pi = 3 + 4/((n)*(++n)*(++n)) - 4/((n)*(++n)*(++n)) + ...
Tl;Dr After 366 iterations my program generated that Pi equals the ratio 1,686,629,694 / 536,870,912 which equals 3.14159262. This is smaller than Pi by ~0.0000000338. More information and raw output below:
READY
>S .0001.0002.0003.0004.0005.0006.0007.0008.0009.0010.0011.0012.0013.0014.0015.0016.0017.0018.0019.0020.0021.0022.0023.0024.0025.0026.0027.0028.0029.0030.0031.0032.0033.0034.0035
READY
>j
Enter Address BB:AAAA 00:0300
Pi = 6487ED3E / 20000000
N = 0000016E
Here's the cut and pasted code for people who don't want to follow the link.
; Calculate pi using the Nilakantha infinite series. While more complicated
; than the Leibniz formula, it is fairly easy to understand, and converges
; on pi much more quickly.
; The formula takes three and alternately adds and subtracts fractions with
; a numerator of 4 and denominator that is the product of three consecutive
; integers. So each subsequent fraction begins its set of integers with the
; highest value used in the previous fraction.
; Described in C syntax n starts at 2 and iterates to the desired precision.
; pi = 3 + 4/((n)*(++n)*(++n)) - 4/((n)*(++n)*(++n)) + ...
; Here's a three iteration example with an error slightly more than 0.0007.
; pi = 3 + 4/(2*3*4) - 4/(4*5*6)
; + 4/(6*7*8) - 4/(8*9*10)
; + 4/(10*11*12) - 4/(12*13*14)
; = 3.14088134088
.include "ascii.inc"
.include "common.inc"
.include "math32.inc"
.include "print.inc"
; Normally this requires floating point arithmetic, but we're using fixed point
; unsigned arithmetic with 3 integer bits, and 29 fractional bits.
; Aliases
THREE = %0110000000000000
FOUR = %1000000000000000
RESCALE = %0010000000000000
CELL = 4
DS_SIZE = CELL * 10
.proc pi
ON16MEM
ON16X
printcr ; start output on a newline
phd ; save direct page register
tsc ; get current stack pointer.
sec
sbc #DS_SIZE ; reserve data stack workspace
tcs
tcd ; direct page now points to stack
ldx #DS_SIZE ; point X to data stack top
lda #THREE ; initialize the sum on the data stack
ldy #0000
jsr _pushay
@while: jsr calc_term
lda #00
ldy #00
jsr _pushay
jsr _stest32
beq @done
jsr _popay ; pop unused zero
jsr _add32 ; add term to the sum
bra @while
@done: jsr _popay ; remove the two unneeded zeros
jsr _popay
print msg1
jsr _popay ; pop the results
printc
tya
printc
print msg2
lda #RESCALE
printc
lda #0000
printc
printcr
print msg3
lda N+2
printc
lda N
printc
printcr
@cleanup:
tsc ; clean up stack locals
clc
adc #DS_SIZE
tcs
pld ; restore direct page pointer
rtl
.endproc
msg1: .asciiz "Pi = 0x"
msg2: .asciiz " / 0x"
msg3: .asciiz "N = 0x"
N: .word 2, 0
; calc_term: calculates Qn - Qn+1
; Inputs:
; X - data stack index
; Outputs:
; C - clobbered
; X - data stack index updated with Qn - Qn+1 on data stack
; Y - clobbered
.proc calc_term
jsr quotient
jsr quotient
jsr _sub32
rts
.endproc
; quotient: calculates a single scaled quotient term
; Inputs:
; Outputs:
; C - clobbered
; X - data stack index updated with quotient on data stack
; Y - clobbered
.proc quotient
ldy #00 ; numerator of fixed point four
lda #FOUR
jsr _pushay
ldy #00 ; scratch space for routine.
lda #00 ; ditto
jsr _pushay
jsr denominator ; calculate N*++N*++N
jsr _udivmod32
jsr _swap
jsr _popay ; discard remainder
rts
.endproc
; denominator: calculates (n)*(++n)*(++n)
; Inputs:
; memory N
; Outputs:
; C - clobbered
; X - data stack index updated with product on data stack
; Y - clobbered
.proc denominator
ldy N
lda N+2
jsr _pushay ; push N
inclong N
ldy N
lda N+2
jsr _pushay ; push ++N
jsr _umult32 ; ++n * n
jsr _popay ; discard unused 32 bits of 64 bit result
inclong N
ldy N
lda N+2 ; push ++N
jsr _pushay
jsr _umult32 ; ++n * first product
rts
.endproc
