It is currently Tue Jun 04, 2024 1:05 pm
PostPosted: Wed Feb 21, 2024 5:04 pm
Have built a WDC65c816SXB-inspired SBC with a 65c816 CPU with an 6551 ACIA for console input/output. Have an assembler startup file that does the basic initing of CPU and ACIA after power-up and then transfers to control to the main() function in a .c file. At the moment, the main() function calls two functions I wrote myself called getchar() and putchar(). These are used to show a welcome message on the console and to read keystrokes from the keyboard. Both functions directly access the 4 ACIA registers, memory-mapped at RAM addresses 0x7F80...0x7F83. Nothing too hard or shocking. The ANSI-compliant C compiler from WDC (WDC816CC) includes the standard libraries that also have putchar() and getchar() functions. They typically read from stdin and write to stdout.
How do I configure the compiler's putchar() and getchar() to use those RAM addresses so they can replace my versions? This way I can also use other "stdio.h" functions such as printf() and scanf()?
PostPosted: Wed Feb 21, 2024 6:23 pm
personally i wouldn't be using WDC's tools, they definitely show their age... but if you get them to work and they work fine for your needs then go ahead.
but i would recommend something like Calypsi C, it's C99 instead of C89, has pretty good documentation, and is actively being maintained.
i also remember vbc (a forum member) talking about working on a VBCC port for the 65816, but that was a really long time ago and i wonder what happend to that project since (from my experience) making a crappy but functional backend shouldn't take that long, right?
anyways back to the WDC tools, i don't know how exactly they handle their standard libraries (but from the documentation i can see that they include them), but i'd assume that similar to newlib, the included libraries would only contain the hardware independent components which would make calls to system specific functions (open, close, read, write, sbrk, etc.)
to see if that's the case you could just try it out. make a simple hello world program with printf, include the given library while linking and then see which function the compiler will complain about being missing.
or if they include the source code for the used libraries (which they should) try to see if you can find any function stubs for read, write, etc. or grep (findstr on windows) through them to find any mentions of functions like that, which would also tell you what arguments they need.
then you just write them (either in assembly or C) assemble/compile them to object files and throw them into a library to link along side your program.
PostPosted: Thu Feb 22, 2024 3:46 pm
My main objections to Calypsi C are closed source, x86 only and restrictive license terms. But I suppose it's good it's out there.
Machine room: http://www.floodgap.com/etc/machines.html
PostPosted: Thu Feb 22, 2024 4:29 pm
the same is true for the WDC tools though, unless they just released the source code or made an ARM (or native 65816) version that i don't know of...
i'm still hoping for that VBCC port so we have a fully open source compiler that could in theory compile itself to allow for native C programming on a 65816. ah, the dream!
PostPosted: Thu Feb 22, 2024 4:44 pm
There's still SDCC (I still need to try out the latest version; the last had some issues. The most recent is still missing 6502 and 65c02 specific documentation).
I seem to remember that with SDCC it is necessary only to define putc() and getc() to make the stdio work.
edit: putchar() and getchar() - see here: viewtopic.php?f=2&t=7049#p98263
PostPosted: Thu Feb 22, 2024 6:10 pm
wait since when does SDCC have a 65816 target? i can't find anything to that online...
PostPosted: Thu Feb 22, 2024 8:12 pm
Oh I'm sorry; for some reason I thought we were looking for 65(c)02.
Mea culpa!
PostPosted: Thu Feb 22, 2024 8:39 pm
Dr Volker had briefly mentioned a 65C816 VBCC port in work about a year ago.  However, nothing seems to be forthcoming.  I suspect such a port is not a trivial project and also suspect it will remain vaporware for the foreseeable future due to the complexity involved, as well as the limited demand for such a thing.
Every so often, I get a small burr under my saddle to look at porting the ehBASIC interpreter to the 816 running in native mode and making full use of 16-bit registers, enhanced stack capabilities, etc.  I then come to my senses as I contemplate the amount of work involved and the fact that relative to the typical lifespan of most men, I am a short-timer.  :D  I don’t even have a working kernel written for my POC unit, so finding time to rework a major piece of software such as ehBASIC seems ludicrous to me—I’m literally unlikely to see results in my lifetime.  :(
PostPosted: Thu Feb 22, 2024 9:19 pm
Alan Cox has a C compiler under development that includes 6502 and 65816 support as part of his FUZIX Compiler Kit project. I don't think it is production ready yet, and I believe it has some limitations due to its intended use as part of the FUZIX project. No idea how good it is. Source is at https://github.com/EtchedPixels/Fuzix-Compiler-Kit.
