6502 Macroassembler & Simulator (Michal k)
I wont to run the woz-monitor in the simulator. But what I trie no succes. Can someone help me out with this, perhaps a running version is very helpful. I struggle withe the in- and output of the simulator in respect to the woz-monitor.
Thanks for any help.
Jan Kromhout - NL
Jan Kromhout - NL
- barrym95838
Re: 6502 Macroassembler & Simulator (Michal k)
I don't have time right now to help much, but I would like to make a point that WOZMON expects bit 7 to be set for incoming and outgoing chars and has some subtle dependencies on the same.
Ben Eater made a nice video that may be helpful, perhaps dependent on your personal level of skill.
- BigDumbDinosaur
Jan Kromhout - NL
Jan Kromhout - NL
First, welcome to 6502 land.
Can you be more specific about what is not working? Perhaps you should write a simple “TV typewriter” to test that the simulator’s I/O window is functioning the way you think it should. Also, which version of the simulator are you using?
Hi Jan,
Here is a working copy. I modified it to run in the Kowalski Simulator. I needed to add some LDA #$8A - JSR ECHO statements to produce line feeds after the carriage returns. I also needed to modify the IO routines to support the high bit 7 used and removed a few initialization statements so it still fits in exactly 256 bytes.
Set up the Simulator with the 6502 or 65C02 processor. The IO page is mapped to $D000. Assemble and start the Simulator. Press the RESET button (far right) and then the RUN button. If the IO page does not open up, open it from the menu. Be sure to select the IO page before entering any keystrokes.
You can get the latest Simulator version from my website: https://sbc.rictor.org/kowalski.html
Have fun!
Have fun!
- Attachments
- WozMon.zip
- (2.45 KiB) Downloaded 54 times
Thanks for the quick respons.
Have set the IO at $D000, compile the code and switch to the debugger.
The IO window is popping up.
Push RST and run in debugger. Notting is comming up in the io window!
Do I sommething wring? Use the latest version of the emulator.
Jan
Jan
Sounds like you have everything set right. be sure the disable the memory protection and be sure the address bus is set to 16 bits on the general tab.
Make sure you click inside the output window before you try to type any entries, otherwise your keystrokes will go somewhere else.
Try this test file - it just reads the input and echo's it back to the screen. If it does not work, there's something else happening (international character code compatibility??)
Anyway, one step at a time.
thanks!
thanks!
- Attachments
- test.zip
- (167 Bytes) Downloaded 47 times
Dear Daryl,
The testfile is working perfect, de wozmonitor all most.
After setting my keyboard to uppercase it was running.
But try to run this simple test program scrolling text on the screen :
0000: A9 00 AA 20 EF FF E8 8A
0008: 4C 02 00
but without results. Run it on my Replica-1 SBC and it runs perfect.
Aso not working is when I try:
FF00R on a clean assembling.
Monitor is also halted.
Can you take a look
Cheers.
Jan
0008: 4C 02 00
Can you take a look
Cheers.
Jan
hi Jan,
The modifications I made to the source code to support the Simulator IO caused some of the IO addresses to change.
The address of the ECHO routine is now at $FFF2 vs $FFEF.
Try this code:
Here is a listing of the new source file
After you start the Wozmon (RST button and Run button), typing FF00R should return a / prompt. It did for me. It will not work if you do not first start the Wozmon running.
Have fun!
Try this code:
0000: A9 00 AA 20 F2 FF E8 8A
0008: 4C 02 00Code: Select all
00001 ; Written by Steve Wozniak in 1976
00002
00003
00004 ; Page 0 Variables
00005
00006 0024 XAML = $24 ; Last "opened" location Low
00007 0025 XAMH = $25 ; Last "opened" location High
00008 0026 STL = $26 ; Store address Low
00009 0027 STH = $27 ; Store address High
00010 0028 L = $28 ; Hex value parsing Low
00011 0029 H = $29 ; Hex value parsing High
00012 002A YSAV = $2A ; Used to see if hex value is given
00013 002B MODE = $2B ; $00=XAM, $7F=STOR, $AE=BLOCK XAM
00014
00015
00016 ; Other Variables
00017
00018 0200 IN = $0200 ; Input buffer to $027F
00019 D004 KBD = $D004 ; PIA.A keyboard input
00020 D011 KBDCR = $D011 ; PIA.A keyboard control register
00021 D001 DSP = $D001 ; PIA.B display output register
00022 D013 DSPCR = $D013 ; PIA.B display control register
00023
00024 00FF00 *= $FF00
00025
00026 00FF00 D8 RESET: CLD ; Clear decimal arithmetic mode.
