Tali Forth for the 65c02
adrianhudson
Re: Tali Forth for the 65c02
Fantastic! Thanks for making this change, it makes the disassembler much more useful
( I have to say I am really impressed by Forth in general. It's fast and compact.)
TLDR Version: I've updated the assembler further with string literal support so it doesn't try to disassemble the string data anymore.
VILR (Very Interesting... Let's Read!) Version: Tali inlines string data by compiling a jump over the string data, then a call to the string literal runtime handler, and then two cells that contain the address and length of the string:Tali used to try to disassemble the string data after the jump and would sometimes gack on it. To fix this, I needed to recognize the JMP/JSR sliteral_runtime pattern. When the assembler encounters a JMP instruction, it peeks ahead at the jump destination to see if the 3 bytes there are the JSR sliteral_runtime instruction. If it matches, it adjusts the current disassembly location to skip over the string data and continue at the jsr. There is then a special handler for JSR sliteral_runtime that prints the following string address and length and skips over those as well.
I thought about printing the string data, but Tali supports very long strings and they are shown in the memory dump when using SEE, so the address and length should be good enough in the disassembly. Here is an example of the new behavior, including typing in the address and length and TYPEing one of the strings.The 2DROP got inlined as the stack depth check and the INX instructions.
Strings are compiled into the dictionary like so:
jmp a
<string data bytes>
a --> jsr sliteral_runtime
<string address>
<string length>
: teststrings s" This is a string literal" 2drop ." This is a printed string" ; ok
see teststrings
nt: 800 xt: 813
flags (CO AN IM NN UF HC): 0 0 0 1 0 1
size (decimal): 78
0813 4C 2E 08 54 68 69 73 20 69 73 20 61 20 73 74 72 L..This is a str
0823 69 6E 67 20 6C 69 74 65 72 61 6C 20 8A A0 16 08 ing lite ral ....
0833 18 00 20 D5 D7 E8 E8 E8 E8 4C 57 08 54 68 69 73 .. ..... .LW.This
0843 20 69 73 20 61 20 70 72 69 6E 74 65 64 20 73 74 is a pr inted st
0853 72 69 6E 67 20 8A A0 3F 08 18 00 20 DE A4 ring ..? ... ..
813 82E jmp
82E A08A jsr SLITERAL 816 18
835 D7D5 jsr STACK DEPTH CHECK
838 inx
839 inx
83A inx
83B inx
83C 857 jmp
857 A08A jsr SLITERAL 83F 18
85E A4DE jsr type
ok
$816 $18 type This is a string literal okRe: Tali Forth for the 65c02
SamCoVT wrote:
Note that SEE changes the base to hex
Although I have RB to restore BASE for those words where I need to change it, I've followed advice given by Charles Moore and don't change BASE in my tools. If I want HEX output from SEE , or DUMP , I'll set BASE to HEX first.
adrianhudson
Hello all.
I am struggling with some relatively simple math (maths in the UK
I have a 16 bit number returned from a thermometer (sht31 if anyone is interested). It has to be converted using this formula
temperature = 175 * (rawtemp / 65535) - 45
I have come up with the following (which works - sort of - see below) Values are in hex.
: convertT ( rT -- T)
445C ( 17500 decimal )
m*
swap drop
1198 - (4500 decimal)
This gives results like (in decimal) 1950 for 19.50 degrees C - which is fine. This code is in effect doing the following:
temperature = (rawtemp ** 17500) - 4500 where ** is a 32 bit result with the lower 16 bits thrown away to act as as a division by 65536 (which is not 65535 but close!).
My problem is this:
The thermometer can give raw values of any magnitude ~$0000 to ~$FFFF (corresponding to ~-45C up to ~120C. The forth code above fails at input of $8000 and above, which is obviously to do with the sign of the number throwing the m*.
An unsigned m* - Um* would probably do the trick but Taliforth doesnt have such a thing.
Can anyone (better at Forth than me - which is almost anyone) help me please.
m*
swap drop
My problem is this:
- GARTHWILSON
- Forum Moderator
Are you sure? I think that in most Forths, M* is a secondary that uses the UM* primitive in its definition.
BTW, SWAP DROP can be shortened to NIP.
I might write:
Let us know how it works out. The only thing I've done for temperature is an LM335 circuit run into my A/D converter. I've never measured humidity.
I might write:
: convertT ( rT -- T) [ DECIMAL ]
17500 UM* NIP
4500 - [ HEX ] ;Let us know how it works out. The only thing I've done for temperature is an LM335 circuit run into my A/D converter. I've never measured humidity.
adrianhudson
oops. You are right, there is a UM* ~blush~
Works perfectly now. Why I decided there was no um* I don't know.
Thanks for the NIP!
Thanks for the NIP!
Does Tali Forth still inline DO LOOPs?
: test do loop ; ok
see test
nt: 800 xt: 80C
size (decimal): 70
080C A9 08 48 A9 51 48 38 A9 00 F5 02 95 02 A9 80 F5 ..H.QH8. ........
081C 03 95 03 48 B5 02 48 18 B5 00 75 02 95 00 B5 01 ...H..H. ..u.....
082C 75 03 48 B5 00 48 E8 E8 E8 E8 20 E9 97 18 68 75 u.H..H.. .. ...hu
083C 00 A8 B8 68 75 01 48 98 48 E8 E8 70 03 4C 36 08 ...hu.H. H..p.L6.
