[the clock oscillator is] from a Motorola CMOS design note
Regarding the reset circuit, the '4148 diode appears (due to a typo?) in an illogical place. As originally drawn (between ground and -Rst) the diode will never conduct, and may as well be omitted.
Instead I believe it ought to be between -Rst and Vcc. In the rare but dangerous circumstance of Vcc sharply dropping from 5 volts to zero (as when an accidental short occurs), the diode ensures that the voltage on the capacitor also gets pulled low. This addresses the very real risk of the CPU getting fried.
(I mean fried in the sense that the reset input of the CPU would get damaged by the voltage on the cap, which would momentarily exceed that of the CPU Vcc pin which is at zero. IOW, without the '4148 diode, the cap will get discharged by the CPU's reset input instead.)
