The loader has a couple of weird things in it that I really don't know why they would be done like that - forgive me because I'm primarily a Z80 person, so I may just be missing some tricks that experienced 6502 developers know about, but even so I can't see much of a reason why some things have been done in a certain way.
For instance, this code snippet:
start_program_1:
0135 lda $02e2 ; INITAD
0138 ora $02e3 ; INITAD + 1
013b beq goto_main ; if INITAD is zero don't jump there (MissileCmd set to 0)
013d jsr jump_initad
goto_main:
0140 bne main ; surely these two can only result in the same as
0142 beq main ; a JMP main?
Then there's this code snippet:
start_program_2:
0144 bit $30 ; status
0146 bvc jump_runad ; if overflow clear, use RUNAD address
0148 lda $02e0 ; RUNAD
014b sta $000c ; DOSINI (why not a ZP instruction?)
014e lda $0231 ; RUNAD+1
0151 sta $000d ; DOSINI+1 (why not ZP?)
0154 lda #$01
0156 sta $0009 ; BOOT? (why not ZP?)
0159 jmp WARMSV ; $e474, OS ROM WARMSV - warm start. Probably for cart images?
jump_runad:
; For Missile Command, this is ultimately set to $8000
015c jmp (RUNAD) ; $02e0 Run address from executable (xex file?)
jump_initad:
015f jmp (INITAD) ; $02e2 Init address from disk
The only reason I can think of is to either to provide padding (unlikely, the whole routine lives in stack space, so you'd think compactness would be important to allow more stack space) and I don't think any of this is timing sensitive. The only plausible reason I can come up with is that when this routine is written out from the first 8k page of the cartridge, the addresses could be modified to be anywhere in address space, but in this instance this still doesn't make sense because DOSINI and BOOT can't be anywhere in memory (because the OS ROM will use these).
