- Comes from a self-taught C programming background and would prefer to use something that is supported by a C compiler (Whether it's the WDC tools or another compiler)
- Does not like assembly and will try to avoid using it as much as possible
- Has a budget of $100 for the SBC and a simple display for it (looking at monochrome LCDs that are 96x64 or smaller, still exploring options, but will be using SPI or I2C)
- Needs something made from off the shelf parts still in production as what I develop with this will be spun off into projects I'd like to make more than one of cheaply
- Can solder if the the SBC is a kit that comes pre-assembled, but won't touch any grid array ICs unless a socket is used
- Wants to get output to a SPI/I2C graphic display as quick as possible by direct CPU drawing (in terms of time spent getting it working, not the communication speed)
- Wants exposed address/data bus lines
I was leaning towards the 65C02SXB, with plans to purchase a W65C02EDU for it at a later date if I go that route, but I wanted to hear thoughts on it as a first SBC for a newbie to this field and see if there were better options that I might not have heard of.
