Hi All.
I have a couple of questions.
1) I've made do with a soldering iron I bought from Tandy in the UK around 35+ years ago. It is a Weller SI 15D Soldering Iron (240v / 15w). I've just looked on eBay and someone is selling one - it has "vintage" in the title!
However, as my aspirations are to move my 65C02 system from breadboard to PCB. I envisage it'll be mostly through-hole stuff I'll be doing, but it would be nice to attempt the bigger SMD stuff too if ever I get into the PCB design aspects. So, my question is this: will this soldering iron suffice or should I get something more modern? I have no clue as to what Wattage or temperatures are needed. Is a soldering station needed (with a hot air gun) for what I want to do?
Hi,
Some say Wellers never die, but mine did - after 40 years...
15w may be a little low but it would work for typical ICs - where it might be a little slow if soldering larger wires when it might not be able to get enough heat to the joints. I think that a temperature controlled iron in the 40-50 watt range is better - Personally, I use 340°C for leaded solder and maybe 380° for lead-free, however my iron has a pencil-tip - you may be better off with a chisel-tip to start with and use lower temperatures.
I'd stick with what you have before upgrading though - it is rated to 400° so ought to be fine - just don't hold it against IC pins for more than you need to. (Or use sockets)
I have a good hot-air station too, but only ever seem to use it for heat-shrink tubing... The few SMT things I've soldered have all been with the iron...
2) I have looked but cannot find this next item - but that may be because I don't know the right search terms. I'm looking for some kind of socket I can put the 65C02 in which takes up the same footprint on the breadboard but allows me to hookup Dupont connectors to for testing purposes. I have seen the huge clips (mega-expensive) and tiny (individual) test clips which would be too messy. Does such a product exist for a reasonable price?
Don't think I've seen anything like that - but yes, those big 40-pin clips are not cheap.
However if you're on a breadboard then you have the rows next to the CPU to push a little wire into to clip the 'scope probe onto. Or you can just probe individual pins on the ICs if needed.
Don't be afraid to just hook it all up and see what happens though. Both my recent projects have started on breadboards and have more or less "just worked". Even at 2Mhz. And there's always good old stripboard since you're in the UK (I think) I've used that with my 6502 projects too with good results up to 16Mhz.
An issue with a lower wattage iron soldering to stripboard is that the tracks can absorb a lot of heat though so it might take a good few seconds to get it hot enough to flow the solder.
Hope it goes well.
