Simple circuits for clock stretching to match a slow clock
Paganini
Re: Simple circuits for clock stretching to match a slow clo
Post by Paganini »
Hi George,
In the simpler one (two counters + NAND network), Ø2 is a modified TC of the second stage counter. TC is always a very short pulse, which means that Ø2-low is the same width as the fast clock, regardless of the WSE\ value. Maybe that's what you had in mind, since it does give one such pulse per slow clock cycle, so tCYC is right, from the 6502's perspective. But it's not any help in terms of address decoding to have such a short Ø2 low time. Possibly I just didn't understand the design, and it turns out to be unsuitable for what I'm trying to do.
gfoot
Post by gfoot »
That is intentional - the PHI2 seen by the CPU always has a short low period, it needs to be this way in case it is a fast cycle. Address decoding for fast cycles ought to take place in time for this, though there is some room for it to take longer if you're careful. In my example schematic this address decoding was just "is A15 low?" So if that is fast enough to harken before PHI2 rises, it ensures the RAM only gets written for low addresses, which is ideal. I can explain more about how we can accommodate slower decoding there especially if you have a small window of slow addresses, but it will muddy the waters a bit, maybe I can make a demo circuit of that sometime though. It is simpler if at least the "slow or not" decision can be quick, even if further decoding of exactly which device is being accessed still takes a bit longer.
If the cycle is slow, then we are going to have at least one low period of the slow clock before the high period we are targeting, and this should be plenty of time for that second round of complex address decoding to take place. PHI2 will be high throughout, and the slow clock may also be high for some time before the target cycle begins. So this address decoding needs to also include SLOWCS so that it waits until the right low-then-high cycle of the slow clock before activating the device. See my example full computer schematic for how that can work - it decides between ROM and VIA in this way.
I actually want to reduce the amount of lead-in we guarantee here as it feels excessive at the moment, but right now this should provide plenty of time for even very slow address decoding - so long as the decision that the cycle is slow can be made fairly quickly (at the very least, before PHI2 falls prematurely).
Paganini
Post by Paganini »
Hi George,
OK, I think I see what you're saying. To confirm, PHI2 and SLOWCLK will never have synchronized low periods. PHI2 will always have a short low period, and the high period will be a variable length, adjusted so that the falling edge coincides with the appropriate falling edge of SLOWCLK.
If that's so, then the first build did work as it should, and my expectation was wrong. The second build was dividing the oscillator frequency by 4 and 16, rather than by 2 and 8, however.
gfoot
Post by gfoot »
Yes that's exactly right, the CPU has PHI2 held high until the appropriate falling edge of SLOWCLK. Thanks for confirming regarding your results, I'll take another look at the one that wasn't working.
gfoot
Post by gfoot »
I can't see anything wrong with that three-counter circuit at the moment, but I'll build it out when I have time, it'll be relatively easy to change my current one over.
For reference, here are some waveforms from my current build (the two-counter divide-by-4 circuit):
In these captures the bottom yellow line is PHI2, next up in blue is the slow clock (5 MHz), then in red the /WSE signal, then at the top in green is the ROM's /CS signal. The input clock (not shown) is 40 MHz.
ROM and RAM operations
The above shows a mixture of ROM and RAM operations - the code is in ROM here. In the normal case of running from RAM almost all the cycles would be fast and the red line would be mostly high all the time.
From the left there's a ROM cycle in progress which ends when PHI2 dips low, in sync with the slow clock falling. Next is another ROM cycle - note that it waits for a fresh falling edge on the slow clock (second trace up) before activating the ROM (top trace going low). Then there are two fast RAM cycles in a row, then another two ROM cycles. The first of these didn't need to wait as long as the second one. Then there are three fast cycles, etc.
ROM and VIA operations
In this second capture we see only slow operations. Note that overall they only run at half of the slow clock rate, i.e. 2.5 MHz - I don't know why the oscilloscope reported it as 5 MHz. This hslving is because the requirement to wait for a falling edge of the 5 MHz slow clock is rather wasteful, we lose up to a whole cycle every time. Some additional logic could allow us to not wait for quite as long, and would then allow code in ROM to run twice as quickly, and generally almost halve cost of slow cycles. It is not a big deal though as they should be rare in practice.