PostPosted: Thu Feb 22, 2024 9:36 pm
I don't like to see the term "vaporware" applied to personal projects. It reads to me as perjorative. If a project seems to be making slow progress, there will be reasons. No-one has a right to demand that someone else's project should make progress.
PostPosted: Thu Feb 22, 2024 10:04 pm
Some years ago, I mucked around with the WDC tools, but ended up setting them aside.  C compilation for the 65C816 seemed reasonably competent, but the resulting linked binaries tended to be bulky and slow-executing.
One of my tests was to implement my version of mkfs (filesystem builder) in C, which uses a lot of integer math and BIOS I/O calls.  During testing, the C version of mkfs ran at about one-fourth the speed of the assembly language version.  Additionally, the binary produced by the WDC linker was nearly twice the size of that produced by assembly language.  Although I didn’t dig into the binary to see where the bottlenecks were, I suspect the compiler’s handling of the API interface was inefficient.
Based on that testing, as well as on some other tests I ran, I decided that while C in itself on the 816 would be acceptable for applications, and possibly an operating system kernel¹, using the WDC compiler to compile the source would not produce satisfactory results.
I suspect an 816 back end that knows how to effectively use the different possible memory models (similar to what C compilers of the 8086-80286 era had to do) would be a non-trivial exercise.  For example, in my assembly language programs, I use macros for library function calls that know the difference between “near” and “far” pointers,² each of which requires a different approach to constructing the stack frame that passes parameters into the function.  The macros were definitely not trivial to write, so I imagine code for a C compiler that would be able to implement equivalent 816 memory models would also not be trivial to develop.
A complication with C on the 816 is how to define the heap and how to give a running program more RAM when requested, i.e., how to model the equivalent of sbrk and malloc.  While the 816’s address space can be treated as flat for data purposes, in some cases, treating it as segmented may result in a faster-executing program, mainly due to the aforementioned use of 16-bit pointers, vs. 24-bit.³  That being a consideration, sbrk has to know which addressing model to use—a one-size-fits-all approach is not going to work.
  1. The time-critical parts, mainly interrupt handlers and device drivers, would likely have to be written in assembly language.
  2. In this context, “near” and “far” refer to objects that are in the execution bank or are elsewhere in memory, respectively.  “Near” addressing can use a 16-bit pointer, which can be dereferenced more quickly than the “far” equivalent.
  3. 24-bit pointers on the 816 are computationally inefficient—I use 32-bit pointers for “far” accesses.
PostPosted: Thu Feb 22, 2024 10:22 pm
Vaporware, as defined in Wikipedia:
In the computer industry, vaporware (or vapourware) is a product, typically computer hardware or software, that is announced to the general public but is late, never actually manufactured, or officially cancelled.
I’m not using “vaporware” in a pejorative sense.  The term’s definition is sufficiently generalized to be understood as “the product is not forthcoming.”  I’m merely highlighting the fact that significant time has elapsed between the present and when the 65C816 vbcc port was mentioned.
No one has made any such demand.  You are manufacturing controversy out of thin air, Mr. Ed.
PostPosted: Thu Feb 22, 2024 11:02 pm
that's why i specifically said crappy backend. getting a backend into a "functional" state doesn't nearly take as long as making it generate good assembly.
my own SW32VM backend for VBCC took me a few months to get (mostly) working, 32-bit ints are broken for some reason, and VBCC doesn't include any kind of test suite, so knowing what features are still missing is difficult. but for having never worked with VBCC before i think i did pretty good so far. (i'll post an update on the SW32VM thread when i get time to just sit down and write it and push all updates to the github as well)
anyways this is why i would think that someone (or a team of people) much more knowledgeable than me likely already have a mostly functional backend and now just focus on bug fixing, optimizing the code generation, and adding customization options (like default pointer sizes).
PostPosted: Thu Feb 22, 2024 11:03 pm
Unfortunately some issues have prevented me from working on it as I had originally planned. It has not been canceled and the backend is mostly complete, but I still need to finish the C library, run my test suite, and do some optimizations.
And I am not aiming for "crappy but functional". :-)
PostPosted: Fri Feb 23, 2024 1:10 am
That’s reassuring!  “Crappy but functional” would be too much like Microsoft Windows.  :D
