I hope the following is not to obvious and has not been answered 10^2 times
I have an apple II, and I want to output integer to screen from hex value in memory,
I have a routine working on my emulator (Virtual II) but not working on my real Apple II
; Michael Pohoreski
; https://github.com/Michaelangel007/apple2_print_uint16
; Optimized from printm
; Thanks to qkumba for optimizations
; Thanks to Gids for nudging a zero-page version
; F8 ROM Entry Points
PRHEXZ = $FDE5
SCRN2 = $F879
; Print unsigned 16-bit integer
; A=High byte
; X=Low byte
; Also see: Applesoft LINPRT @ ED24
PrintUint16
LDY #0 ; S=F3
PHA ; S+5 = _temp+1 = $105,X S=F1
PHX ; S+4 = _temp+0 = $104,X S=F2
PHY ; S+3 = _bcd[2] = $103,X S=F0
PHY ; S+2 = _bcd[1] = $102,X S=EF
PHY ; S+1 = _bcd[0] = $101,X S=EE
Dec2BCD
LDY #16 ; 16 bits
SED ; "Double Dabble"
_Dec2BCD ; https://en.wikipedia.org/wiki/Double_dabble
TSX ; X=EE
STX _BCDbegin+1 ; *** SELF-MODIFYING
; ASL _temp+0 ; abcd efgh | ijkl mnop |
; ROL _temp+1 ; C=a bcde fghi | jklm nop0 |
; ; Bit 7654_3210 | 7654_3210 |
ASL $104,X ; _temp+0
ROL $105,X ; _temp+1
; LDX #$FD ; $00-$FD=-3 bcd[0] bcd[1] bcd[2] bcd[3]
_DoubleDabble ; Y=FD Y=FE Y=FF Y=00
JSR Dabble ; X=EF
JSR Dabble ; X=F0
JSR Dabble ; X=F1
DEY
BNE _Dec2BCD
CLD ; Y=0 = output length
BCD2Chars
LDA $100,X ; X=F1, 1F1 -> bcd[2]
JSR HexA ; print 0, 1, or 2 hex digits
DEX
_BCDbegin
CPX #00 ; *** SELF-MODIFIED X == EE ?
BNE BCD2Chars
; Safe to restore stack now since we are done with vars
TXA
ADC #$04 ; C=1 from CPX #EE
TAX
TXS
TYA ; Handle special case input = $0000 of no output
BEQ _HaveLeadingDigit
_PrintDone
RTS
Dabble
LDA $101,X ; bcd,X
ADC $101,X
STA $101,X
INX
RTS
; Converts A to high ASCII digits, prints as they become available
; @return: A will be bottom nibble in high ASCII
HexA
PHA
JSR SCRN2+2 ; LSR x4 == 0>> 4
JSR _HexNib
PLA
AND #$F
_HexNib
BNE _HaveLeadingDigit ; If have leading zero and no output yet ...
DEY ; ... then skip storing it
_HaveLeadingDigit
INY ; Y = output string length
BEQ _PrintDone
JMP PRHEXZ
I only need 1 byte From 00 to FF to be outputted to 0 to 255 on screen
Thanks
Vincent
