Hello all... I've got yet another question for ya'll. Most computers (Pentium class and up) that I have access to use Flashable type memory chips as the bios. Can this be used in a 6502 computer? And if so, what is the upper limit (ie., max amount of memory)? Can I use a 1MB chip? Could I use one with more memory? Any info/help would be appreiciated.
Thanks.
Lyos Gemini Norezel
Bios Chips
Re: Bios Chips
Yes
Any size is fine, but since the 6502 only has a 16 bit address bus you'll never be able to see more than 64k at a time - so a 1MB part would require paging or some such other scheme.
All standard stuff - web searches and basic electronics books will cover these topics,
Sprow.
Yes
Sprow.
Lyos Gemini Norezel
Thanks.
Lyos Norezel
Mundus Vult Decipi et Decipiatur
It seems simple enough. Set it up so you can write to the inputs of some 74xx chip as a register, and have it's output control the higher address lines of the memory.
For every extra address line added, you double the memory available. This was done very often on NES game cartridges, using standard or custom parts.
http://nesdev.icequake.net/rom.txt
But the CPU can only access the 'page' that's currently switched in. That's easy to deal with, just keep the code/data that's used together in the same page.
