator comparison myself, but it was harder than I though. I found the error while executing a RTS instruction:
$9132 rts          A =  $8D  $00|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$9133 lda  #$AE    X =  $04  $10|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$9135 bne  $913D   Y =  $00  $20|00 00 00 00 00 90 00 90.00 90 00 00 00 00 00 00
$9137 lda  #$A0    S =$1.FB  $30|00 00 00 00 00 00 00 00.00 00 00 00 00 00 C1 D5
$9139 bne  $913D   PC=$9132  $40|D4 CF 8D 00 00 00 00 00.00 00 00 00 00 00 00 00
$913B lda  #$8D              $50|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$913D jmp  $FFEF   .V_...ZC  $60|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$9140 pha                    $70|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$9141 lda  #$A4    - stack-  $80|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$9143 jsr  $FFEF   $00 $00   $90|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$9146 pla          $00 $00   $A0|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$9147 jsr  $FFDC   $00 $00   $B0|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$914A tya          $00 $00   $C0|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$914B jmp  $FFDC   $00 $00   $D0|00 00 00 00 C1 00 00 00.00 00 00 00 00 00 00 00
$914E cld          $90 $80   $E0|00 00 00 00 00 00 00 00.00 00 00 00 00 00 00 00
$914F ldy  #$00    $94 $A6   $F0|E8 03 0A 00 00 00 92 91.00 00 00 00 00 06 00 10
Breakp: 9132    Clocks: 6280468
[Command,'?']-> e
Error
Before
    PC=9132 A=8D X=04 Y=00 S=FB P=63
Op-Code: 60
After: correct
    PC=94A7 A=8D X=04 Y=00 S=FD P=63
After: bad
    PC=A695 A=8D X=04 Y=00 S=FD P=63
The return address is bad, but this was the second time this RTS was executed, the first time it was OK. I'm just comparing the registers of the emulated CPUs and, therefore, errors related to stack can have passed unnoticed. I guess the problem is the way 16-bit addresses are pushed into/pulled from the stack. I think you are pushing the LSB first, and a real 6502 will push the MSB first. As long as the RTS returns from an address pushed by a JSR instruction the PC is OK, but the assembler could have pushed a return address using PHA instructions and then executed an RTS.
I hope this can help to solve the bugs of the emulator. I like it because of its compactness...
PostPosted: Mon Jan 31, 2011 9:37 pm
jesari wrote:
... but the assembler could have pushed a return address using PHA instructions and then executed an RTS.
That's exactly what the assembler is doing:
        LDA     .JUMPS+1,Y
        PHA
        LDA     .JUMPS,Y
        PHA
        RTS
.JUMPS  .DA     DIR_AS-1
        .DA     DIR_AT-1
... And I found another bug. This time regarding the Carry flag and SBC.
PostPosted: Tue Feb 01, 2011 7:26 am
I think I fixed JSR/RTS, and SBC is probably still broken but in a different way ;)
PostPosted: Wed Feb 02, 2011 8:35 am
I collected some links to various 6502 test suites on the visual6502 wiki.
Edit: oops, I see I already linked to that in this very thread. Sorry for the useless repetition!
PostPosted: Wed Feb 02, 2011 11:10 pm
After trying to understand how the BCD really works on the 6502 I decided to make truth tables for the ADC and SBC instructions using a real 6502 (NMOS version). The tables can be downloaded from here:
http://www.ele.uva.es/~jesus/6502/bcd.zip
These tables include all the possible input values (2^17 cases, not only the valid BCD ones) and the resulting N,V,Z and C flags. This information can be useful for accurate emulator development.
On a NMOS 6502 the N,V and Z flags doesn't make much sense in BCD mode, but they behave in a deterministic way. Things can be different on a 65C02 or 65816, but, unfortunately I only got NMOS chips. The source code of the tests is included in the ZIP file.
The only emulator I tested versus the real chip was that of Marat Fayzullin. The resulting value in accumulator for ADC was OK, but only the C flag was changed.
PostPosted: Thu Feb 03, 2011 8:33 am
Thanks for the zip file.
Mike's py65 has 100% accurate BCD emulation (of the NMOS 6502), and Bruce's documents are 100% accurate too.
I think few emulators are completely accurate in this respect - and if they wish to be, they need to be decisive and explicit as to chip they accurately emulate! They might choose to be accurate only with respect to the manufacturer spec, in which case they may not get all flags right in all cases. As you say, these things are deterministic, for each chip design.
PostPosted: Thu Feb 03, 2011 10:31 pm
Hi, Happycube.
I fixed the ADC/SBC routines. See the code attached. I tested them against the values of a real 6502 and they are OK. I don't like the use of 16-bit arithmetic but that was the only way I found to get the carry flag correct. In decimal mode only the carry was tested OK (N,V and Z doesn't match the real ones, but they are junk anyway) and the accumulator does not match the real 6502 for non BCD values. Even with these flaws I think the routines are good enough for the emulation of all practical codes.
inline u8 do_adc(u8 reg, int n)
   if (flags & F_BCD) {
      u8 p1 = ((flags & F_CARRY) != 0) + (reg & 0x0f) + (n & 0x0f);
      u8 p2 = (p1 >= 10) + (reg >> 4) + (n >> 4);
      flags &= ~(F_CARRY);
      if (p1 >= 10) p1 -= 10;
      if (p2 >= 10) {flags |= F_CARRY; p2 -= 10;}
      return (p2 << 4) + p1;
   } else {
      u16 tmp=reg+n;
      if (flags & F_CARRY) tmp++;
      if (tmp&0x100) flags |= F_CARRY; else flags &= ~F_CARRY;
      tmp&=0xff;
      if ( !((reg^n)&0x80) && ((reg^tmp)&0x80) )
         flags |= F_OVF; else flags &= ~(F_OVF);
      return tmp;
inline u8 do_sbc(u8 reg, int n)
      int nd = ((n >> 4) * 10) + (n & 0x0f);
      if (!(flags & F_CARRY)) nd++;
      int val = ((reg >> 4) * 10) + (reg & 0x0f) - nd;
      flags |= F_CARRY;
      if (val < 0) {flags &= ~F_CARRY; val += 100;}
      return ((val / 10) << 4) + (val % 10);
   } else {
      u16 tmp=reg+(n^0xff);
      tmp&=0xff;
      if ( ((reg^n)&0x80) && ((reg^tmp)&0x80) )
      return tmp;
PostPosted: Fri Feb 04, 2011 1:38 am
Hi Jesari
I've linkified my previous post: py65's code is BSD-licensed so you're relatively free to take from that. All the other emulators which get BCD mode right are GPL licensed, so you can only take their code into a GPL project.
I liked the ascii screenshot you gave in your emulator comparison post - so I looked a bit deeper, and I see it's from Marat Fayzullin's M6502 emulator library - looks like a great resource which has been mentioned a couple of times on this forum but isn't in the list of emulators on this site. I see that usotsuki announced a 65c02 version - all the above carrying a non-commercial-use license and therefore not suitable for GPL projects.
PostPosted: Sat Feb 05, 2011 8:27 pm
Jesari - thanks! I checked it in with attribution.
cron
