... remembering that the data stored at the SSR must have its bits flipped, since the 6522 SR is least significant bit first rather than most significant bit first.
Dietrich
BIT PORTA ; trigger /ACK for clock circuit
; ... per byte
STA SR ; trigger transfer
LDX #$FF
L0 LDA #4
L1 BIT IFR ; check
BEQ L1
LDA PORTA ; read incoming data
STX SR ; trigger next transfer (by sending $ff in this case)
; process received data (e.g.)
STA (ZP),Y
INY
BNE L0
SPI_BIN LDA IFR ;read byte from SPI
AND #$04 ;test SR bit
BEQ SPI_BIN
STA IFR ;clear SR bit
LDA SR
RTSCode: Select all
SPI_BIN: LDA #4
1$: BIT IFR
BEQ 1$ ; (shorter loop)
LDA SR ; (This clears the IFR's SR bit.)
RTSCode: Select all
lda #0
ldx #BITS_CS_LO
ldy #BITS_CS_LO | BIT_SCK
sty SD_PORT ; 4 set sck hi
bit SD_PORT ; 4 test miso
stx SD_PORT ; 4 set sck lo
bvc *+4 ; 2/3 branch if miso is low
ora #$80 ; 2 set bit 0
ora #$40 ; 2 set bit 0
ora #$20 ; 2 set bit 0
ora #$10 ; 2 set bit 0
ora #$08 ; 2 set bit 0
ora #$04 ; 2 set bit 0
ora #$02 ; 2 set bit 0
ora #$01 ; 2 set bit 0
ldy #$7f
cpy SD_PORT
rol
cpy SD_PORT
rol
cpy SD_PORT
rol
cpy SD_PORT
rol
cpy SD_PORT
rol
cpy SD_PORT
rol
cpy SD_PORT
rol
cpy SD_PORT
rol