00027 00FF01 58 CLI
00028 00FF02 A9 A7 LDA #$A7 ; KBD and DSP control register mask.
00029 00FF04 C9 DF NOTCR: CMP #'_'+$80 ; "_"?
00030 00FF06 F0 18 BEQ BACKSPACE ; Yes.
00031 00FF08 C9 9B CMP #$9B ; ESC?
00032 00FF0A F0 03 BEQ ESCAPE ; Yes.
00033 00FF0C C8 INY ; Advance text index.
00034 00FF0D 10 14 BPL NEXTCHAR ; Auto ESC if > 127.
00035 00FF0F A9 DC ESCAPE: LDA #'\'+$80 ; "\".
00036 00FF11 20 F2 FF JSR ECHO ; Output it.
00037 00FF14 A9 8D GETLINE: LDA #$8D ; CR.
00038 00FF16 20 F2 FF JSR ECHO ; Output it.
00039 00FF19 A9 8A LDA #$8A ; LF print (modified)
00040 00FF1B 20 F2 FF JSR ECHO ; (modified)
00041 00FF1E A0 01 LDY #$01 ; Initialize text index.
00042 00FF20 88 BACKSPACE: DEY ; Back up text index.
00043 00FF21 30 F1 BMI GETLINE ; Beyond start of line, reinitialize.
00044 00FF23 AD 04 D0 NEXTCHAR: LDA KBD ; Key ready?
00045 00FF26 F0 FB BEQ NEXTCHAR ; Loop until ready.
00046 00FF28 09 80 ORA #$80 ; Load character. B7 should be ‘1’. (modified)
00047 00FF2A 99 00 02 STA IN,Y ; Add to text buffer.
00048 00FF2D 20 F2 FF JSR ECHO ; Display character.
00049 00FF30 C9 8D CMP #$8D ; CR?
00050 00FF32 D0 D0 BNE NOTCR ; No.
00051 00FF34 A9 8A LDA #$8A ; LF print (modified)
00052 00FF36 20 F2 FF jsr ECHO ; (modified)
00053 00FF39 A0 FF LDY #$FF ; Reset text index.
00054 00FF3B A9 00 LDA #$00 ; For XAM mode.
00055 00FF3D AA TAX ; 0->X.
00056 00FF3E 0A SETSTOR: ASL ; Leaves $7B if setting STOR mode.
00057 00FF3F 85 2B SETMODE: STA MODE ; $00=XAM, $7B=STOR, $AE=BLOCK XAM.
00058 00FF41 C8 BLSKIP: INY ; Advance text index.
00059 00FF42 B9 00 02 NEXTITEM: LDA IN,Y ; Get character.
00060 00FF45 C9 8D CMP #$8D ; CR?
00061 00FF47 F0 CB BEQ GETLINE ; Yes, done this line.
00062 00FF49 C9 AE CMP #'.'+$80 ; "."?
00063 00FF4B 90 F4 BCC BLSKIP ; Skip delimiter.
00064 00FF4D F0 F0 BEQ SETMODE ; Set BLOCK XAM mode.
00065 00FF4F C9 BA CMP #':'+$80 ; ":"?
00066 00FF51 F0 EB BEQ SETSTOR ; Yes. Set STOR mode.
00067 00FF53 C9 D2 CMP #'R'+$80 ; "R"?
00068 00FF55 F0 3B BEQ RUN ; Yes. Run user program.
00069 00FF57 86 28 STX L ; $00->L.
00070 00FF59 86 29 STX H ; and H.
00071 00FF5B 84 2A STY YSAV ; Save Y for comparison.
00072 00FF5D B9 00 02 NEXTHEX: LDA IN,Y ; Get character for hex test.