The code running here was polling for I/O, so there are some slow cycles where the ROM's /CS wasn't asserted - in these, the VIA's CS would have been asserted instead, but I didn't think to capture that.
Alnitak
Post by Alnitak »
This seems like a promising place to start for my hypothetical '02 system to run like a fast BBC Micro.
This is very hypothetical, but the idea is a real 65C02 at 8MHz+, with a real 65C22 system VIA running at the original steady 1 MHz (it provides the MOS system timer) along with scope for other peripherals that need 1 MHz, but there are others that require 2 MHz, if fitted (Tube, FDC, etc). ROM, RAM and video would be emulated with an RP2350B.
The address decode to decide which speed is required is relatively straightforward for that (in CUPL syntax, below) but the clock handling has eluded me so far, precisely because of the need to ensure that the various speed clocks need to be in phase.
PIN  1 = CLK;
PIN [2..11,13] = [A15..A5];
FIELD Addr = [A15..A5];
nPGFE = Addr:[FEXX];
nPGFD = Addr:[FDXX];
nPGFC = Addr:[FCXX];
nSYS = Addr:[FE00..FE1F];
nVIAA = Addr:[FE40..FE5F];
nVIAB = Addr:[FE60..FE7F];
nADC = Addr:[FEC0..FEDF];
CLK_SLOW= nPGFE & (nVIAA # nVIAB # nSYS # nADC);
CLK_MEDIUM = nPGFE & !CLK_SLOW;
Alnitak
Post by Alnitak »
I might have actually cracked this...
Ray
Alnitak
Post by Alnitak »
George - how does your SLOWCLK circuit cope when there are two consecutive accesses to a slow address range? If I understand your comment above "Next is another ROM cycle - note that it waits for a fresh falling edge on the slow clock" this implies that you can't actually achieve consecutive slow cycles without wasting some bus cycles?
The design I posted has this (same?) flaw - it won't start a new slow cycle until it's seen a falling edge of the slow clock, and then it needs a whole cycle to actually do its thing. I suspect that for true IO devices this is unlikely to be a concern as I think it's highly unlikely that any significant amount of code can actually initiate consecutive IO device accesses, but for a slower ROM it could be an issue.
gfoot
Post by gfoot »
Yes in this case that is intentional and it will tend to wait an extra slow cycle before executing the operation on the next one. You can tune that though, so that it only waits for e.g. halfway through the slow clock's low phase - so long as the devices on the slow bus are happy with being activated at that point. In general it should be fine so long as this activation happens more than a certain amount of time before the slow clock is due to rise.
For asynchronous devices like ROM none of this really matters because they don't really care about the slow clock, they just want enough time between the addresses and control signals being stable and the data being read - so the end result is very much not optimal. It's really 65-series devices like 6522 or 6551 that pay attention to the clock and require the control signals to be set up while their clock is low. The 65C22 requests 10ns setup time before the clock rises, while on paper the 65C51 requires something like 30ns, I forgot the exact figure. So long as you are not already too far through the slow clock's low phase, you could still select these devices without waiting a full cycle.
As an example, if your slow clock is a quarter of the speed of your fast clock, then after one slow cycle your fast clock and slow clock are going to fall at the same time. By the time your fast clock rises again you'll be a quarter of the way through the slow clock's low period, and have three quarters of the low phase remaining. Even if the slow clock is just half the speed of the fast clock, you'll only be halfway through the low phase, and that probably leaves enough setup time for the 65C22 at least.
In practice with the 4:1 clock ratio it typically takes 5-8 clock cycles to perform a slow operation, composed of 1-4 cycles waiting for the edge and 4 cycles for the operation itself. If you are happy to start halfway through the slow clock's low phase, that reduces to 1-4 cycles of waiting and 3 cycles for the rest of the operation, which is one cycle better on average, and four cycles better in the case of consecutive cycles.
But I don't really worry about these things much because the theory is that slow operations should be very rare - so exactly how long they take isn't a big deal. Also note that this sort of clock stretching is only required when you do have devices that require a clock input but which can't necessarily run at the same speed as your main clock. If you don't have devices like that then you can use the more standard method of just stretching the main clock by a specific number of cycles rather than trying to make it match a second, slower clock.
