uint32_t comparison
barnacle
uint32_t comparison
Post by barnacle »
I'm trying to compare two 4-byte words: one at a fixed location (lba) and one at a variable location pointed to by [Y:A]. All I need to know is whether one is greater than the other; equality is nice to have since I can delete another routine. Both variables are unsigned values.
The need to increment and test Y demolishes any previously calculated flags, which is a shame, but I think this ought to work (I may have the C flag upside down). There's a lot of flags being pushed and pulled...
; u32_cmp
; compare four-byte words in lba and [Y:A]
; returns the carry set if [Y:A] < lba
u32_cmp:
	sta u32_ptr
	sty u32_ptr+1
	ldy #0
	php
u32_c_1:
	plp
	lda lba,y
	cmp (u32_ptr),y
	php
	iny
	cpy #4
	bne u32_c_1
	plp
	rts
Thoughts?
barnacle
Re: uint32_t comparison
Post by barnacle »
Ooops, let's try this; it needs the subtraction for the higher order bytes:
u32_cmp:
	sta u32_ptr
	sty u32_ptr+1
	ldy #0
	lda lba,y
	cmp (u32_ptr),y
	php
u32_c_1:
	iny
	plp
	lda lba,y
	sbc (u32_ptr),y
	php
	cpy #3
	bne u32_c_1
	plp
	rts
leepivonka
Post by leepivonka »
Maybe like:
u32_cmp: ; compare lba with (YA) as uint32, return P.C & P.Z
   sta temp1	; save ptr to arg
   sty temp1+1
   ldy #$ff	; start at most-significant byte
@1: iny		; step to next byte
   cpy #4
   beq @9	; if done, return z=1, c=1
   lda lba,y	; compare
   cmp (temp1),y
   beq @1
@9: rts
barnacle
Post by barnacle »
Ah, thank you; that's a little tidier than mine. I'll have a play.
I'm trying to compare two 4-byte words...There's a lot of flags being pushed and pulled...
No need to to make it complicated.  :D  Something like this might work for you, assuming the “4-byte words” aka “double words” are in little-endian order:
u32_cmp  =*                    ;compare LBA to variable
;	This function compares the current 32-bit LBA to a
;	32-bit variable whose address is pased in .A (LSB) &
;	.Y (MSB).  The LBA & variable are assumed to be in
;	little-endian format.  Returns are as follows:
;	SR ——> c   z   Result
;	       x   1   LBA == variable
;	       0   0   LBA <  variable
;	       1   0   LBA >  variable
;	Invocation example:
;	    lda #<variable
;	    ldy #>variable
;	    jsr u32_cmp
;	    beq isequal
;	    bcc lbalower
;	    bcs lbahigher
         sta u32_ptr           ;variable pointer LSB
         sty u32_ptr+1         ;variable pointer MSB
         ldy #4-1              ;index...
;			We are working MSB to LSB.
u32_c_1  =*                    ;main loop
         lda lba,y
         cmp (u32_ptr),y
         bcc u32_c_2           ;LBA < variable
         bne u32_c_2           ;LBA > variable
         dey
         bpl u_32_c_1          ;keep checking
         iny                   ;LBA == variable
u32_c_2  =*
         rts
Last edited by BigDumbDinosaur on Sat Feb 07, 2026 9:41 am, edited 1 time in total.
barnacle
Post by barnacle »
My assembler makes yours a byte longer than Leepivonka's, BDD, but it's more understandable to me :mrgreen: and I think it might provide more functionality - not sure about that yet.
Thanks, both!
barnacle
Post by barnacle »
And here's the results from BDD's method; just what I need.
NeoDOS32 v0.0276
Free cluster count: 0001E5EC
Next free cluster: 0000007D
Press any key to boot:
Test 32-bit compare
lba is < tmpq1 Z = 0 S = 1 C = 0
lba is = tmpq1 Z = 1 S = 0 C = 1
lba is > tmpq1 Z = 0 S = 0 C = 1
finished test - any key
This means I can replace an existing equality test as well.
Okay for me to use the code in the FAT32 stuff?
teamtempest
Post by teamtempest »
I agree. It took me a second to understand that final INY, but only a second. Very straightforward and quite handy.
NeoDOS32 v0.0276
Test 32-bit compare
What are the S = 1 and S = 0 referring to?
Are you asking for permission to use my routine?  Of course you may.
Having “slept on it,” as well having consumed sufficient quantities of coffee :mrgreen:, I came up with a slightly shorter rendition:
;	SR ——> c   z   Result
;	    lda #<variable
;	    ldy #>variable
;	    jsr u32_cmp
;	    beq isequal
;	    bcc lbalower
;	    bcs lbahigher
         ldy #4-1              ;index...
         lda lba,y
         cmp (u32_ptr),y
         bne u32_c_2           ;LBA != variable
;			If LBA < variable, c = 0, z = 0.
;			If LBA > variable, c = 1, z is don't care.
         dey
u32_c_2  =*
         rts
Bon appetite!
barnacle
Post by barnacle »
The flags tested were zero, sign, and carry. Just included for completeness since it's the inverse of the carry. The canonical name is probably 'N' in 6502 land. :mrgreen:
Thanks for the permission. Credit in the source code!
The new code is interesting, but it's handy to have the equality test as well.
edit: wait, what does the last routine return for equality? Z set?
Yes, canonical for the negative bit in SR is ‘n’.
In a binary comparison context, the state of n is not only irrelevant, it may/could/might/probably-will be treacherous.  In comparisons, c and z are your friends; n is a sNake in the grass :D, since it reflects the internal sign effect caused by the subtraction that CMP, CPX and CPY carry out.  It is possible with certain values to produce a comparison in which carry is clear (register_value < memory_value) and the internal subtraction does not result in a carry into the sign bit.
Yer welcome.
The new code is interesting, but it's handy to have the equality test as well...edit: wait, what does the last routine return for equality?  Z set?
Same results as the previous routine, as described in the comments.
