Neolithic Tiny Basic
Re: Neolithic Tiny Basic
If you view the page source, you can see an awful lot of non-breaking-spaces where tabs used to be. It looks like three spaces per tab, but it doesn't align on tab boundaries.
I've updated the rough guide (above) to reflect current changes.
New and improved memmove.
Thanks Mike, at first tests that seems to work, and it's thirty-two bytes shorter!
Previous buggy version of tiny.asm removed; check newer posts.
barrym95838 wrote:
I've been really busy lately, so I didn't have time to test this, but it's based on Bruce Clark's code, so I know it started out tight and fast. It's still tight and fast, and hopefully correct, if I didn't mess something up adapting it.
- BigDumbDinosaur
BB8 wrote:
anyway the <pre> - </pre> tags have existed since the very early versions of Html: they are meant for preformatted monospaced texts, especially valid for displaying source code; with those tags any spaces or tabs are rendered as they were entered.
Unfortunately, the forum software doesn’t process any HTML embedded in a post. The only way to get monospaced font is by using the code tags. Tab rendering is not part of the HTML standard, so it’s anyone’s guess how tabs will appear in a browser.
- BigDumbDinosaur
That is probably the forum’s PHP code doing that. I've written a lot of PHP code and have not been able to conclusively determine what happens when a tab gets processed by an echo command in PHP. The logical thing would be for PHP to expand the tab into a bunch of entities, but there is nothing in the php.ini configuration file that deals with tabs. I’m guessing the forum code has something that watches for tabs and expands them—string manipulation in PHP is painless.
That makes sense, and matches what I'm seeing. Slightly frustrating for _me_ since I use four-space tabs but I'm not going to lose sleep over that.
Anyway, since NTB seems to do what I want, I'm going to spend a little time on the pi pico 2040 as a memory mapped peripheral; something I was doing when I got distracted by this. At least, I now have something to run on it so I can prove it loads and runs... beyond that, I'm still thinking about a variant of NTB that would be completely line-number-free, but that requires at least a minimum text editor, in or closely associated with the basic, or an external editor and some sort of operating system. That's also on the road map, but a long way down...
There's an issue with developing an editor: the Symon emulator doesn't appear to understand any control codes other than backspace; I haven't even found a way to clear the screen or to move the cursor. Maybe it incorporates VT codes; I haven't tested any of those yet.
Feel free to play with NTB; bug reports gratefully accepted, particularly if they come with fixes
Thanks,
Thanks,
Another couple of bugfixes: one accidentally re-introduced into son-of-memmove, and one courtesy a cut'n'paste error while rejigging compare.
It happily runs Gordon's Mandelbrot code, with slight syntax modifications mentioned elsewhere.
Incidentally, I can't help feeling there must be some easier way to generate an enum list that the horrible way I did in that code (and which was indirectly the cause of my compare issues).
I haven't played yet, but I wonder about a macro to set the first value, and the subsequent macros to increment that set value.
GlennSmith
Have you looked at the implementation of RP6502 by "rumbledthumps" ? I fell instantly in love with the idea, and I'm working on my own implementation/interpretation of it. In it's most simple form (ie without the 2nd pico that's used as the VGA device), it gives you a free memory map up to $FEFF, with UART, USB, fileio, and sound all thrown in. The only real downside is that it's running everything at 3.3v, so you can't get breakneck speeds out of the 65C02. But it's so simple and reliable that I've been using it to write a whole suite of programs (compiler, editor, etc.in PLASMA) and no longer worry about the stability of the underlying HW. My current work is now adding the HW bells & whistles that I had designed into my SBC into the RP56502 design.
Well, my penny's worth. Great work on the tiny basic.
Glenn-in-France
Yes, I've seen his stuff; I'm not sure I fully understand it but in concept, yes.
My plan is to include the vga and serial port (via usb) with a pair of memory mapped address: one address to read status and write commands, the other to read and write the associated data. The pico will also supply an initial program load and manage the processor clock. I can live with 3v3
But probably better that I discuss that on its own thread, rather than clutter this thread more than it already is - as usual with any thread I start, it's tended to drift! Here: viewtopic.php?f=4&t=8116
- barrym95838
Regarding enums, I am being hampered a little by my assembler... but I have something that works, with a little work. Here's the macro, a couple of enum definitions, and some assembled code using them.
It's a bit annoying: attempting to complete the macro without an assembled opcode before the 'endm' caused it to segfault. Eventually I discovered that defining a byte (and probably a word) there works; perhaps the parser is expecting to see some actual code generated.
I don't want that code in my executable, obviously, but setting it to the BSS segment means it doesn't generate code. I have to remember to reset the origin of BSS when I actually start using it. Setting enum_cnt allows setting an initial value for the first enum.
In main, or anywhere thereafter, those enums remain global and constant. If you try to use a name in a different enum, you get a redefinition error. There's also no way to set random values, as you might with C; it's not that flexible. But useful, I think.
So:
The hex file generated started as expected at $e000.
