* PROOF-OF-CONCEPT V2 LOGIC *
* Copyright (C)2010 by BCS Technology Limited. All rights reserved. *
* VERSION HISTORY *
Ver Rev Date Revision
01 2010/11/04 Original version.
02 2010/12/06 Changed device, added wait-state features & memory banking, &
removed PHI2 generation.
Name mpu_logic;
PartNo B011040001;
Date 11/04/2010;
Revision 02;
Designer BigDumbDinosaur;
Company BCS Technology Limited;
Assembly POC V2;
Location Ux;
Device v2500clcc;
* INPUT DECLARATIONS *
pin 42 = !EWS; /* add a wait-state if low */
pin 1 = PHI2; /* MPU clock */
pin 19 = RESET; /* system reset if low */
pin 44 = RWB; /* MPU read/write signal */
pin 2 = VDA; /* MPU valid data address signal */
pin 3 = VPA; /* MPU valid program address signal */
/* MPU address lines... */
pin 25 = A8;
pin 24 = A9;
pin 43 = A10;
pin 41 = A11;
pin 23 = A12;
pin 22 = A13;
pin 20 = A14;
pin 21 = A15;
/* MPU data lines... */
pin 6 = D0;
pin 5 = D1;
pin 8 = D2;
pin 16 = D6;
pin 17 = D7;
* OUTPUT DECLARATIONS *
pin 35 = !EPCE; /* EPROM chip select */
pin 36 = !SRCE; /* SRAM chip select */
pin 38 = !RD; /* inverted read data */
pin 40 = !RDY; /* MPU wait-state */
pin 18 = RST; /* active high reset */
pin 37 = !WD; /* write data gated by PHI2 */
/* RAM bank selection... */
pin 15 = A16;
pin 14 = A17;
pin 13 = A18;
/* I/O device selection... */
pin 29 = !IO0; /* I/O device chip select */
pin 30 = !IO1; /* I/O device chip select */
pin 31 = !IO2; /* I/O device chip select */
pin 32 = !IO3; /* I/O device chip select */
* HARDWARE NODES *
pin 7 = wd; /* write data node */
pin 9 = romsel; /* ROM selection */
pin 10 = ramsel; /* RAM selection */
pin 27 = romhi; /* HIROM selection */
pin 28 = romlo; /* LOROM selection */
* FIELD DECLARATIONS *
field ADR = [A15,A14,A13,A12]; /* RAM/ROM address range bits */
field IOB = [A11,A10,A9,A8]; /* I/O addresses */
field DAB = [D7,D6,D2,D1,D0]; /* significant part of data bus */
* BURIED LOGIC *
node d0ff; /* D0 state flip-flop */
node d1ff; /* D1 state flip-flop */
node d2ff; /* D2 state flip-flop */
node d6ff; /* D6 state flip-flop */
node d7ff; /* D7 state flip-flop */
node memmap; /* memory mapping */
node ws; /* wait-state enable */
node wsff1; /* wait-state flip-flop */
node wsff2; /* wait-state flip-flop */
node wsff3; /* wait-state flip-flop */
* INTIALIZATION *
d0ff.ar = !RESET;
d1ff.ar = !RESET;
d2ff.ar = !RESET;
d6ff.ar = !RESET;
d7ff.ar = !RESET;
wsff1.ar = !RESET;
wsff2.ar = !RESET;
wsff3.ar = !RESET;
d0ff.sp = 'b'0;
d1ff.sp = 'b'0;
d2ff.sp = 'b'0;
d6ff.sp = 'b'0;
d7ff.sp = 'b'0;
wsff1.sp = 'b'0;
wsff2.sp = 'b'0;
wsff3.sp = 'b'0;
* CONTROL SIGNALS LOGIC *
RST = !RESET; /* active high reset */
vbus = VDA # VPA; /* true if address bus is valid */
* ADDRESSING LOGIC *
Memory Map Rules:
Address MMU RWB Hardware Symbol
$bb0000-$bbBFFF xx000bbb x banked RAM
$00C000-$00CFFF x000xxxx x common RAM LORAM
x100xxxx H ROM (4K) LOROM
x100xxxx L common RAM LORAM