00073 00FF60 49 B0 EOR #$B0 ; Map digits to $0-9.
00074 00FF62 C9 0A CMP #$0A ; Digit?
00075 00FF64 90 06 BCC DIG ; Yes.
00076 00FF66 69 88 ADC #$88 ; Map letter "A"-"F" to $FA-FF.
00077 00FF68 C9 FA CMP #$FA ; Hex letter?
00078 00FF6A 90 11 BCC NOTHEX ; No, character not hex.
00079 00FF6C 0A DIG: ASL
00080 00FF6D 0A ASL ; Hex digit to MSD of A.
00081 00FF6E 0A ASL
00082 00FF6F 0A ASL
00083 00FF70 A2 04 LDX #$04 ; Shift count.
00084 00FF72 0A HEXSHIFT: ASL ; Hex digit left, MSB to carry.
00085 00FF73 26 28 ROL L ; Rotate into LSD.
00086 00FF75 26 29 ROL H ; Rotate into MSD’s.
00087 00FF77 CA DEX ; Done 4 shifts?
00088 00FF78 D0 F8 BNE HEXSHIFT ; No, loop.
00089 00FF7A C8 INY ; Advance text index.
00090 00FF7B D0 E0 BNE NEXTHEX ; Always taken. Check next character for hex.
00091 00FF7D C4 2A NOTHEX: CPY YSAV ; Check if L, H empty (no hex digits).
00092 00FF7F F0 8E BEQ ESCAPE ; Yes, generate ESC sequence.
00093 00FF81 24 2B BIT MODE ; Test MODE byte.
00094 00FF83 50 10 BVC NOTSTOR ; B6=0 STOR, 1 for XAM and BLOCK XAM
00095 00FF85 A5 28 LDA L ; LSD’s of hex data.
00096 00FF87 81 26 STA (STL,X) ; Store at current ‘store index’.
00097 00FF89 E6 26 INC STL ; Increment store index.
00098 00FF8B D0 B5 BNE NEXTITEM ; Get next item. (no carry).
00099 00FF8D E6 27 INC STH ; Add carry to ‘store index’ high order.
00100 00FF8F 4C 42 FF TONEXTITEM: JMP NEXTITEM ; Get next command item.
00101 00FF92 6C 24 00 RUN: JMP (XAML) ; Run at current XAM index.
00102 00FF95 30 30 NOTSTOR: BMI XAMNEXT ; B7=0 for XAM, 1 for BLOCK XAM.
00103 00FF97 A2 02 LDX #$02 ; Byte count.
00104 00FF99 B5 27 SETADR: LDA L-1,X ; Copy hex data to
00105 00FF9B 95 25 STA STL-1,X ; ‘store index’.
00106 00FF9D 95 23 STA XAML-1,X ; And to ‘XAM index’.
00107 00FF9F CA DEX ; Next of 2 bytes.
00108 00FFA0 D0 F7 BNE SETADR ; Loop unless X=0.
00109 00FFA2 D0 19 NXTPRNT: BNE PRDATA ; NE means no address to print.
00110 00FFA4 A9 8D LDA #$8D ; CR.
00111 00FFA6 20 F2 FF JSR ECHO ; Output it.
00112 00FFA9 A9 8A LDA #$8A ; LF print (modified)
00113 00FFAB 20 F2 FF JSR ECHO ; (modified)
00114 00FFAE A5 25 LDA XAMH ; ‘Examine index’ high-order byte.
00115 00FFB0 20 DF FF JSR PRBYTE ; Output it in hex format.
00116 00FFB3 A5 24 LDA XAML ; Low-order ‘examine index’ byte.
00117 00FFB5 20 DF FF JSR PRBYTE ; Output it in hex format.
00118 00FFB8 A9 BA LDA #':'+$80 ; ":".
00119 00FFBA 20 F2 FF JSR ECHO ; Output it.
00120 00FFBD A9 A0 PRDATA: LDA #$A0 ; Blank.
00121 00FFBF 20 F2 FF JSR ECHO ; Output it.
00122 00FFC2 A1 24 LDA (XAML,X) ; Get data byte at ‘examine index’.
