Having become bored with scrolling through several hundred pages of PDF to find information - most frequently, which addressing modes are available, and which flags are affected - I put the information together in a convenient table.
[File corrected: latest version is below]
Opcodes in black are NMOS 6502 original instructions; those in red are later CMOS versions. The flag columns indicate merely that a particular flag _may_ be changed by a given instruction, not the value to which it changes.
Italics indicate the Rockwell bit setting/testing instructions, which in Western Design's 2007 "Programming the 65816 Including the 6502, 65C02, and 65802" are relegated to an appendix on the grounds that they clash with some 65816 instructions. However, they are present in the opcode table in WDC's 2024 W65C02S datasheet.
The Progamming book also indicates that WAI and STP instructions are not included in the 65c02, but again, they are there in the 2024 datasheet.
Please let me know if this is incorrect anywhere. I wanted something to remind me of the new instructions and operating modes on the 65c02 as that's what's currently available!
edit: corrected CLC opcode!
edit: this table corrected further below
Opcode table
Opcode table
6502inside
Re: Opcode table
I'm a little puzzled by how the rmb/smb/etc. instructions in the table should be interpreted.
Otherwise it's very easy to read. Thank you.
Machine room: http://www.floodgap.com/etc/machines.html
- BigDumbDinosaur
Re: Opcode table
Having become bored with scrolling through several hundred pages of PDF to find information...I put the information together in a convenient table...
Also, in your chart, you indicate that PLP and RTI affect all SR flags. That is not quite correct; the b flag and bit 5 are never affected by those instructions—bit 5 is always set. Note that the Eyes & Lichty description of PLP incorrectly shows b as being affected by the instruction. On the other hand, their description of RTI correctly shows that b is unaffected.
TRB and TSB affect z, as those instructions perform a logical AND between the accumulator and the affected memory location. The logical AND occurs before any bits are cleared (TRB) or set (TSB).
PLX and PLY affect n and z, which is not noted in your chart.
ADC affects c, n, v and z, but is only showing that it affects n and z.
The Programming book also indicates that WAI and STP instructions are not included in the 65c02, but again, they are there in the 2024 datasheet.
smb #0,$12
| +———> ZP location
+——————> bit to setSyntax in some assemblers appends the bit number to the mnemonic, which is non-standard when considered against the original 6502 assembly language definition.
The Rockwell extensions are of somewhat limited value, as their only addressing mode is zero page. At the time of their development, Rockwell’s main interest in the 65C02 was in embedded applications, especially modems, in which the UART’s registers were mapped into zero page. BBR, BBS, RMB and SMB were created specifically to interact with the registers. Back when I did 65C02 development, I never found a use for them, but did make extensive use of TRB and TSB. Unlike the extensions, those two are not bound to zero page, can manipulate multiple bits with one instruction, and are portable to the 65C816.
Re: Opcode table
Thanks for the corrections, BDD.
I missed the flag effects on the new instructions, oops! Should be added now, see below.
PLP and RTI flag effects were taken from Zaks - could be a misprint there. Changed to include your correction.
WAI and STP italics removed as they're now canonical, but I'm leaving 'em in for RMB/SMB
Like you, I've never used them.
@6502inside: BBR and friends use the number of the bit in question as bits 4-6 of the instruction, so e.g. smb0 is $87, smb1 is $97 etc (or smb #0,zp smb #1,zp in BDD's example syntax)
I was looking only for a quick reference, so I haven't gone into any details about how the instructions work, just how you can use them. Nor have I considered the sixteen bit parts, none of which I've ever used.
WillisBlackburn
Re: Opcode table
Most of what you want is here: https://www.pagetable.com/c64ref/6502/?cpu=65c02s&tab=4
- BigDumbDinosaur
Re: Opcode table
Re: Opcode table
smb #0,$12
| +———> ZP location
+——————> bit to set--
JGH - http://mdfs.net
