It is currently Thu Nov 14, 2024 6:32 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Nov 03, 2024 8:08 pm
It's better than that: prior to moving to Window Rock she married the same fellow (not the Navaho, that was later) four times in the same week; first a religious ceremony which was not acceptable to the UK authorities, so a UK civil ceremony, then as the US immigration authorities had some concerns, a US civil ceremony, and finally another religious ceremony for the benefit of his parents.
Then they moved to to Pocatello, land of the potato, where there was once it seems some ordinance against looking unhappy in the street.
Years later they got divorced, in Flagstaff, and after that she married the Navaho. Which by some bizarre logic apparently means I have inherited some strange rights in the Navaho lands... I don't like to ask.
PostPosted: Sun Nov 03, 2024 9:10 pm
Nora, keep up posted on your musings on your OS and home-made computer, even if you don't feel like you have any progress yet.
PostPosted: Tue Nov 05, 2024 4:50 am
Translated by ChatGPT:
Hello, Nora. I’m ponzu840w. I’m also Japanese. When I saw this topic, I quickly created an account.
I am also developing a DOS for the 6502 inspired by CP/M. I'm working on it directly on the actual hardware (W65C02) without using an emulator, and I'm using CA65 as my assembler. If you'd like, would you be interested in exchanging ideas about our projects? (I'm fine with communicating in Japanese!)
Here’s some information about my project:
Blog (Japanese): http://ponzu840w.starfree.jp/blog/blog.html?id=00032
GitHub (DOS): https://github.com/ponzu840w/miracos
If possible, I’d love to see your work as well!
原文:
はじめましてnoraさん、ponzu840wと申します。僕も日本人です。このトピックを見かけて、急いでアカウントを作りました。
私も、CP/Mを参考にした6502用のDOSを開発しています。エミュレータは使わずに実機(W65C02)での開発で、アセンブラにはCA65を用いています。よろしければ、作品について意見交換をしませんか?(私は日本語で構いません!)
よろしければ、noraさんの作品も見せていただけませんか?
PostPosted: Tue Nov 05, 2024 4:55 am
原文:
僕もですその僕は実機なくてその実行はエミュレータとじゃないと開発できないのですがその6502用のdosを作ろうと思ってますけどまだ開発を実行できていません、アドバイスをください
PostPosted: Tue Nov 05, 2024 5:03 am
原文:
僕もその6502用のdosを作りたいと思っていたけどその実機ないので意見交換でその僕は実機ないですwそのなのでそのponzu840wさんにそのエミュレータをどうすればいいかアドバイスをお願いします。で僕の意見は良いエミュレータない場合は最悪の場合はエミュレータ自作するのもありかな、と思っていますご返信いただければ幸いです
PostPosted: Tue Nov 05, 2024 5:07 am
translation from Yandex: I'm not a real machine, and I can't develop it unless I run it with an emulator, but I'm going to make a dos for that 6502, but I haven't been able to do development yet, please give me some advice.
PostPosted: Tue Nov 05, 2024 5:09 am
Translation again:  I also wanted to make dos for the 6502, but since there is no real machine, I do not have real machine w So please give advice on how to do the emulator to ponzu840w.  So my opinion is a good emulator If you don't have the worst case emulator you can make your own, I think if you can reply
PostPosted: Tue Nov 05, 2024 6:28 am
原文:
When it comes to creating your own DOS, access to storage and basic text input/output functions are essential. That means you’ll want a reliable emulator with those capabilities. I’m not very knowledgeable about emulators, but I think it would probably involve using an emulator for an existing computer, like the Apple ][ or Commodore. Since many people use these emulators, they’re both reliable and convenient.
However, there’s a big issue: these existing platforms already have their own robust DOS. Depending on what you want to get out of making your own DOS, it could impact your motivation. For example, in my case, if I had to create a DOS for the Apple ][ when Apple2DOS already exists, I probably wouldn’t have the motivation. No matter how much effort I put in, it’d be hard to make something better than the original.
From this perspective, a custom-built machine would remain a DOS-less machine forever unless you make a DOS for it, which can really be motivating.
While it’s also possible to do this with a custom emulator, I imagine that developing one from scratch would be tough… The W65C02 can be bought for 750 yen at Akizuki Denshi Tsusho. Why don’t we build a real machine together?
原文:
DOSの自作を目的にするとなると、ストレージへのアクセスと文字列入出力が最低限必要ですよね。それらの機能を備えていて、かつ信頼できるエミュレータが欲しいということになります。
僕はエミュレータについて詳しいわけではありませんが、おそらく、Apple][とかコモドールとか、既製品のパソコンのエミュレータを使うことになると思います。これらのエミュは多くの人が使っているので信頼性も利便性も高いでしょう。
ただし大きな問題があって、これらの既存プラットフォームには立派なDOSがすでに用意されているんですよね。自作DOSの楽しみの重きをどこに置くかにもよりますが、例えば私の場合ですと、すでにApple2DOSがあるのに別途Apple2用のDOSを作るようなことだと、モチベーションが持たなかったと思います。どう頑張っても純正品のほうが出来がいいということになりかねませんし。
この観点でいえば、自作のマシンは自分でDOSを作らない限りは永遠にDOSのないマシンになってしまいますから、俄然やる気が出るというものです。
自作エミュレータでも同じことはできますが、独自開発するのは大変な気がします…。W65C02は秋月電子通商で750円で買えます。一緒に実機を作りませんか?
PostPosted: Tue Nov 05, 2024 6:33 am
原文:
原文:
厳しいですねその僕は12歳でその自分単独で買えないので無理ですすみませんでした、ありがとうございました
PostPosted: Tue Nov 05, 2024 7:20 am
原文:
原文:
"I see, so that’s the situation. Wait, you’re 12 years old!? I’m amazed that you’re interested in the 6502 at that age—wow.
Given that, it would definitely help to hear from people with more knowledge about emulators.
How about starting by developing a DOS for an existing computer and then transitioning to a custom emulator once you’re more experienced? As you continue developing, you’ll probably start wanting various features here and there, and you could bring all those ideas together in a custom machine running on an emulator.
Then, once you’re old enough to buy components freely, you could turn that custom emulator into a real machine. That sounds like it’d be a lot of fun!"
なるほどそういう事情があったんですね。というか、12歳!?その年齢で6502に興味があるとは…いやはや。
そういうことでしたら確かに、エミュレータに詳しい人の意見も聞きたいですね。
既製品パソコン用にDOSの開発を始めて、詳しくなってから自作エミュに移行するというのはどうでしょう?開発を続けるうちに、あんな機能が欲しい、こんな機能が欲しいという欲が湧いてくると思いますが、それを全部盛り込んだ独自機をエミュ上で実現できますよ。
自由にものが買える年齢になってから、それを実機として実現するというのも面白そうです。