084C 68 68 68 68 68 68 hhhhhh
80C 8 lda.#
80E pha
80F 51 lda.#
811 pha
812 sec
813 0 lda.#
815 2 sbc.zx
817 2 sta.zx
819 80 lda.#
81B 3 sbc.zx
81D 3 sta.zx
81F pha
820 2 lda.zx
822 pha
823 clc
824 0 lda.zx
826 2 adc.zx
828 0 sta.zx
82A 1 lda.zx
82C 3 adc.zx
82E pha
82F 0 lda.zx
831 pha
832 inx
833 inx
834 inx
835 inx
836 97E9 jsr 1
839 clc
83A pla
83B 0 adc.zx
83D tay
83E clv
83F pla
840 1 adc.zx
842 pha
843 tya
844 pha
845 inx
846 inx
847 3 bvs
849 836 jmp
84C pla
84D pla
84E pla
84F pla
850 pla
851 pla
Fleet Forth's DO LOOP's also use the $8000 "fudge factor" so they end when an overflow is detected.
I asked about the inlining because I've been working on some ideas for an STC version of Fleet Forth and have versions of the DO LOOP words which do not get inlined. The added overhead for (DO) and (?DO) would be minimal since they only run once per loop. I also think the added overhead for (LOOP) and (+LOOP) would also be minimal, thanks to a suggestion from leepivonka.
Another benefit, there is a separate (LOOP) primitive compiled by LOOP .
STC versions of Fleet Forth's DO LOOP's.
The use of SUBR (subroutine) was so I could test these words with the current version of Fleet Forth, an ITC Forth.
I realize you may not want to change Tali Forth's DO LOOP's. If it's not broken, don't fix it; however, it might be worth trying if you have a really big application with lots of DO LOOP's and find memory getting a little tight.
Patrick actually wrote three different alternative looping options and benchmarked them against each other. We ended up choosing the "Loop Control Block - Simple" (lcb simple) version because it offered the best speedup while still being relatively simple to implement. Tali's test suite has a cycle counter added to py65mon, so we were able to benchmark all three options and saw the following speedups (the numbers are 65C02 cycle counts (clocks)):
: do?word1 5 5 ?do loop ;
original 322
master 322 ; all about the same
push/pull 325
lcb cmplx 325
lcb simple 325
: do?word2 100 0 ?do i drop loop ;
original 12836
master 8384
* push/pull 6052 ; -6 cycles for i
lcb cmplx 7218 ; speculatively incrementing i
lcb simple 6658
: doword 100 0 do loop ;
original 6700
master 2148
* push/pull 1304 ; simple one-level loop
lcb cmplx 2651
* lcb simple 1310 ; about the same
: dowordi 100 0 do i drop loop ;
original 12700
master 8248
push/pull 5904 ; -6 cycles for i
lcb cmplx 7169
lcb simple 6511
: dodoword 100 0 do 10 0 do loop loop ;
original 90500
master 44748
push/pull 42704
lcb cmplx 51318
* lcb simple 33410 ; 9294/100 => 90 cycles better for nested loops
: dodowordij 100 0 do 10 0 do i drop j drop loop loop ;
original 210500
master 165748
push/pull 149704 ; not a huge difference when all native comple
lcb cmplx 158217
lcb simple 156410 ; default J is a JSR; +6 cycles for i
* lcb simple' 144410 ; forcing J native compile
: dodowordbigi 10 0 do 1024 0 do i drop loop loop ;
original 1282730
master 822298
* push/pull 587424 ; -6 cycles for xt_i
lcb cmplx 700317
lcb simple 648060 ; diff 60636 = +61440 for `i`, 804 better otherwise
: doword+loop 100 0 do 5 +loop ;
original 2420
master 2418
* push/pull 2291
lcb cmplx 2601
* lcb simple 2213 ; faster when step `<256`Re: Tali Forth for the 65c02
SamCoVT wrote:
If you are interested in the "Loop Control Block" scheme that Tali now uses, let me know and I can provide more details as to the inner workings.
adrianhudson
I am doing a bit more FORTH programming. I have a word that may need to bail out with a message if it encounters an error. The thing is it is 3 levels deep and I want it to continue execution at the first level. Normally I understand this is solved by THROW and CATCH which Tali doesn't support. What is the best way of achieving this in Tali please anyone?
leepivonka
I can think of several alternatives:
If you know how to clean the parameter & return stacks:
If you want to return all the way back to the FORTH interpreter:
Use returned flags to indicate word execution should be cut short:
Or start implementing Throw & Catch for Tali Forth.
Define a word:
: RDrop ( R: addr -- ) \ discard a return stack entry
[ $68 c, $68 c, \ pla; pla
] ; always-native compile-only
Use RDrop as needed to remove return address cells from the return stack.
Use Drop as needed to remove cells from the parameter stack.
Use Quit or Abort or Abort" to end application executionCode: Select all
A called word would return a flag or set a global variable to indicate callers should quit.
The word's caller would test the flag & cut processing short as appropriate.
adrianhudson
@leepivonka
Many thanks!
"Or start implementing Throw & Catch for Tali Forth"
If only I knew how!
Many thanks!
If only I knew how!
- barrym95838
I immediately thought of using in-line RDROP(s) to unnest the return stack but I was too timid to post, since I'm a stark beginner in programming FORTH. I know a lot about the internal nuts and bolts but I've never taken it for a serious test drive.
