Can the SPI interface handle 320x240 with 16-bit color at 60 frames per second? If so, I'd rather use that than the 18-bit parallel RGB LCD I'm currently using.
nope, sadly not. SPI is way too slow for that.
the Datasheet for the ILI9341 mentions that the maximum speed of the SPI interface is 10MHz, so transferring a whole frame of data will take ~122.8ms (~8 FPS).
when it comes to graphics you just need large bandwidths which means wide data buses or very high transfer speeds.
so like said if you want to actually get 60 FPS you have to use atleast the 8-bit parallel interface at pretty high speeds, or the 16/18-bit one at half the speed of the 8-bit interface.
I'm trying to avoid relying on things that are too modern like a MicroSD card. I intend to have a flash memory chip to hold the firmware since I have a GQ-4X programmer already.
that's a bit of a confusing statement, µSD cards are almost 30 years old at this point, and both very cheap and easy to interface. you yourself wanted to use SPI for the display which has an equally if not more modern LCD controller on it, so why draw the line at storage?
and yea i would recommend using Flash chips for the boot code of the system. and if you give the CPU access to the ~WE pin on them you can have the CPU reprogram its own boot ROM, which can be risky but also pretty convienent as you then don't need use an external program to update the ROM.
though still having some form of storage would be a good idea, being able to load, store, and transfer files conveniently between your system and a PC can be very useful for software development.
There will be voltage regulators changing voltage on things due to no combination of parts I'm looking at settling on a single voltage, so I suspect I'll have voltage lines for 1.8V (or whatever the FPGA needs), 3.3V and 5V going through the board.
what other parts do you have planned that would require up to 3 different voltages?
basically all FPGAs i know of can run at 1.8V-3.3V, the ILI9341 specifically needs 3.3V,
cheap SRAM,
Flash/ROM chips are also available for 3.3V, and the 65xx have a voltage range of 1.8V-5V.
so unless i'm missing something, you should be able to just run the whole system with only 3.3V.
