Wanted: An 65816 Assembler
As I understand it, individual Transputers are just a typical Von Neumann stack machines with instructions for serial I/O. The only oddity I can think of for them is how they construct immediate literals. However, anything beyond 8 literal instructions in a row should overflow a 32-bit Transputer's capacity to hold the number. That should set some kind of limit on code size.
yes, but you can imagine even passes bumping up the length by one byte, and odd passes bumping it back down again, such that neither pass is self-consistent and the process can't converge.
(in fact, the machine code is somewhat word-width neutral - same coding for the earlier 16-bit and the later 32-bit models. Each byte in the instruction stream is a pair of nibbles, which constructs the actual opcode in a word-sized buffer. You could, I think, have an instruction stream which constructs a 128-bit constant using lots of PFIX nibbles, and that would be valid (accepted) on any machine, although the machine would doubtless truncate the constant. See http://en.wikipedia.org/wiki/Transputer#Instruction_set)
- BitWise
- In Memoriam
Unfortunately, I have never encountered a triple pass assembler able to resolve forward references in that fashion.
Andrew Jacobs
