Old but Gold: in search for (forgotten) tricks
Broti
Post by Broti »
Well technically not just a 6502 only topic.
Since I wasn't around in the early days of computing in the '70s and don't know where (magazines or books) to start:
I'm searching for those vintage programming tricks like the BIT skip, which also appears e.g. in the source of Altair BASIC (8080: LXI) or GW-BASIC (8088: MOV).
Do you know any?
ROR A? Where we're coding, we don't need A.
BB8
Re: Old but Gold: in search for (forgotten) tricks
Post by BB8 »
Broti
Post by Broti »
I already knew these two threads but thanks anyway :wink:
(And the code section on this site)
They might be helpful for others. *thumb up*
BB8
Post by BB8 »
; is min <= .A <= max
CLC
ADC #$FF-max
ADC #max-min+1
BCS yes
SEC
SBC #min
SBC #max-min+1
BCC yes
CLC                           ; by Mike Barry
ADC #$FF-max
CMP #$FF-min+1
BCS yes
CMP #min
BCC LessThanMin
CMP #max+1
BCS MoreThanMax
; here is   min <= .A <= max
; .A = M- .A
SEC
EOR #$FF
ADC M
CLC
SBC M
EOR #$FF
; SwapNibbles
ASL
ADC #$80
ROL
ASL
ADC #$80
ROL
; ROL8 (bit7 --> bit0)
CMP #$80
ROL
ASL
ADC #$0
; DoubleROL8 (bit7,6 --> bit1,0)
ASL
ADC #$80
ROL
; ROR8 (bit0 --> bit7)
LSR
BCC +2
ORA #$80
; Invert the bits of a byte
LDX #8
loop:
ASL source
ROR
DEX
BNE loop
;  ASR (signed division by 2)
CMP #$80
ROR
; INV  (flip  .A)
EOR #$FF
; NEG  (-.A)
CLC
EOR #$FF
ADC #$01
SEC
EOR #$FF
ADC #$0
; NEG M  (-M)
SEC
LDA #$0
SBC M
;  Compare Sign
LDA N1
EOR N2
BPL SameSign
; Toggle  Carry
ROL
EOR #$01
ROR
ROR
EOR #$80
ROL
; copy bit7 of Memory into all bits (so it's $00 or $FF)
LDA #$7F
CMP Mem    ; Carry clear if >= $80
ADC #$80   ; $00 if carry set; $FF if carry clear
; copy carry into all bits
LDA #n
SBC #n
EOR #$FF
; Copy bit 3-5 of .A into M and leaving other untouched
EOR Mem
AND #$38   ; bits 3-5 (set the bits to be copied)
EOR Mem
STA Mem
; Copy bit 3-5 of M into .A
EOR Mem
AND #$C7   ; not bits 3-5
EOR Mem
;  Check if 16bit value is zero
LDA m
ORA m+1
BEQ iszero
;  Increment 16bit value
INC m
BNE skip
INC m+1
skip:
; Decrement 16bit value
LDA m
BNE skip
DEC m+1
skip: DEC m
; convert hex digit to ascii
SED
CMP #$0a
ADC #$30
CLD
CMP #$0A
BCC skip
ADC #$66    	; add $66+C; convert $0A to ascii
skip:
EOR #$30	; convert 00-09 to 30-39 and 71-76 to 41-46
CLC
SED
ADC #$90
ADC #$40
CLD
CLC
ADC #’0’
CMP #’9’+1
BCC skip
ADC #’A’-’0’-10-1
skip:
; is just 1 bit of .A set?
; (is .A a power of 2)
STA temp
DEC temp
BIT temp
BEQ IsPwrOf2
; indirect JSR
LDA #<dest
STA addr
LDA #>dest
STA addr+1
JSR (redirect)
redirect:
JMP(addr)
synthetic logical operators table
bit AND 0 = 0
bit OR 1 = 1
bit EOR 1 = not bit
barrym95838
Post by barrym95838 »
Thanks for the kind mention, but I think I might have been inspired by some old Woz code. When I "upgraded" some of my code to CMOS, I also saved a byte on my complement carry (I didn't have anything useful in A at that moment):
    rol a
    inc a
    ror a
I think David Galloway should be credited for the nyfty little nybble swap.
barnacle
Post by barnacle »
I've used that trick on (heresy!) the 8080 (burn the witch!)
Neil :mrgreen:
edit: nah, can't have been... it has CMC. I wonder what it was, then?
barrym95838
Are accumulator bits 6 and 7 the same or different?
    cmp #$C0    ; (thanks, Woz)
    bmi different
same:
different:
Useful while normalizing two's-complement floats. :wink:
barrym95838
;   Convert ASCII character to binary number in bases up to 41.
;   This translates A-Z[\]^_ and a-z{|}~DEL as 10, 11...40.
;   The caller must check the returned value if the intended base was
;   less than 41.
;          A: (written) ASCII character to convert; binary number on return
;     N flag: (written) clear on success, set on error.
;       X, Y: (preserved)
convascdigit
            cmp #'9'+1
            bcs .letter         ; >'9', convert letter
            sbc #'0'-1          ; convert digit; if <'0', N flag set for error
            rts                 ; N clear, no error
.letter
            and #%11011111      ; clear bit 5 to convert to upper-case
            bmi .exit           ; high bit set, error
            sbc #'A'-$0A
            cmp #$0A            ; if <$0A, set N flag to indicate error
.exit       rts
Courtesy of cjs.
barrym95838
{               } ; delay 9*(256*A+Y)+8 cycles
{               } ; assumes that the BCS does not cross a page boundary
{ 8000 C0 01    } .1 CPY # 1 ; 2
{ 8002 88       }    DEY     ; 2
{ 8003 E9 00    }    SBC # 0 ; 2
{ 8005 D0 F9    }    BCS =.1 ; 3
Courtesy of dclxvi.
