It is currently Fri Nov 01, 2024 2:37 am
 Post subject: rf6847 core
PostPosted: Thu Oct 17, 2024 11:19 am
I have been enthused to create a 6847 core in System Verilog. It will be a slight modification due to the intended output to a VGA monitor in 800x600 mode.
The display will be 50 by 25 characters instead of 32x16.
Alpha / graphics modes work in a manner similar to the 6847.
100x100, 200x100, 200x150, 200x300, 400x300 (full graphics mode)
instead of
64x64, 128x64, 128x96, 128x192,256x192
Output is the same 8 colors rendered with 6-bit RGB (2,2,2)
chars are 8x12.
Display RAM (16kB) is embedded in the core, so that external multiplexors are not needed.
There is a built in char ROM.
Meant mainly to be used in a system-on-chip.
http://www.finitron.ca
 Post subject: Re: rf6847 core
PostPosted: Thu Oct 17, 2024 11:52 am
Added legacy operation mode by pulling the 'leg' signal high.
32x16 chars centered in the display.
PostPosted: Sat Oct 19, 2024 1:27 am
The photo is crappy. IRL looks much better. Taken with a phone which thought it was a QR-code.
1st mile stone: text output.
At reset a randomizer fills the screen with random characters.
File comment: rf6847 txt mode
PostPosted: Sat Oct 19, 2024 1:29 pm
Nice work!
