Now that I've supercharged myself with caffeine and can more-or-less think straight, a couple of design notes:
1) Unused inputs on the MPU should not be allowed to float, as doing so makes them susceptible to noise, possibly causing strange effects that will drive you nuts. You should tie these signals to Vcc with pullups—3.3K is a good value, preferably by using SIPs, not discrete resistors. Keep the physical path between the SIPs and MPU as short as possible.
2) I said this elsewhere, but all glue logic should be (in order of preference) 74ABT, 74F or 74AC. I recommend you use a 74F138 for IC10 and IC12. Also, use a 74ABT573 at IC5. The latter has approximately 30 percent of Ø2 low in which to react to and latch the bank address. You need all the speed you can get, since that setup time is additive to the setup time on the SRAM and the prop time of the chip select logic.
3) I don't see any connections to the "G" inputs on IC12. How do you intend to have the '138 assert /Y7 when the ROM is supposed to be mapped in?
4) I believe you can eliminate IC7C by changing the manner in which you are gating IC10. The '138 is relatively slow (lots of internal gates) and adding an inverter to one of IC10's inputs adds yet more prop time to a circuit who expeditious operation is essential to being able to ramp up the clock rate.
5) You are not qualifying RWB with Ø2, which opens the door to random data corruption in SRAM due to inadvertent timing violations. D0-D7 are valid only when Ø2 is high. Otherwise, D0-D7 are either undefined (early part of Ø2 low) or hold the bank address (latter part of Ø2 low). Therefore, the /WE inputs on the SRAM should never be asserted while Ø2 is low. Carefully peruse the '816 timing diagram so this relationship is clear.
6) Is has long been customary in digital electronics notation to refer to the positive side of the power supply as Vcc and the negative side as Gnd (ground). This was an old military standard that was intended to be unambiguous. Notation such as Vss and Vdd are confusing to most of us old dinosaurs. Which one is positive?