$00D000-$00DEFF xx00xxxx x I/O IOBLK
$00DF00 xx00xxxx x MMU mmu
$00E000-$00FFFF 0x00xxxx H ROM (8K) HIROM
0x00xxxx L common RAM HIRAM
1x00xxxx x common RAM HIRAM
loram = A15 & A14 & !A13 & !A12; /* RAM at $00C000 */
lorom = A15 & A14 & !A13 & !A12; /* ROM at $00C000 */
dxxx = A15 & A14 & !A13 & A12; /* $00D000 ... */
ioblk = dxxx & !A11; /* I/O at $00D000 */
mmu = dxxx & A11 & A10 & A9 & A8; /* memory mapping at $DF00 */
hiram = A15 & A14 & A13; /* RAM at $00E000 */
hirom = A15 & A14 & A13; /* ROM at $00E000 */
memmap = mmu & !RWB & vbus; /* 1 = configuring memory map */
d7ff.ck = memmap & PHI2;
d6ff.ck = memmap & PHI2;
d2ff.ck = memmap & PHI2;
d1ff.ck = memmap & PHI2;
d0ff.ck = memmap & PHI2;
d7ff.d = D7 & memmap;
d6ff.d = D6 & memmap;
d2ff.d = D2 & memmap;
d1ff.d = D1 & memmap;
d0ff.d = D0 & memmap;
vbank = !loram & !hiram & vbus;
A18 = d2ff & vbank;
A17 = d1ff & vbank;
A16 = d0ff & vbank;
* ROM SELECTION LOGIC *
romhi = hirom & !d7ff & RWB; /* high ROM enabled on read */
romlo = lorom & d6ff & RWB; /* low ROM enabled on read */
EPCE = (romhi # romlo) & vbus; /* ROM chip enable */
* RAM SELECTION LOGIC *
ramhi = (hiram & d7ff) #
(hiram & !RWB);
ramlo = (loram & !d6ff) #
(loram & !RWB);
SRCE = (ramhi # ramlo) & vbus; /* RAM chip enable */
* I/O SELECTION LOGIC *
iosel = ioblk & vbus; /* true if I/O device selected */
IO0 = iosel & !A10 & !A9 & !A8; /* I/O device 0 */
IO1 = iosel & !A10 & !A9 & A8; /* I/O device 1 */
IO2 = iosel & !A10 & A9 & !A8; /* I/O device 2 */
IO3 = iosel & !A10 & A9 & A8; /* I/O device 3 */
* WAIT-STATE LOGIC *
ws = EPCE # iosel; /* wait-state ROM or I/O access */
wsff1.ck = PHI2 & ws; /* enable flop clock for wait-state */
wsff1.d = (!wsff3 & EWS) # (!wsff2 & !EWS);
wsff2.d = wsff1;
wsff3.d = wsff2;
RDY.oe = ws; /* tri-state RDY when not active */
RDY = ws & (wsff1 $ ((wsff3 & EWS) #
(wsff2 & !EWS))); /* assert RDY if wait-stating */
* READ/WRITE LOGIC *
RD = (RWB # (RWB & RDY)) & vbus; /* read data operation */
wd = !RWB & !mmu; /* ignore RWB if accessing MMU */
WD = ((wd & PHI2) # (wd & RDY))
& vbus; /* write data operation */When an attempt is made to simulate the above, WinSim croaks with a run-time error 457, which is a key indexing error that is emitted by Microsoft Visual Basic (now we know what Atmel's developers use
After having puzzled over this one for quite a while, as well getting Daryl Rictor (8Bit) to try it out, we both reached the same conclusion and I queried Atmel on it. Here's Atmel's reply:
- The WinSim issue seems to be caused by the use of “wd” and “WD” in the CUPL design file. I tried changing “WD” to “WD_t” and that fixed the WinSim problem.
Hope this will help you solve the problem. Please feel free to contact us at pld@atmel.com if you have any Atmel PLD related inquiries.
Best regards,
Alan Wong
CSP Applications Manager / Atmel Corporation
Tel: (+1) (408) 436-4156 / Fax: (+1) (408) 487-2538
