Old Guy with Special Case Need to Divide by Three
teamtempest
Re: Old Guy with Special Case Need to Divide by Three
Post by teamtempest »
teamtempest wrote:
I only worked out one random example by hand. Kind of a distributed division:
<snip>
; adjust by hi byte
ldx dividend+1
clc
adc factor,x
factor:
.byte 0*85, 1*85, 2*85
$1FF aka 511 is a special case you will need to handle...
I thought you must be right, because you tested far more extensively than I did. Without that I thought it was possible something might be off.
But if I work it out by hand I get the correct result:
511 = %01 1111 1111
511/3 = 170
x(lo) = 255 = %1111 1111
x(lo)/3 = 85 = %0101 0101
x(hi) = 1 = %01 (so add 85)
85 + 85 = 170
Is there a mistake? A carry bit threw the calculation off somewhere?
BruceRMcF
Post by BruceRMcF »
BillO wrote:
Is the following significantly smaller than a 756 byte look-up table?
Just look at the final assembly address (+1 since the origins are all $xx00) of each snippet to see vs $2F4.
2100: $21
2200: $2A
2300: $3A
2400: $2D
2500: $37
2600: $49
2700: $17
2800: $34
Seems like all of them would be.
BillG wrote:
 2000                     00532          org    FreeRAM
 2000                     00534 DIVIDE_BY_THREE:
 2025 60              [6] 00572          rts
2100                     00574          org    FreeRAM+$100
 2100                     00585 div3_ay:
 2120 60              [6] 00616          rts
 2200                     00618          org    FreeRAM+$200
 2200                     00651 Mine:
 220D 4C 2213         [3] 00663          jmp    EnterLoop
 2229 60              [6] 00692          rts
 2300                     00694          org    FreeRAM+$300
 2300                     00696 BB8:
 2335 60              [6] 00735          rts
 2400                     00737          org    FreeRAM+$400
 2400                     00739 OptimizedBB8:
 242C 60              [6] 00773          rts
 2500                     00775          org    FreeRAM+$500
 2500                     00780 ModifiedBB8:
 2536 60              [6] 00825          rts
 2600                     00827          org    FreeRAM+$600
 2600                     00829 MineTabled:
 262D 60              [6] 00870          rts
 2634 60              [6] 00879          rts
                          00880
 2635 00 00 00 01 01 01   00881 MyTable  ...
 2647 06 06
 2700                     00883          org    FreeRAM+$700
 2700                     00889 div3:
 2716 60              [6] 00906          rts
 2800                     00908          org    FreeRAM+$800
 2800                     00917 ModifiedBB8_plus_teamtempest:
 2834 60              [6] 00968          rts
BillG
Post by BillG »
511 = %01 1111 1111
511/3 = 170
85 + 85 = 170
You are right about 511. Faulty analysis on my part.
Now try 513 and 514 with your method...
BillG
Post by BillG »
BruceRMcF wrote:
2900: $122
That last one is the test driver and not a candidate division subroutine.
BB8
Post by BB8 »
Further optimized... I'm using your suggested one byte DivBy3. And no loops anymore, only code going forward.
Now it should be at 49-67 +rts cycles when adopting zeropage variables.
        ldy nl
        lda nh          ; loads high byte
        beq lv          ; if zero then goes to low byte value
                        ; otherwise will sub 255 from low byte and add 85 to res
                        ; one or two times
        iny             ; subtracts 255 from low byte
        beq hv1         ; if zero, high byte is not done
        cmp #1          ; checks high byte
        beq hv2         ; if zero, high byte is done
hv1     lda #170        ; .A = 2 x 85 (partial quotient)
   byte $2c             ; *** the wonderful bit/$2c trick!! my first time... ***
hv2     lda #85         ; .A = 85 (partial quotient)
        sty nl
lv                      ;  here value is <256 (only low byte)
        sta res
        tya
        lsr
        adc #21
        lsr
        adc nl
        ror
        lsr
        adc nl
        ror
        lsr
        adc nl
        ror
        lsr
        clc             ; adds the partial quotient from the upper byte
        adc res
        sta res
        rts
res byte 0
nl  byte <726
nh  byte >726
BillO
Post by BillO »
BillG wrote:
BruceRMcF wrote:
2900: $122
Gotcha.
barrym95838
Post by barrym95838 »
BruceRMcF wrote:
2700: $20
You added nine or ten bytes to mine, depending on how you look at it.
BruceRMcF
Post by BruceRMcF »
barrym95838 wrote:
BruceRMcF wrote:
2700: $20
Definitely added some. $20 instead of $17 would be adding 9.
WynnSmith
Post by WynnSmith »
Your input here is more than I could ask for. A 'Thank you' seems inadequate. Nevertheless, thank you.
fachat
Post by fachat »
I haven't closely followed I'm afraid but has this division algorithm been discussed so far? https://www.bbcelite.com/deep_dives/shi ... ision.html
Robin from YouTube's 8bit show and tell has pointed to it on Twitter/X
https://twitter.com/8BitShowAndTell/sta ... 9530750115
In its division-by-10 variant, but I believe it can be adopted to division-by-3.
André
barrym95838
That's almost exactly what mine is doing. The smallest and slowest of the bunch.
fachat
Post by fachat »
Haha, I was almost expecting this, that you guys already know all that :-)
Great stuff!
fachat
Post by fachat »
What I like about the bbcelite division algorithm is that it is very small - and that it can be adopted to other argument sizes (and divisors) easily. I find that very neat.
Hermes
Post by Hermes »
Hello!
I hope, I am not too late with my answer.
You can multiply the lower 8 bits of your 10 bit number by 171 and take the lower 8 bits of the result.
You don't even have to calculate the upper byte.
You can ignore the upper 2 bits of your 10 bit number. That works, because your numbers are a multiple of 3.
Use the fastest multiplying by 171 algorithm that you can come up with. (a 256 byte lookup table would work)
To divide by 5 you multiply your lower 8 bits by 205 and throw away the upper byte. (your input must be a multiple of 5)
