Tali's native compiler will get in your way. For this to work properly, you need each word to be compiled as a JSR. To make that happen, you can either:
set nc-limit to zero like so:
0 nc-limit !or you can simply mark the words in question with never-native. This goes just after you finish defining a new word, and it marks that word in the dictionary to always be compiled as a JSR (and never "native", which is Tali's term for when it inlines the assembly code instead of using a JSR). Here's a simple example of a word returning to a grandparent word:
: child ." going back to grandparent" cr
r> drop ; never-native
: parent child ." This shouldn't print" cr ; never-native
: grandparent ." Starting main word.. " cr
parent
." Back in main word." cr ;
grandparent Starting main word..
Back in main word.
okCode: Select all
nt: 83E xt: 848 header: 40 06 00 24
flags: HC 0 NN 1 AN 0 IM 0 CO 0 DC 0 LC 0 FP 0 | UF 0 ST 0
size (decimal): 36
0848 20 0A 08 20 3B A2 14 00 54 68 69 73 20 73 68 6F .. ;... This sho
0858 75 6C 64 6E 27 74 20 70 72 69 6E 74 20 A8 94 A9 uldn't p rint ...
0868 0A 20 54 86 . T.
848 80A jsr child
84B A23B jsr SLITERAL 14 This shouldn't ...
864 94A8 jsr type
867 A lda.#
869 8654 jsr
okIf you're wondering about the lda.# and unnamed JSR in there, that's the CR word, which loads $A (the CR character) into the A register and calls a function (which does not have a Forth name) to print it out.