ENUM macro p1
p1 equ enum_cnt
enum_cnt set enum_cnt+1
db 0
endm
bss
enum_cnt set 0 ; set value of first enum
org 0x0000
ENUM FIRST
ENUM SECOND
ENUM THIRD
enum_cnt set 1 ; let's number from 1-7
ENUM MONDAY
ENUM TUESDAY
ENUM WEDNESDAY
code
org $e000
main:
lda #FIRST
lda #SECOND
lda #THIRD
lda #MONDAY
lda #TUESDAY
So:
- Include the macro
- Before defining any ENUMs, set the origin to zero, and set BSS
- Define the value of the first enum, using
enum_cnt set 0 ; set value of first enum - Add ENUMs as desired, ensuring that you do not share names
- Reset the BSS origin to zero (I didn't show that in the example) before you assign variables with DS or DW
- Switch to code and code as normal.
ENUM macro p1
p1 equ enum_cnt
db 0
endm
bss
0000 = enum_cnt set 0 ; set value of first enum
0000 = org 0x0000
ENUM FIRST
0000 = >FIRST equ enum_cnt
0001 = >enum_cnt set enum_cnt+1
0000 = > db 0
ENUM SECOND
0001 = >SECOND equ enum_cnt
0002 = >enum_cnt set enum_cnt+1
0001 = > db 0
ENUM THIRD
0002 = >THIRD equ enum_cnt
0003 = >enum_cnt set enum_cnt+1
0002 = > db 0
0001 = enum_cnt set 1 ; let's number from 1-7
ENUM MONDAY
0001 = >MONDAY equ enum_cnt
0003 = > db 0
ENUM TUESDAY
0002 = >TUESDAY equ enum_cnt
0004 = > db 0
ENUM WEDNESDAY
0003 = >WEDNESDAY equ enum_cnt
0004 = >enum_cnt set enum_cnt+1
0005 = > db 0
code
e000 = org $e000
e000 : main:
e000 : a900 lda #FIRST
e002 : a901 lda #SECOND
e004 : a902 lda #THIRD
e006 : a901 lda #MONDAY
e008 : a902 lda #TUESDAY
barrym95838 wrote:
In memmove it looks like you forgot to push x and y at the top, and using bmi for an unsigned compare of addresses is not advised in the general case. I previously left your quirky address compare alone because I didn't understand it and assumed that it "just worked".
The address compare is courtesy of BB8 who has been most helpful; it's possible I've copied his suggestions incorrectly. I need to look in more detail. Originally I was using a signed comparision; some lines may have stayed, or I may be jumping to the wrong place.
Thanks! Who'da thunk memmove could be so tricky?
I put it to you that
is somewhat neater, and a lot less error-prone when adding, removing, or moving entries, than
; token enums
bss
org 0
enum_cnt set $80
ENUM LET
ENUM REM
ENUM PRINT
ENUM LIST
ENUM NEW
ENUM RUN
ENUM INPUT
ENUM IF
ENUM ENDIF
ENUM FOR
ENUM TO
ENUM NEXT
ENUM WHILE
ENUM ENDWHILE
ENUM GOTO
ENUM GOSUB
ENUM RETURN
ENUM END
; these comparisons _must_ be in this order
ENUM LTE
ENUM GTE
ENUM EQUAL
ENUM NEQUAL
ENUM LT
ENUM GT
ENUM POKE
ENUM LAST_KW
FIRST_COMP equ LTE
LAST_COMP equ GTCode: Select all
; token enums
LET equ 0x80
REM equ LET + 1
PRINT equ REM + 1
LIST equ PRINT + 1
NEW equ LIST + 1
RUN equ NEW + 1
INPUT equ RUN + 1
IF equ INPUT + 1
ENDIF equ IF + 1
FOR equ ENDIF + 1
TO equ FOR + 1
NEXT equ TO + 1
WHILE equ NEXT + 1
ENDWHILE equ WHILE + 1
GOTO equ ENDWHILE + 1
GOSUB equ GOTO + 1
RETURN equ GOSUB + 1
END equ RETURN + 1
LTE equ END + 1
GTE equ LTE + 1
EQUAL equ GTE + 1
NEQUAL equ EQUAL + 1
LT equ NEQUAL + 1
GT equ LT + 1
POKE equ GT + 1
LAST_KW equ POKE + 1
FIRST_COMP equ LTE
LAST_COMP equ GTRe: Neolithic Tiny Basic
memmove:
lda mm_size
ora mm_size+1 ; not much point if size is zero
beq mov_done
lda mm_from+1 ; check high bytes
cmp mm_to+1
bne memo_nz
lda mm_from ; high bytes were equal, check low bytes
cmp mm_to
beq mov_done ; done if the source and dest is the same
memo_nz:
BCC mov_dec
Thanks for the confirmation, BB8. I've fixed that in my local copy.
I'm probably out of circulation for a couple of days, so I'll not post the latest version (which incorporates that change and also the New Improved[tm] enums for the token values) until I'm back. I'd like to confirm that it runs on actual silicon first!
