IN SEARCH OF A NAME
IN SEARCH OF A NAME
In a 6502 system, we may refer memory ranges in several ways:
  • Two bytes is a “word.”
  • Three bytes is an “extended word” (a 65C816 thing :D).
  • 4 bytes is a “double word.”
  • 8 bytes is a “long word.”
  • 256 bytes is a “page.”
  • 65,536 bytes is a “bank.”
Without going into the “why,” I need a succinct name to refer to a range of 16 bytes.
Re: IN SEARCH OF A NAME
sentence?
paragraph?
double long?
long double?
sedecimyte?
hexadecamyte?
hexadecabyte?
barnacle
Post by barnacle »
Segment
In other worlds, I see 'quadword' has been used, but in our case a word is only two bytes, so 'octaword' would be the equivalent.
By the same token, 'quaddouble' would be consistent.
fourbyfour?
or how about chunk? Or block? Or square? (And by that route, quadrat, or ritter.)
barnacle
Post by barnacle »
From nibble->byte->mouthful?
Along the same line... a bolus ?
barrym95838
Post by barrym95838 »
It's a distant memory and therefore possibly inaccurate, but I think I've heard this referred to as a "paragraph" in the 8086/8 camp, coming from the way the segment registers are shifted left four bits before being incorporated into the 20-bit effective address.
Broti
Post by Broti »
If I recall correctly, older Turbo Pascal literature called 16 bytes Paragraph or Double Quadruple Word
ROR A? Where we're coding, we don't need A.
sentence?
Hmm...that might be it.
paragraph?
I've seen references to a paragraph in the past, but they were usually for a range of 1K or 4K bytes.
hexadecabyte?
Hexadecabyte sounds like what happens when one is attacked by a pack of dogs.  :D
I nearly choked on that.  :shock:
Segment
That one is tied with Ed’s “sentence” suggestion for succinctness.  8)
Paganini
Post by Paganini »
I like 'segment,' but if you want something pedantically literal (and that also sounds sort of 'C-ish') "long double" or "double long" would fit the bill.
“Long double” in C refers to a particular floating point number size.  I was looking for a general reference, one that doesn’t imply a particular sort of data type or structure.
I’m leaning toward “segment,” although it is x86-ish.  :roll:
barnacle
Post by barnacle »
Could always use int128_t...
