Apple II , DMA question.
In AppleII there is DMA access to RAM. It consists of stopping the 6502 clock. I have a question. For how long can you safely stop the 6502 clock in the LOW state in the MOS version?
- BigDumbDinosaur
Re: Apple II , DMA question.
Not for very long. Ed probably knows for sure, but I think FMIN for the NMOS part is in the 250 KHz range, below which the registers are at risk of losing content.
It is permissible to stop the clock for an indefinite period of time in the high phase with all versions of the 65C02. It is permissible to stop the clock an indefinite period of time in either phase with any WDC 65C02 or 65C816 that has an ‘S’ designator in the part number, e.g., W65C02S6TPLG-14. The ‘S’ indicates the device has a static core. WDC switched from dynamic to static cores in the early 1990s, at which time FMAX was increased to 14 MHz. Incidentally, the ‘T’ in the part number means the die was produced at the Taiwan Semiconductor (TSMC) foundry. Parts with the ‘S6T’ designation are the highest-performing versions of the WDC product line.
I don't know for sure, but in the past I said
> note that it's the max cycle time which is the constraint here. The general advice is to go no slower than 100kHz for reliable operation. In practice you've probably got some tens of milliseconds before charge leakage starts to flip values, maybe more
The actual length of time before an important value decays will be a function of voltage, temperature, noise, manufacturing variation, and possibly also altitude and solar activity...
Highly anecdotal and "it worked for me", but when I was experimenting with overclocking my 6507s (so NMOS) I somewhat crudely unplugged a wire from one can oscillator into another.
The board stopped then started again - just carried on where it left off. I left it 10 seconds once to see what would happen - it just carried on.
No guarantee of anything though!
Did any peripheral for the Apple II actually use DMA though?
A related question is how long DRAM retains data without refresh - George Foot explored that here
Testing memory refresh failure
I'm curious as to why Apple didn't use the RDY pin for this, anyone know?
- BigDumbDinosaur
I want to connect a 65816 symulator (STM32H750) to the AppleII bus so that it works in DMA mode and does not disable the 6502.
This emulator has its own RAM but needs access to Video RAM and I/O.
Since the maximum amount of data to write to RAM that the symulator 65816 can write in one command is 2 bytes, I think that stopping for 2 cycles will not be a problem.
I will have to figure out how to prevent problems with MVN MVP
- barrym95838
Uncle Warthog
Apple produced some tech notes covering detailed bus timing for DMA access. See https://mirrors.apple2.org.za/Apple%20I ... 989-09.pdf for details.
Uncle Warthog
A few cards used for software piracy, er, preservation had their own CPU and used DMA.
Some other cards such as video input cards and debugging aids did as well.
Apple had their own DMA SCSI controller card too. I've been told that Apple's big demo for that card was a digitized version of the asteroid field scene from The Empire Strikes Back stored on a hard drive being pumped into an Apple IIgs' video and sound memory at full frame rate. Impressive if true. Some of the newer third-party storage controller cards made toward and after the end of Apple producing the II also use DMA.
- BigDumbDinosaur
What sort of problems are you anticipating?
- BigDumbDinosaur
Uncle Warthog wrote:
If you're talking about a IIgs, that uses a 65816 which is fully static so you can stop things for any length of time.
No sir, the 65C816 in the IIGS is not static and as is the case with all 65Cxx MPUs, the clock can only be safely halted on the high phase. The IIGS went out of production about a year before the release of the static-core 816.
Last edited by BigDumbDinosaur on Mon Mar 10, 2025 11:29 pm, edited 1 time in total.
I use AppleII Europlus and SY6502 processor, so Synertec.
I don't have 65816 but only its simulator running on STM32H750
https://stm32-base.org/boards/STM32H743 ... 7XX-M.html
I want to connect it as a card to my AppleII
Basically, I have to develop the interface, so there is a chance that I will finish it by April 1st
I want to get the fastest possible data transfer speed in DMA 1 byte per 1 6502 cycle, so if I send data to Apple2 RAM memory, then every few bytes I will have to perform one 6502 processor cycle to refresh its registers.
E.g. for 10us every 10 MVN or MVP instructions I will have to let the 6502 execute 1 cycle.