00123 00FFC4 20 DF FF JSR PRBYTE ; Output it in hex format.
00124 00FFC7 86 2B XAMNEXT: STX MODE ; 0->MODE (XAM mode).
00125 00FFC9 A5 24 LDA XAML
00126 00FFCB C5 28 CMP L ; Compare ‘examine index’ to hex data.
00127 00FFCD A5 25 LDA XAMH
00128 00FFCF E5 29 SBC H
00129 00FFD1 B0 BC BCS TONEXTITEM ; Not less, so no more data to output.
00130 00FFD3 E6 24 INC XAML
00131 00FFD5 D0 02 BNE MOD8CHK ; Increment ‘examine index’.
00132 00FFD7 E6 25 INC XAMH
00133 00FFD9 A5 24 MOD8CHK: LDA XAML ; Check low-order ‘examine index’ byte
00134 00FFDB 29 07 AND #$07 ; For MOD 8=0
00135 00FFDD 10 C3 BPL NXTPRNT ; Always taken.
00136 00FFDF 48 PRBYTE: PHA ; Save A for LSD.
00137 00FFE0 4A LSR
00138 00FFE1 4A LSR
00139 00FFE2 4A LSR ; MSD to LSD position.
00140 00FFE3 4A LSR
00141 00FFE4 20 E8 FF JSR PRHEX ; Output hex digit.
00142 00FFE7 68 PLA ; Restore A.
00143 00FFE8 29 0F PRHEX: AND #$0F ; Mask LSD for hex print.
00144 00FFEA 09 B0 ORA #'0'+$80 ; Add "0".
00145 00FFEC C9 BA CMP #$BA ; Digit?
00146 00FFEE 90 02 BCC ECHO ; Yes, output it.
00147 00FFF0 69 06 ADC #$06 ; Add offset for letter.
00148 00FFF2 29 7F ECHO: AND #$7F ; No, wait for display.
00149 00FFF4 8D 01 D0 STA DSP ; Output character. Sets DA.
00150 00FFF7 09 80 ORA #$80
00151 00FFF9 60 RTS ; Return.
00152
00153 ; BRK ; unused
00154 ; BRK ; unused
00155
00156 ; Interrupt Vectors
00157
00158 .WORD $0F00 ; NMI
00159 .WORD RESET ; RESET
00160 .WORD $0000 ; BRK/IRQ
00161 Have fun!
Dear Daryl,
Please can you post the asm code for me.
Jan
Jan
The asm for the small program is :
The ASM code from the disassembly above is posted in my first reply - WozMon.zip
thanks!
*= $0
LDA #$00
LP TAX
JSR $FFF2
INX
TXA
JMP LP
thanks!
Thanks, nice work.
Have played with it, but one thing is not going well.
When starting fresh with FF00R the program is hanging.
And always when I send FF00R the program hangs.
Please can you take a look.
Jan
Jan
Hi Jan,
I see what you mean now. Sorry for my mistake.
I had to fix part if the initialization at RESET. This made the source more than 256 bytes. To fix that, I added a subroutine to print CR & LF that is needed in 2 places. This allowed me to recover the extra bytes need and even gained back our 2 "spare" bytes at the end.
This did again move some of the internal command addresses, including ECHO, which is now at $FFE6
The attached file has the new ASM file and the listing of the assembler.
It should work now.
thanks!
It should work now.
thanks!
- Attachments
- WozMon.zip
- (5.92 KiB) Downloaded 45 times
Dear Daryl,
Thanks, it works.
I have another question. Is there an 6502 monitor (simple) that runs on the emulator.
I am verry interested in this, for my esp32 emulator project. Running 6502 code on my emulator is working, but I missing a small monitor. When this works I wont to implement ithis on my Replica sbc, so my board act as a standalone 6502.
Thanks for all your help so far.
Jan
Thanks, it works.
Jan
- barrym95838
- BigDumbDinosaur
What Mike said. WozMon comes from the days when 1KB was a lot of memory, and an 8KB machine was almost mainframe-grade.
There are other, more full-featured monitors out there, but WozMon is more than adequate to do basic debugging, especially inside of the Kowalski simulator.
