It is currently Sat Nov 23, 2024 3:35 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Oct 29, 2024 8:28 am
I'm Japanese and I'm looking forward to working with you and having fun developing the 6502.
PostPosted: Tue Oct 29, 2024 10:21 am
Greetings and welcome!
初めまして。
PostPosted: Tue Oct 29, 2024 11:32 am
初めまして。
こんにちはよろしくお願いします
PostPosted: Tue Oct 29, 2024 5:28 pm
Welcome.  You’ve come to the right place!
PostPosted: Tue Oct 29, 2024 11:41 pm
僕もx86はいらないと思っています丁度意見が合いましたよろしくお願いします。僕がx86いらない理由は自分のosを自作するのにbiosやuefiが難しいしいらないと思ったからですよろしくお願いします。
PostPosted: Tue Oct 29, 2024 11:42 pm
僕は6502のcpuやコンピュータのシンプルが大好きです
PostPosted: Wed Oct 30, 2024 12:05 am
自分の6502用のOSを作りたいです。CP/Mを基にして、ゼロから6502のOSを作成し、みんなに配布したいです。しかしそのエミュレータとアセンブラをどうすればいいかわかりません
PostPosted: Wed Oct 30, 2024 12:33 am
Translation: I also don't think x86 is necessary. I agree with you, thank you. The reason I don't need x86 is because I don't need BIOS or UEFI because it's difficult to make my own OS.Thank you in advance.
Reply: Egh, to be fair, the x86 carried a lot of weight with it. Even most 6502 systems had a ROM of some sort, even if it wasn't specifically called a BIOS. While I'm not a huge fan of the x86's decision to go with a segmented memory model in real mode; back in the DOS days, writing an OS wasn't significantly more complicated between the two.
In any event, you don't need a huge complicated BIOS to get a 8086, 80286, Z80 running if you know the exact details of the hardware on the system.
Things started really becoming more complicated when protected mode was introduced, and you couldn't just easily jump back and forth between calling the BIOS (which existed only in real mode) from your protected code. (Yes, it could be done, but it was/is a pain to do so)
UEFI came about later after things started rapidly moving to 64-bit long mode; though it was conceived of towards the end of the 32-bit era of the x86.
In some ways UEFI simplifies making an OS; you effectively can generate a PE32 binary that can use the provided services to do some basic loading and discovery in a flat memory model with a set of basic drivers provided by the hardware vendors.
Unfortunately they also added that awful "secure boot" nonsense which just makes it a pain if you want to test on actual hardware and not a virtual machine.
PostPosted: Wed Oct 30, 2024 12:36 am
Translation: I want to create an OS for my 6502. I would like to create a 6502 OS from scratch based on CP/M and distribute it to everyone. But I don't know what to do with that emulator and assembler.
Which emulator and assembler are you working with?
Side note: I'm using Google Translate for this, my Japanese isn't that good.
(Really super heavily skewed really as most of it I picked up from watching tones of Anime over the past 35+ years.)
PostPosted: Wed Oct 30, 2024 12:38 am
みなさんありがとうございます。ちょっと6502の勉強に僕はこれからその6502のcomputerをエミュレータという形でいちから作ってみますc言語で作ってみますお待ちください。かなり時間かかります。作ろうと思った理由は6502のosやゲームを作りやすくするためですもちろんbiosはつけませんアドバイスや意見あればどうぞよろしくお願いいたします。
PostPosted: Wed Oct 30, 2024 12:40 am
Nora, I think you'll get more help if you yourself run your messages through translator software to post in English.  I'm afraid some of the people who might otherwise help you might not take the time to do that themselves.  I don't think anyone else here can read Japanese directly, let alone write Japanese.  I've been using https://translate.yandex.com/ to read your messages.  In any case, we wish you success, and hopefully we can be part of it.  FWIW, I speak Spanish and some French.  Actually, I learned to read and write in Spanish before I did in English.
PostPosted: Wed Oct 30, 2024 12:43 am
It's a good idea to have a good time with your friends and family.For a little study of 6502 I will try to make that 6502 computer from now on I will try to make it in c language Please wait.It takes quite a while.The reason I wanted to make it was to make it easier to make 6502 os and games.Of course, I don't add too complex features.
PostPosted: Wed Oct 30, 2024 1:41 am
Now I'm preparing a design for that 6502 computer terminal and I'm going to put a floppy disk drive and a cartridge on it.and i'm also thinking about how to boot.
PostPosted: Wed Oct 30, 2024 3:40 am
Welcome aboard :)
PostPosted: Wed Oct 30, 2024 4:21 am
The text in his messages are just little, featureless boxes on my screen.
Users browsing this forum: DRG and 28 guests
