As for the other arguments, they range from just as off-topic for this thread to irrelevant. (Yes, disorganized programmers can produce bad code in any language. That doesn't mean that having a language designed to make good programming easy is unimportant. It mystifies me how someone would use that argument to justify bad language features.) So I agree that this thread is not the place to pursue them. The only thing I'll suggest here is that if you can't produce a list of serious problems for any language you know reasonably well, you're not a good programmer. If you really don't know where BASIC stands as a language, one good place to start your understanding would be to go and write something like a unit test framework for BASIC and compare that to the ones you could write even for other microcomputer languages of the day, such as Pascal, Logo or LISP.
Any updates on the license problem?
Re: Any updates on the license problem?
It's an odd choice, to use an EhBasic forum to declare that Basic is a poor language in one or another respect. It's off topic in a very strong way.
- BigDumbDinosaur
Any interpreted language will run into limitations when implemented on any 6502-based machine. Incorporating the full scope of a modern timesharing BASIC would overwhelm the machine's resources, so the programmer has to be realistic about what can or can't be provided. The late Lee Davison, the author of EhBASIC, was confronted with that reality and, I think, did an admirable job of dealing with it. It could be a more powerful BASIC could be implemented on a 65C816 system with extended memory, but no one to date that I know of has undertaken such an endeavor.
Last edited by BigDumbDinosaur on Wed Sep 02, 2020 1:32 am, edited 1 time in total.
- GARTHWILSON
- Forum Moderator
I looked into EhBASIC years ago (although admittedly not very seriously) and it did appear that Lee did a really good job considering the small amount of memory the code had to fit into. The BASIC I used the most was on my HP-71B hand-held computer which way, way better, in ways most BASIC users could never imagine; but with the LEX (Language EXtension) files, it amounts to over 170KB. Is EhBASIC simple enough for the serious user to add capability to it (like the HP-71's LEX files), or would that require re-writing most of it? And a question that's relevant to the topic title is this: If the expansion can be done without a re-write, what are the licensing implications?
(I've started a thread on the subject of language extensions. It would be truly excellent, IMHO, if new ideas could be introduced as new threads - it makes for a much better experience reading and searching the forum.)
- BigDumbDinosaur
I think the only way to produce a truly unencumbered BASIC interpreter would be with "clean room" code.
EhBasic is said to be derived from MS Basic, Dartmouth Basic and so on... but does anyone have a reference to what original source codes were used and were they can be found?
I can see that GW Basic has been open sourced in its 8088 form, but I haven't seen any 6502 source published by them.
Most of the labels are of the form LAB_<address>. The addresses increase according to the amount of code between them most of the time, with exceptions in the places that have been modified. You don't write source code like that unless you've already got the binary.
Here's EhBASIC's error-printing code, with "out of memory" immediately before the general routine:
LAB_OMER
LDX #$0C ; error code $0C ("Out of memory" error)
; do error #X, then warm start
LAB_XERR
JSR LAB_CRLF ; print CR/LF
LDA LAB_BAER,X ; get error message pointer low byte
LDY LAB_BAER+1,X ; get error message pointer high byte
JSR LAB_18C3 ; print null terminated string from memory
JSR LAB_1491 ; flush stack and clear continue flag
LDA #<LAB_EMSG ; point to " Error" low addr
LDY #>LAB_EMSG ; point to " Error" high addr
LAB_1269
LDY Clineh ; get current line high byte
INY ; increment it
BEQ LAB_1274 ; go do warm start (was immediate mode)
; else print line number
JSR LAB_2953 ; print " in line [LINE #]"Code: Select all
OMERR: LDXI ERROM
ERROR:
IFN REALIO,<
LSR CNTWFL> ;FORCE OUTPUT.
IFN EXTIO,<
LDA CHANNL ;CLOSE NON-TERMINAL CHANNEL.
BEQ ERRCRD
JSR CQCCHN ;CLOSE IT.
LDAI 0
STA CHANNL>
ERRCRD: JSR CRDO ;OUTPUT CRLF.
JSR OUTQST ;PRINT A QUESTION MARK
IFE LNGERR,<
LDA ERRTAB,X, ;GET FIRST CHR OF ERR MSG.
JSR OUTDO ;OUTPUT IT.
LDA ERRTAB+1,X, ;GET SECOND CHR.
JSR OUTDO> ;OUTPUT IT.
IFN LNGERR,<
GETERR: LDA ERRTAB,X
PHA
ANDI 127 ;GET RID OF HIGH BIT.
INX
PLA ;LAST CHAR OF MESSAGE?
BPL GETERR> ;NO. GO GET NEXT AND OUTPUT IT.
TYPERR: JSR STKINI ;RESET THE STACK AND FLAGS.
LDWDI ERR ;GET PNTR TO " ERROR".
ERRFIN: JSR STROUT ;OUTPUT IT.
LDY CURLIN+1
INY ;WAS NUMBER 64000?
BEQ READY ;YES, DON'T TYPE LINE NUMBER.
JSR INPRTIdentifying which version of Microsoft BASIC was used as the base might be possible - the addresses in the labels give very strong clues (the difference between two tells you how many bytes of code were originally between them) - but would require considerably more work than I'm willing to put in. My guess (based purely on the addresses being so low in memory) would be one of the Apple II versions. https://www.pagetable.com/?p=46 is a good place to start exploring.
Of which: has anyone a link to a manual for those early Microsoft basics? I keep ending up with mbasic or basic-80 or even (horror!) visual basic.
- barrym95838
The first MS BASIC I used was TRS-80 Model I Level II. A not-so-great scan of the same reference guide I remember is here.
The second MS BASIC I used was Applesoft BASIC on my ][+. There's a pretty good PDF of the manual I remember here.
While poking around, I stumbled upon an in-browser emulation of "MS BASIC 2.00.00" running on what appears to be a first-generation Macintosh. The mouse doesn't track exactly right on my PC, but the functionality seems to be there, at first glance anyway, and the user interface is clumsy by today's standards but still intuitive.
(... looks like it offers 64-bit MS floats ... nice!)
Its amazing how well-protected datacode is. I've had several patents over the years... max 20 year protection at a huge cost.
Thanks Mike... it had simply not occurred to me to search for equipment manuals rather than just 'basic'. A search for 'microtan 65 basic manual' dropped me straight here: https://www.geoff.org.uk/microtan/basic_manual.htm which is exactly the system I used to use back in the day.
And conveniently, one which I believe can be generated from the source at Pagetable: https://www.pagetable.com/?p=774
(hurriedly edited upon being advised of Mr Barry's first name... Sorry!)
With the release of MS-Basic source under the MIT License I believe that this now means that EhBasic is legal as a derivative work, if that is the case, so that issue now goes away. Scanning through this topic it appears that Lee licensed EhBasic for non-commercial use, so anyone that did have concerns about using EhBasic should now be ok to use and modify it for non-commercial purposes.
Interesting point. It would be necessary to add the MIT license, I think, and acknowledge the copyright holder. I'm not absolutely sure who could do that, as Lee no longer can.
- BigDumbDinosaur
Isn’t there someone currently maintaining Lee’s code?
Yes, but my (rather pedantic) point is that one cannot just change licenses - either one is the original copyright holder, or the existing license allows the change.
Edit: the point being that current EhBasic is partly copyright Microsoft and partly copyright Lee. Microsoft changing their story is only part of the thing.
