It is currently Thu May 23, 2024 3:36 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Oct 19, 2010 3:27 pm
HI
Guys , Murphy’s law happened to me . I have Loose everything … everything I have done is wasted , all my vhdl codes are a history . hard drive is death !!. so what now ? … I have some new ideas , first is to increase a screen resolution in text mode, maybe 64x30 will be good ? I don’t won’t do make my system to work with full graphic mode , because Cpu is to slow. Semi graphic is the best way I thing . My system is not a commercial project , after I will finish it the schematic and sources will be available on the internet . So please guys , help me to make the right decision .
Greetings.
PostPosted: Wed Oct 20, 2010 11:21 am
Damn, sorry to hear of your loss.
Not a total loss though, it's still in your head & you still have the hardware, and I'm sure you learned alot!
HDD failures happen often. One of mine is starting to go, I can hear it click (the head driver fails as if it were shutting off) once in a rare moon. Currently, I use an 8GB USB stick to back up whenever I make progress. No moving parts like HDDs, so they're less susceptible to failure. Then also to be more secure, burn your projects to CD/DVD. Even more secure than that?: make RAR's, then make PAR's (parity error correction). CD/DVD's are not as reliable as one would like to think!
I wouldn't be so discouraged about graphics, especially since you know how to use FPGA's. Look at fpga4fun for more insight. An FPGA is used as the controller for an LCD display 480x320 no colors, and holds all of the font data for characters as well.
http://www.fpga4fun.com/GraphicLCDpanel.html
Never quit! :|
PostPosted: Fri Oct 29, 2010 2:44 am
bound, any luck?
What are your thoughts?
PostPosted: Fri Oct 29, 2010 7:33 am
Hi , not really .
I just got a GU256x64 display from ebay for few us dollars and now I'm working on simple 6502 sbc . After that I will back to my 65816 sbc...
Thanks for asking .
