"PicoSYM"- Synertek Sym-1 Emulator for the Raspberry Pi Pico
andysa
Post by andysa »
The attached ZIP file contains the file "6502emu.uf2" which will allow emulation of a Synertek Sym-1 on a Raspberry Pi Pico 1.
It is based on Jonathans Fouvers "pico-6502 emulator" and "Fake6502".
https://github.com/jfoucher/pico-6502
picoSYM Memory Map
32K RAM (0000 - 7FFF)
Supermon V1.1 (8000 - 87FF)
1541DOS (9000 - 9FFF)
VIA (A000 Block)
System Ram (A600 - A67F)
RAE assembler (B000 - BFFF / E000 - EFFF)
Basic (C000 - DFFF)
Basic Trig functions (F5C0 - F6EE)
PicoSYM emulates a SYM-1 with the Supermon V1.1 Monitor, Basic, RAE Assembler & Editor and 1541DOS at the typical addresses.
The 1541DOS implementation uses "Port A" of an emulated VIA to connect to SD2IEC style floppy disk emulator modules.
It has been tested with reasonable success with both the UIEC-SD and pi1541.
These SD2IEC type modules need to be connected to the RPi Pico GPIO ports via a suitable 3.3v/5v level converter and 7416 open collector inverter.
(Refer SYM-1 1541 DOS manual and connection diagram within the ZIP file)
The 1541DOS relies heavily on the VIA Timers, which required much experimentation with the emulator code in order
to get operational. As such, the reliability has not been fully confirmed, however Loading, Saving of files and directory listings
does appear to be functional and repeatable at this stage.
The only noticeable bug is with the Directory Listing reporting of "Blocks Free", which contains erroneous characters.
This is due to the 1541DOS simplistic decoding of the received IEC filesize data. This worked fine back in the day given the 170KB
storage capacity of a floppy disk.
With the larger capacity of modern SD cards however, the reported free block size is larger than what the 1541DOS routines can accommodate.
Partitioning SD cards to a smaller capacity should get around this problem in the short term, however I am in the process of patching the necessary subroutines in 1541DOS.
Usage
To use the emulator, put the Raspberry Pi Pico in bootloader mode, by holding the 'BootSel' button while
connecting it to a computer.
The RpiPico will appear as a drive. Drop the UF2 file to it.
Open a comms utility such as Putty, at 9600 baud.
picoSYM.zip
PicoSYM SYM-1 Emulator and documentation
(34.59 MiB) Downloaded 64 times
6502inside
Re: "PicoSYM"- Synertek Sym-1 Emulator for the Raspberry Pi
Post by 6502inside »
Nice work!
HansO
Post by HansO »
Awesome!
I flashed a Pico and it is really a SYM-1 via TTY.
A Pico W also works fine.
I do have to test the SYM 1541 DOS
Will add this to my website today!
Great to see the complete 1541 DOS manual in the archive.
I hope that other users of PicoSYM will benefit from the other SYM-1 manuals and information on SYM 1541 DOS on my website.
Thank you for making this.
Hans
