It is currently Sun Nov 24, 2024 1:55 am
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed Feb 07, 2024 8:27 am
Hi Neil,
I connected the logic analyser to serial port CH.A coming out of the Digiac board. as I mentioned in a previous post the pinout is non standard pin 1 is TX1 Pin 6 is RX1. I had to make a custom cable which I broke out onto a breadboard so I could connect the ftdi ft232rl adapter and the logic analyser. The chip on the digiac board that handles the serial communication is a motorola mc2681 duart. The output from the duart goes through a max232 ic and int o the serial port.
PostPosted: Wed Feb 07, 2024 9:09 am
Yup, I suspect you're looking at an inverted RS 232 signal if you're looking at the signal on your breakout box, after the D-9 connector.
But if your FTDI adaptor is an RS232 adaptor and not a UART adaptor, it should correct that apparent inversion (UART can be expected to idle at +5v (or +3v3 for 3v3 systems) while the RS232 signal idles at -3 to -15v)
PostPosted: Wed Feb 07, 2024 7:38 pm
I measured the voltage at idle at the db9 connector on the digiac it reads -9v
I did some research, apparently you can reprogram the firmware on the ftdi ft232r to invert the tx and rx lines.
after several hours of messing around I reprogrammed my converter with inverted signals.
Now when I try to connect to the digiac via serial it does nothing, the digiac board wont go into terminal mode.
I tested the ftdi adaper by connecting tx and rx together and it works.
I'm running out of ideas.
PostPosted: Wed Feb 07, 2024 8:20 pm
Joseph, it's not clear to me if you understand the difference between just a UART and RS-232 (most accurately "TIA-232," but everyone understands "RS-232").  It's not just about inverting versus not inverting.  RS-232 levels are much higher voltages than just normal logic levels, and they're positive and negative too.  Pretty standard is to go plus and minus twelve volts (although there's a wide acceptable range), to become more immune to noise getting into the line; and connecting an RS-232 output to a standard logic input will probably damage the latter.  I certainly understand the common desire to forgo the RS-232 line drivers and receivers; but unfortunately this has led to confusion and incompatibility, and sometimes damage.  Your FTDI adapter needs to be one that that has the RS-232 line drivers and receivers.  I have a somewhat 65xx-oriented RS-232 primer at http://wilsonminesco.com/RS-232/RS-232primer.html .
PostPosted: Wed Feb 07, 2024 10:27 pm
I'm pretty sure you can get a cheap and cheerful level converter for this situation. (Which also inverts.)
I think I might have one of these - I imagine there are cheaper versions
https://www.sparkfun.com/products/449
Or you can roll your own
http://picprojects.org.uk/projects/simpleSIO/ssio.htm
PostPosted: Thu Feb 08, 2024 3:41 am
Mohan wrote:
I measured the voltage at idle at the db9 connector on the digiac it reads -9v...
It appears the serial interface on the Digiac unit is TIA-232.
TIA-232 operates at a nominal plus and minus 12 volts DC with respect to ground, with generally-accepted operating conditions supporting a voltage range of 3 to 25 volts.  When the voltage is positive with respect to ground, the TIA-232 circuit is in the “space” condition, which may be thought of as a logic 0.  When the voltage is negative with respect to ground, the circuit is in the “mark” condition, which is considered a logic 1.
On the UART side, a space is zero volts, which is the “opposite” of what is on the TIA-232 side (+3 to +25), but still representing a logic 0.  A mark is a high, generally close to VCC, again the opposite of what is on the TIA-232.
Due to the differences between voltage and polarity on both sides, line drivers, such as the Maxim MAX232 or the older 1488/1489 devices, are required to couple the UART to the TIA-232 link.  The drivers act as level converters and logic inverters at the same time.  As a fairly general rule, you cannot safely connect a TIA-232 circuit directly to a UART—this is aside from the inverted logic meanings.  UARTs operate at 5 or 3.3 volts, always positive with respect to ground.  A TIA-232 circuit operating at full nominal voltage will drive the UART’s inputs well beyond their ratings and likely cause damage.
Those are okay if the only connections you want to make are RxD and TxD.  They have no provisions for CTS/RTS flow-control.  In most cases, attempting to operate above 9600 bpS without hardware flow control will lead to errors during sustained transfers.  As always, caveat emptor!
PostPosted: Thu Feb 08, 2024 6:26 am
I was unable to find either a circuit diagram or a sufficiently clear photo of the Digiac circuit board, but from the photos I did find it looks as if there are two UART-RS232 converter chips between a 40-pin part and the sockets. You could hook a UART signal at their inputs, if this is so.
PostPosted: Thu Feb 08, 2024 1:43 pm
I'm just going to wait until the serial card that I ordered for my pc to arrive, I'll make a custom cable for it and report back my findings.
PostPosted: Sat Feb 10, 2024 1:08 pm
Good news, everyone it is working, I can now communicate with the board via serial terminal.
Thank you all for your advice, suggestions and constructive criticism.
PostPosted: Sat Feb 10, 2024 1:45 pm
That's excellent! I get the impression the serial connection offers some good facilities over and above the keypad options.
